Question about Hurst Jaws Of Life / Vetter Vehicle Parts & Accessories
Ja how to make a jaws of life using syringes, rubber tubing and washing pegs
    Problem Solver:
  • 11 Answers
Ja -
Are you trying to make a model or mini-sized "Jaws of life" or the real thing?
Posted on Mar 25, 2014
My son needs to make jaws of life out of syringes, tubing and cardboard. How on earth do i do that
THE syringes act as the teeth of the jaws of life, the surgical tubing is used to hinge the jaws....fabricate some scissor like cardboard I am done with handles and there you have your Mock jaws of life
Mar 14, 2014 | Vehicle Parts & Accessories
How to make jaws of life
Id get a chunk of wood and a Swiss army knife and whittle one, finish with a metallic silver sharpie. Micheals
Mar 04, 2014 | Hurst Jaws Of Life / Vetter Vehicle Parts...
The printer turn on ok , then whene i print any thing the printer work ok but its not printing on the paper .
It seems like its a jammed print head for this try cleaning your print head using the cleaning utility thats present in your printer software, (NOTE: Head cleaning will consume a lot of ink) Or you can just clean your head with isopropryl alcohol.
Requirements:- 1. Isopropryl alcohol 2. Syringe 10 or 20ml 3. Tube(I used medical tube) that fits in the tip of the syringe and the nozzle
Steps: 1. First remove the needle from the syringe and fit the tube into the tip till its firm. 2. Pull 10 ml of isopropryl alcohol inside the syringe (note: no vacuum or air should remain inside the syringe) 3. Fit the tip of the tube on the nozzle of the print head and slowly squirt about 5ml of isopropryl into the nozzle and pull back till all the isopropryl comes back while pulling back clogged inks will come inside the syringe repeat this till the nozzle is clear. repeat this to all the nozzles. don't forget to throw away all the dirts (clogged inks that will come inside the syringe) and do it slowly, though it will take much time but it will be helpful. I was able to clear my jammed print head with this procedure hope this will help you.
Apr 17, 2011 | Epson STYLUS R230 InkJet Photo Printer
Where can i get a rubber tires for a Peg Perego John Deere Gator HPX 12 Volt Ride on Toy?
the whole tire would be difficult to replace with a rubber one, but you can put bmx tires on the plastic wheels and that will give much greater traction, but shorten the life of the gearboxes. here is a link to how to do it.
http://www.youtube.com/watch?v=AAySJVt6bys
Oct 04, 2010 | Peg Perego John Deere Gator HPX Ride on...
How do you bleed the clutch on the tuono?\r\ni have a little bleeder to help.
the way i do mine, get a large syringe put a 3.5-4mm inside dia. rubber tube ie fuel pipe, empty the clutch slave and fill the syringe with fluid put the tube on the nipple with the nipple open put syringe on the other end and push fluid in slowly make sure you take the cap off the master first, you will have to fill the syringe more than once when you finish emtying the syringe close the nipple each time, keep an eye on the master pot on the handle bars, when it gets to the high limit leave it for 15 seconds and then slowly press the clutch leaver and push the fluid into the syringe, each time you push the fluid make sure you don't run the master pot empty that must have a small amount in it, then wait until the air bubbles have stopped in both the syringe and the master pot, do this until there are no bubbles top and bottom and then tighten the nipple and put the cap on and try it.. I've found its the fastest way so far.
Sep 10, 2010 | 2008 Aprilia Tuono 1000 R
Bleed ktm 65 rear bakes 2003
the best way to bleed them is with a syringe and a bit of rubber tube. take off the resavoir tops, crack the nipples. do one at a time. fit tube over the nipple, fit the syringe into the pipe,make sure it is a tight fit bothe ends of the tube. fill syringe with dot 4 brake fluid. gently push in the plunger, very gently untill all air bubbles come out of the brake resevoir. hope this helps.
Mar 02, 2010 | 2003 KTM SX 250
Leaking water into frig when defrosts
The problem is the defrost drain is pluged. At the rear of the frig section up at the top you will see a small cup where the water drains into. I always used a large syringe with a rubber hose attached. Fill the syringe with hot tap water and flush the ice out of the drain tube. Once cleaned out and the water runs freely your problem will be solved.
Dec 27, 2009 | Kenmore Refrigerators
Clutch will not bleed
I had the same problem...FIX...with these bike you need to bleed the master cylender first. The way to do this is to fill the resevior and but the cap back on,pump the handle several times while holding the handle in break open the hose bolt on the resevior. MAKE SURE TO HOLD A RAG UNDER THE BOLT BECAUSE DOT4 WILL EAT YOUR PAINT. Do this a couple times until you have nothing but fluid comming out. You should now have a good handle as long as there is no air in the rest of the system.
Apr 08, 2009 | 2000 Suzuki VS 1400 Intruder
Fridge stinks
Hi there, you ay not want to detach it if its full and stinking!!
You could try using an ink syringe to remove a little at a time, alternatively a wet and dry hoover to remove it, then spray with something nice that is antibacterial.
Hope this helps, Chris
Nov 09, 2008 | Refrigerators
Vehicle Parts & Accessories Logo
193 people viewed this question
Top Hurst Jaws Of Life / Vetter Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Hurst Jaws Of Life / Vetter Vehicle Part and Accessory Expert? Answer questions, earn points and help others
