Question about Husqvarna Garden
Husqvarna power belt loose how to tighten
Model 2042LS no traction or power to back wheels
    Genius:
  • 1,114 Answers
Parts and Diagrams for Husqvarna 2042 LS 96043006200 2008 11 This link will provide diagrams of the drive belt and associated parts. The diagram shows the idler pulleys and tension springs. Inspect your mower to compare all drive parts to the diagram. Hope this helps....
Posted on Apr 23, 2014
Tightening steering wheel on husqvarna tractor 42in 15 horsepower no. yth1542
Interesting! The steering gear can commonly become loose at a several points. I would check the steering wheel itself, prise off the central plastic cover and make sure the nut underneath is tight. Check the gear at the bottom of the steering wheel shaft, if this gets loose it can jump the gear teeth. Sometimes this is so bad the steering wheel will turn without moving the wheels. Tighten everything and replace any worn parts.
Jun 13, 2016 | Husqvarna Garden
Do I tighten a ground belt from a 2011 Husqvarna rz5424 zero turn lawn mower?
There is not an "adjustment" tension is held by an idler pulley. If the belt is too loose, you must change it.
Aug 09, 2015 | Husqvarna Garden
Change belt on snapper 722 snow blower
1. Remove the belt cover with a socket wrench. Slide the belt cover off and set it aside.
2. Remove the two belt cover stud bolts with a socket wrench to get to the auger belt guide. 3. Remove the belt guide with a socket wrench.
4. Push down on the belt tensioner pulley with your hand. Remove the old belt and set it aside.
5. Install the new belt and release the belt tensioner pulley to tighten the belt.
6. Re-install the belt guide with a socket wrench and tighten the bolt.
7. Re-install the two belt cover stud bolts and tighten with a socket wrench.
8. Re-install the belt cover and secure it with the cover bolts. Tighten the bolts with a socket wrench.
I pulled the following from a snaper model similar to yours.
The snowthrower has two drive belts, one for the traction
drive-which transmits engine power to the wheels, and
a second for the auger drive-which transmits engine
power to the auger mechanism.
Each of these drive belts are of special construction and
should be replaced only with genuine replacement belts
which match the original equipment belts. These are
available from your dealer.
Traction Drive Belt Replacement
I pulled the following from a snapper model similar to yours. Believe it should help.
1. Disconnect spark plug wire and fasten it away from
the spark plug.
2. Remove belt cover. (Located in back of the discharge shute).
3. Pull the traction drive belt idler pulley arm (See
Figure 24) away from the belt to relieve tension, and
slide the belt off the engine pulley.
4. Slip the belt off from around the traction pulley (See
Figure 29) and pull the belt out of the unit between
the auger pulley and the traction pulley (the lower
cover need not be removed for this step).
5. Reverse the procedure to install the new belt. Be
sure there are no twists in the belt, and that the belt is
properly seated in the pulley grooves.
6. Replace the belt cover.
7. Start the unit, and check the traction drive for proper
operation. See "Traction Clutch Cable Adjustment"
for adjustment procedures.
There are also several videos on YouTube on changing snowthrowr belts. (Didn't see one for your blower, but most similar and should provide a good starting reference).
May 09, 2014 | Agri-Fab Agri - Fab Snow Blower - 42"
My 42" Husqvarna (model #917.279240
Remove the center dust caps from the rear axles, start the tractor up and put it in gear and observe the axles, if one of them is spinning freely inside the wheel, you have lost the 1/4" square key that pins the wheel to the axle. Replace the key and you can go back to mowing. Hope this helped Tim
May 15, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
I have a Toro personal pace mower. Model 20017 The propulsion system isn't working. If I lift the mower, the wheels will spin, but back on the ground it won't propell the mower. I just put a new...
im assuming you dont here any grinding, start by tightening the cable ( loosen the cable mounting bolt slide the cable towards the engine, make sure you leave some play in the cable so its doesnt engage constantly and re-tighten ) this is most likely your issue however if you re-test and get grinding you either need new drive gears and wheels, new transmission or possibly both, you said it does something just not powerfully this pretty much rules out your belt, highly doubtful its that worn out and if it came off of a pulley it would do literally nothing, however if you tighten it and the drive is almost normal but still weak you do have a worn drive belt
May 10, 2011 | Toro Power Lawn Mower
ABSand traction control and slip light keeps popping up. When car is turned off it goes off but comes back after awhile. Solution???
One of your wheel sensors is either bad/off or loose. Check all wheel sensors and replace bad or tighten loose one.
Feb 18, 2011 | 2005 Nissan Altima
The rear wheel drive in my Husqavarna push lawn mover quite working, how can I fix it?
You can try putting a little more tension on the drive belt. It is probably stretched out a bit and the drive engagement cant cancel all the slack out. So, the belt slips.
Pull out your owners manual and look up instructions for tightening the drive belt. If you dont have a manual go to the Husqvarna website and get a PDF copy.
Good luck and be careful!
Jul 20, 2010 | Husqvarna 675 hp 21" Honda Rear Bag Push...
Replacing the alternator
Fig. : Alternator mounting-2.2L engine
REMOVAL & INSTALLATION
(2.2L Engine)
  1. Disconnect the negative battery cable.
  2. Raise and support the front of the vehicle, then remove the passenger side tire and wheel assembly for access to the rear of the alternator through the wheel well.
  3. Working through the wheel well, unfasten the alternator brace-to-block bolt, then remove the brace-to-intake nut and the brace-to-engine stud nut.
  4. Unplug the alternator wiring connector, then remove the battery terminal nut and wire.
  5. Carefully release the serpentine belt tension and remove the belt from the alternator pulley. Do not allow the tensioner to snap back into position once the belt is off the pulley.
  6. Loosen the alternator retaining bolts, then support the alternator and remove the fasteners. Remove the alternator from the vehicle.
To install:
  1. Position the alternator in the vehicle and loosely install the retaining bolts.
  2. On 1994-98 models, tighten the top alternator bolt to 22 ft. lbs. (30 Nm) and the bottom bolt to 32 ft. lbs. (43 Nm).
  3. On 1999-99 models, tighten the rear bolt to 37 ft. lbs. (50 Nm) and the front bolt to 18 ft. lbs. (25 Nm).
  4. On 1994-98 models, install the alternator brace, then tighten the retaining nut(s) and bolts to 22 ft. lbs. (30 Nm).
  5. On 1999-99 models, install the alternator brace, tighten the brace-to-alternator and brace-to-intake retainers to 18 ft. lbs. (25 Nm). Tighten the brace-to-engine stud nut to 37 ft. lbs. (50 Nm).
  6. Install the battery terminal wire and tighten the retaining nut, then engage the alternator wiring connector.
  7. Hold the serpentine drive belt tensioner, back off the belt while slipping the belt over the alternator pulley. Gradually lower the tensioner into contact with the belt, then check for proper alignment and tension.
  8. Connect the negative battery cable.
Fig. : Alternator mounting-4.3L engine
(Except 2.2L Engine)
  2. Remove the air inlet duct assembly, if necessary.
  3. Carefully relieve the serpentine drive belt tension, then remove the belt from the alternator pulley. Do not allow the tensioner to snap back into position once the belt is off the pulley.
  4. Remove the nut retaining the radiator hose brace to the back on the alternator.
  5. If equipped, unfasten the retainers, then remove the brace from the engine and/or the alternator.
  6. Disconnect the battery terminal boot wiring from the back of the alternator, then unplug the regulator wiring connector.
  7. Support the alternator and remove the mounting bolts (usually 2) from either side of the alternator, then remove the alternator from the vehicle.
To install:
  1. Position the alternator in the vehicle and loosely install using the mounting bolts.
  2. If equipped, loosely install the brace to the engine and/or alternator.
  3. Tighten the left or front alternator retaining bolts to 36 ft. lbs. (50 Nm), the right or rear alternator bolt to 18 ft. lbs. (25 Nm), the brace bolt to 18 ft. lbs. (25 Nm) and/or the brace nut to 22 ft. lbs. (30 Nm), as applicable.
  4. Connect and secure the alternator wiring.
  5. Carefully relieve the serpentine drive belt tension and position the belt over the alternator pulley, then slowly release the tensioner into position.
  6. If equipped, install the air inlet duct assembly.
  7. Connect the negative battery cable.
I hope helps with this. Good luck (remember rated this help).
Jan 05, 2010 | 1998 Chevrolet S-10 Pickup
Tractor won't go forward or reverse
Check the drive belt. It has probably broken or has come loose.
Sep 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blower wheel on dryer is loose
Jclay, you are in for a little work here partner. On this model the blower is up-front. The dryer is going to have to come apart for you to tighten or replace the blower wheel. The end caps on the consol will pull off. Remove the two screws on each end securing the consol. Flip the consol up. There will be 3 quarter inch screws under the consol, in back, holding the top on. Remove these and the top will slide off, forward. Remove the bottom panel by the blower. Remove the lint filter. Remove the 4 screws attaching the front panel and door to the front of the dryer, remember to unplug the door switch cable. The drum now can be removed after removing the belt. Take the tension off the belt by moving the pulley over. Remember the belt configuration so you can put it back on right. Once the drum is removed you will now be able to get a wrench on the motor shaft itself so you can tighten or replace the wheel. Reverse the above steps and your back in business. Im going to attach a picture of a rear blower system and the way to take it off. Yours is up front but the removal will work the same way. Sometimes you have to cut the old blower wheel off because it's fused on with heat. Your part number for the wheel is 697772. Remember to unplug the dryer during this work..Catriver..post back.
Aug 30, 2006 | Kenmore 63012 Electric Dryer
Garden Logo
585 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
