Question about Dryers
Lg tromm dle2514w dryer
I have replaced the fuse and thermostat, approximately 1 month later the fuse blows again. I have noticed the est. drying time display change, if set at 41 minutes, a few minutes later the display changes to 15 minutes remaining. I have replaced and cleaned the vent, cleaned the filter, what else could be the issue? It also appears that the drum is louder. Continuity good on element and thermostat.
  • 1,087 Answers
The first thing that tends to go are the bearings on the drum. When they are worn that will be harder work for the motor and that could be the reason for the fuse going. I would get it checked by a tech. NB A lot of house fires are started by dryers!
Posted on Mar 23, 2014
rickzilla
  • 706 Answers
SOURCE: LG TROMM DRYER DLE2514W
Hello Napew65,
Please use this link http://136.166.4.200/contents/Laundry/DLE2514W.htm to get access to the service, operator and all manuals associated with your dryer. You can run diagnostics as shown in the service manual to interpret the root cause of your problem. Let me know if you still aren't able to get this resolved.
Regards
Rick
Posted on Jan 06, 2009
  • 142 Answers
SOURCE: LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Posted on Sep 28, 2009
PSITECHNICAL
  • 71 Answers
SOURCE: check filter light wont shut off and setting.lg tromm dryer
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
Posted on Dec 23, 2009
omaharox
  • 166 Answers
SOURCE: the check filter light keeps coming ob to my lg
Clean the vent all the way to the outside.
The dryer will take 4-5 loads to reset the filter sensor.
Mahe sure the vent is not smashed behind the dryer.
Posted on Jan 20, 2010
  • 2696 Answers
SOURCE: Maytag performa Keeps blowing Thermal Fuse. Vents
something is still plugged with lint,if the vent line is long blow it out with a leaf blower to clean it out,you have to clean out the duct that the lint filter slides into,if the filter is on top remove the vent line,remove the back panel,remove the lint filter and the two screws in front of it and remove the four screws and clean out the duct,if the filter is in front take off the bottom panel,remove the filter and clean the duct,also vac out the inside of dryer where the motor is,when the dryer gets to hot the thermal fuse pops as a safety so you still have a block somewhere
Posted on Mar 19, 2010
How to change fuse in LG Trom dryer circuit breaker model DLE2514W
dryers don't have circuit breakers in them you do have them in your house fuse box,you must mean like the thermal fuse or high limit fuse,if the dryer isn't running these are the things you want to check,also if the dryer and vent line haven't been cleaned out and you might have noticed that it was taking loner for your clothes to dry,this will blow one of the t-stats as a safety,all a dryer does is move air,if you have a block in the dryer or vent line one of the fuses pop from the dryer heating up to much from the block so clean out the dryer and vent line before you run the dryer again if you fix it because the t-stat that was blown will blow again.
Jan 15, 2018 | LG Dryers
I have a LG Tromm dle0442w doesn't heat blow out cold air
It is caused by three possible candidates:
(1) The thermal fuse
(2) Heating element
(3) High limit thermostat.
Have these devices checked out and replace the faulty part.
Feb 28, 2015 | LG Dryers
Lg dryer is overheating blowing the thermal fuse
you have an airflow problem. Check the vent hose all the way out and the outdoor vent hood.
a simple verification can be performed by disconnecting the vent hose from the dryer and see if this solves the problem.
Mar 03, 2014 | LG DLE5977 Electric Dryer
My LG Tromm electric dryer won't heat - again.
if the high limit is popping the dryer is getting to hot,i know you say you checked the vent line but i've heard that before,when i get out i remove the vent from the back of dryer,change out the t-stat and run it with the vent line off and it runs fine,how long is the vent line?if it's a long run remove it from the back of dryer and stick a leaf blower into it,blow it out to the outside and see what comes out,also first run it on air fluff,if this is a newer dryer set it to timed dry and then you can set it to air fluff,go outside and feel how it blows,then after you blow it out check it again,if you see alot of lint blow out and it's blowing harder your all set,you should take the dryer apart and clean it and the vent line once a year and you won't have any problems like this,also you won't have to worry about a dryer fire,your clothes will dry on time and less parts will have to be changed out,also when you get it to heat again run it on air fluff,if it gets hot on air fluff you have a shorted heater,one of the coils are touching the metal box on the heater and the heater won't shut off,also you have to clean out the duct where the lint filter slides down into,if this is blocked the dryer can't push the air out the blower wheel is blocked with lint.hope this helps you out happy holidays
Dec 25, 2017 | LG Tromm Electric Dryer
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
Lg TROM dryer DLE2514W drying time very slow takes forever
be sure the lint trap is empty, and you might have to check the outside vent for blockage also....it worked for me.
Dec 30, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Sep 28, 2009 | Dryers
Hello Napew65,
Regards
Rick
Jan 04, 2009 | LG DLE2514 Electric Dryer
Kenmore dryer won't start
your blowing that many thermal fuses, id replace all the thermostats. (2) come in one kit both on heater box 1 top and one bottom. id also look into your venting, a clogged fo kinked vent is going to overheat the unit and blow all sorts of stuff(not to mantion the potential fire hazard of a bad vent
Mar 19, 2008 | Dryers
Dryers Logo
Top Dryers Experts
