Question about Epic A30T Treadmill
White line when turn machine on
When the machine is turned on a white line goes across the screen whether the key is in or not. Not power to any part of the machinge
Is Worth Fixing Panasonic PT-50LC13-K Rear Projector TV
most likely a bad mainboard or bad caps in the power supply. Borderline on the repair-ability. I would check Shopjimmy.com to see if used parts are available. If they are it may be worth it.
Sep 14, 2015 | Panasonic PT-50LC13 50" Rear Projection...
How do I Fix LCD White Screen?
If you see "fractured lines" across the screen, it would appear that your LCD screen is broken. That's the only way these kinds of lines appear.
You need to replace the screen.
May 14, 2012 | Computers & Internet
Having problems with my laptop theres white lines that goes across my screen and freezes my hole laptop and when i try to turn it on sometimes theres nothing that even show up on the screen
Restart your computer in same mode and see if you see the same issue.
To do this tap the F8 key as soon as the laptop begins to start.
If you see the same problem even in safe mode it might be problem with your laptop screen and might need to be serviced at the service center
Aug 18, 2011 | Computers & Internet
When i turn it on it goes to a white screen with a blue line across on the very top it says recovery code 108 the next line says "would you like to recover your system?" then it gives me three...
when i turn it on it goes to a white screen with a blue line across on the very top it says recovery code 108 the next line says "would you like to recover your system?" then it gives me three options no, repair disk, and format disk. I dont know what to do cam body help me?
Nov 04, 2010 | Archos 605 WiFi Digital Media Player
White line across my laptop screen vertical
Do a hard reset to the system take the battery out and unplug the power cable, make sure to unplug the acadapter from the system so there should be no power on the system, after that you have to keep the power botton pressed on the laptop for 50 seconds and then release it. connect the battery only and turn on the laptop and go to the bios screen. if the line is present in the bios too than its a pixcel problem which cannot be repaired if under warranty get the screen replaced in case its on the windows screen then you have to reload the video driver.
May 05, 2009 | Toshiba Satellite A135-S4467 Notebook
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Phone wont turn on
may be the drink goes into the cpu and flash
in this case anything could happen
pleasae reball the flash ic and the flash it
Jan 28, 2008 | Nokia 7373 Cellular Phone
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Epic A30T Treadmill Logo
69 people viewed this question
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Colin Stickland
Colin Stickland
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
