Question about Craftsman Garden
Doesnt charge or start
Hi there,have a Wedgewood 18 hp sit on mower and it doesn't charge the battery and will not start at all although I DO have a spark and fuel supply would be grateful for any help,thank you .
  • Craftsman Master
  • 2,478 Answers
First remove charge it check voltage, then 12 hours later see if 12-13 volts. Also check start fuse.
Posted on Mar 23, 2014
SOURCE: 15 HP Kohler Engine RIding mower wont stay on
What's the gap setting between the coil and flywheel 15 hp kohler motor?
Posted on Aug 03, 2008
  • 5 Answers
SOURCE: Husqvarna 24 hp mower shuts down after about 5 or 10 min.
I WOULD LOOK FOR AN ELECTRICAL (IGNITION) SHUTDOWN,CHECK WHEN IT SHUTS DOWN WITH SPARK TESTER TO SEE IF IT IS FIRING.
Posted on Apr 08, 2009
  • 1129 Answers
SOURCE: 18 HP tractor cranks but will not start
It sounds like you lost compression take out the spark plug and screw in a compression tester to check for engine pressure there should be 70 - 90 psi, if you can't buy one put you thumb over the spark plug hole and have a assistant crank over the engine push on the hole pretty hard, be careful not to get a shock from the spark plug wire while cranking the motor, if you feel pressure with your thumb reinstall the plug and connect the spark plug wire proceed to remove the air cleaner and pour a small amount (1 o.z ) of gas into the carburetor hole then try to start if it starts then stalls it is a fuel delivery issue. unscrew the carb float bowl to clear out any water or debree from it. the float bowl is round and is located on the under side of the carb, it should un screw by wraping a rag around it and turning it counter clockwise with a strong hand. also try cranking over the motor with your hand over the carb intake hole this will force any debree to get cleared out of the tiny passages in carb without having to full disassemble the carb this may also get the motor started for you if it starts remove your hand to allow the motor to breath and start/run.
Posted on Jul 16, 2009
  • 80 Answers
SOURCE: Starts but won't stay running
It sounds like you are getting a vapor lock.
Try getting the fuel line and fuel fillter away from the motors heat.This will cause the fuel to boil and give you trouble. Check all your electrical connections for that clicking problem. Make sure everything is clean and tight. Check your spark plug gap.
John
Posted on Sep 28, 2009
SOURCE: craftsman riding mower will not start
Same thing happened to me with my 26 horse kohler craftsman. Replaced EVERYTHING (spark plug, fuel filter, oil filter, and degunked the carborator), and still was flooding. It ended up being the flywheel key. Cheap part, quick fix. I guess it can happen when you hit something hard with the deck, or it can just happen without reason... I hit a snowbank hard with my snowblower attachment, but I didn't even realize it until afterwards because it kept running fine. Supposedly, even after the strain to the engine, it won't always stall out. It will keep running (but maybe rougher) until you shut it off. Then when you go to start it again, you will have no luck because all the timing is out of whack. It cost me $80 to have a repair company fix it. I think the part was only $5.
Posted on May 21, 2010
Craftman 18 hp won't start with key
Check Battery. If headlight equipped turn key to headlight on position and see if headlights are lit. No light dead battery dead tractor,
Charge battery. If after charging weak or no start forget the battery and get new, Life of battery is two to three years,
If battery good make sure that parking brake set and blades are not engaged. Safety lockout will prevent tractor from cranking. The tracker has a safety interlock on the seat that requires a body warm or cold sitting on the seat if the parking brake is not set. The seat switch is known to fail. Try bouncing on the seat?
OK if battery OK and seat is sat or park brake set we can assume the safety interlock circuit is disabling the start circuit.
Need model to provide more answers
This website video shows how to check the component. Your model would be similar.
How to test lawn mower electrical safety switches
This electrical diagram is for a typical lawn tractor. Your model would be similar but different . This will give you an idea. The switch on the seat has two sets of contacts.26045611-oxnapdkevdwqbvzn03d44ye1-1-0.png
Jan 09, 2016 | Garden
18hp craftmans will not start no clicking noise
First of all check the battery is fully charged.
If OK check the battery terminals are clean and tight.
Check that the brake is on, gearbox in neutral and disengaged, mower disengaged and you are sitting on the seat. Many mowers have safety features to prevent starting unless these conditions are met. If it still fails to start, check the starting circuit, including the switch and the solenoid. Still no luck? Check the wiring to make sure there is not a short circuit in an of the starting wiring.
Oct 14, 2014 | Garden
Why can' I t get mower to do anything when trying to crank it over?
try jumping your battery with your car/battery. If that works, charge your battery and/or adjust your valves. If it doesnt, try jumping directly to the starter from the battery. If that works, get a new starter solenoid. If it doesnt, get a new starter.
Jun 09, 2014 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman riding mower doesnt turn over easily
I have the same problem and suspect it is caused by a combination of an older starter requiring more amps and the battery not able to supply them. When I fully charge the battery my engine starts OK.
Try leaving the battery on charge for a couple of hours
Mar 11, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Poulan 18 HP 42" deck; battery would not charge so replaced it with new. Now starter gear will not engage with teeth on flywheel, sits just below engagement level and just spins. Suggestion
Most starters will have a bendix shaft, once the motor starts to rotate the gear follows the bendix thread up into the fly wheel ring gear, so there is either not enough charge in the battary, or the bendix on the starter motor is bad, or the gear itself is bad, or the battary is wired up the wrong way.
Feb 10, 2013 | Poulan 42 In Deck 165 HP 6 Speed Manual...
Lawn mower will not start or make any noise. Tried to jump battery with car and it started however can't sit on mower and car too Help please
why not????? i gess your mower battery has packed up fit a new one if the old battery has been left flat or gone flat over the winter its a right off now as it will never take a charge again sorry thats the way batterys are
Jun 18, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Tractor won't start. Battery fully charged but will not make a sound
kill switch is on? which would be the case when: mower perhaps engaged? or not sitting in seat? clutch not depressed fully?
May 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Battery want charge... ok i paid to talk w/ a
Sounds like the voltage regulator is bad--will run the battery down!
Feb 27, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
49 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
