Question about Novelty Manufacturing Novelty and Fake Money Dachshund Million Dollar Bill (pack Of 100) Pack of 100 pcs
Js 2102cor135 g bill value is
Value bis
I have 100 dollar bill 2009 made serial number LB91144927E WHAT IS VALUE, ALSO 20 DOLLAR BILL JD68371964B
Yours are worth $100 and $20 respectively. The serial numbers aren't 'special'. If you hundred was LB91144411E, then yes.
For serial-number hunters, $100 isn't just $100 - The Boston Globe
https://www.bostonglobe.com/ideas/2013/09/15/for-serial-number...isn.../story.html
Sep 15, 2013 - When the first new hundred-dollar bills are issued to the public on Oct. 8, the ... the real value will be determined by another number: the serial number. ... A $20 bill that was first off the press in a 2009 run sold in April for $5,581. ... radars" ($75 to $100) that have all internal digits the same, like 46666664.
How some new $100 bills worth $1,000 or more - USA Today
www.usatoday.com/story/money/business/2013/09/22/...100-dollar-bills/2849643/ Sep 22, 2013 - America's new $100 bill is getting a new look with improving printers and more ... That's the collectors' term, not the Globe's, for serial numbers that fall in a number ... It helps if you have friends in high and very secure places.
17 Bills in Your Wallet Worth More than Face Value - SavingAdvice ...
www.savingadvice.com/.../1018389_17-bills-in-your-wallet-worth-more-than-face-va... Oct 7, 2013 - Collectors estimate that new $100 bills with low numbers could be ... Binary bills are those notes which have a serial number that consist of only ...
Dollar bill: Serial numbers make banknotes worth thousands in online ...
www.dailymail.co.uk/.../Dollar-Serial-numbers-make-banknotes-worth-thousands-onl... Sep 17, 2013 - The eight-digit serial number which appears on each U.S. banknote is at the ... The next time you're holding a dollar bill, it might be worth looking ... Collectors have long been interested in rare and flawed money - and not just in the U.S. ... In 2009, a batch of 20p pieces that had been minted without the date ...
One Hundred Dollar Bill '
have 100 dollar bill 2009 made serial number LB91144927E WHAT IS VALUE...
Mar 26, 2017 | Refrigerators
I need a code of a simple login form with the output
<?php
require("db/config.php");
session_start();
if(isset($_POST["btnLogin"]))
$nm=$_POST["txtUid"];
$pas=$_POST["txtPass"];
$q=mysql_query("select * from userinformationtb where user_id='$nm' and password='$pas'");
$data=mysql_fetch_array($q);
$_SESSION["seid"]=$data["user_id"];
// session_id();
if($nm==$_SESSION["seid"])
header("location:php/home.php");
//echo "valid";
else
echo "invalid";
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<title>Untitled Document</title>
<link href="../css/style.css" rel="stylesheet" type="text/css" />
type="text/javascript" src="js/script.js">
type="text/javascript" src="js/cufon-yui.js">
type="text/javascript" src="js/arial.js">
type="text/javascript" src="js/cuf_run.js">
<link rel="stylesheet" href="css/validationEngine.jquery.css" type="text/css"/>
src="js/jquery-1.8.2.min.js" type="text/javascript">
src="js/jquery.validationEngine-en.js" type="text/javascript" charset="utf-8">
src="js/jquery.validationEngine.js" type="text/javascript" charset="utf-8">
jQuery(document).ready(function(){
// binds form submission and fields to the validation engine
jQuery("#frmLogin").validationEngine();
</head>
<body>
<form id="frmLogin" name="frmLogin" method="post" action="">
<table width="548" border="0" id="txtbrder">
<tr>
<td width="90" height="">Enter User Id </td>
<td width="152"><label>
<input name="txtUid" type="text" id="txtUid" class="tnm validate[required,custom[email]] text-input" />
</label></td>
<td width="56"><div align="left">Password</div></td>
<td width="154"><label>
<input name="txtPass" type="password" id="txtPass" class=" tnm validate[required] text-input validate[required,minSize[6]] text-input" />
</label></td>
<td width="74"><label>
<input name="btnLogin" type="submit" id="btnLogin" value="LogIn" style="background:#0000FF;color:#fff;"/>
</label></td>
</tr>
</table>
<a href="php/userinfo.php">Create New Account</a> &nbsp;&nbsp;&nbsp;&nbsp;
<a href="php/forgotpassword.php"> Forgot Password ?</a>
</form>
</div>
</body>
</html>
Oct 31, 2013 | Computers & Internet
How can I activate blackberry messenger on blackberry 9930 in south africa
You first need to buy R60 airtime for the network you are using such as MTN, Vodacom, Cell C etc. That R60 will be the amount you need for (BIS) Blackberry Internet Service. You need BIS to enable BBM (Blackberry Messenger) to work. Once you have topped up your airtime with R60, you need to dial *141*11# which should bring up the option to activate BIS. Choose BIS and not any other option. BIS is usually option 1, but just make sure you select to activate BIS. Once BIS is activated then you can go onto BBM (Blackberry Messenger) and you should be able to send messages. You then have internet access as well. The great thing about the BIS is that it lasts for a month, without you needing to pay anything after the R60 to send as many messages as you like for free on BBM, plus you can use the internet on your phone as much as you like too! I am experiencing a problem getting BIS on my Blackberry Curve which I shall ask a question about on this site!! Good luck :)
Apr 11, 2013 | Cell Phones
Flash_integration.min.js i get this message everytime i load empireand allies game on zynga
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; GTB7.2; EasyBits GO v1.0)
Timestamp: Sun, 18 Dec 2011 09:17:33 UTC
Message: Object doesn't support this property or method
Line: 1
Char: 209
Code: 0
URI: http://assets.castle.zgncdn.com/19555/js/flash_integration.min.js
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Sep 30, 2011 | Microsoft Internet Explorer 8
Web page errors
if you're using IE8 try the compatibility view,
Make sure that the page displays correctly within ie7 or ie6.
Let me have some feedback
Regards
GeWiz.
Jul 21, 2009 | Microsoft Internet Explorer 8
Ms access 2000 query help
you need to dwnlod a newer vertion of this product
Jun 03, 2009 | Microsoft Access 2000 Step by Step...
Novelty Manufacturing Novelty and Fake Money Dachshund Million Dollar Bill (pack Of 100) Pack of 100 pcs Logo
106 people viewed this question
Top Novelty Manufacturing Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Novelty Manufacturing Toy Expert? Answer questions, earn points and help others
