Question about Mr. Coffee IDS77 Electric Burr Grinder
Will not grind coffee
Grinder will not run
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
My Odea Giro stops working when entering the brew pump cycle. When I run it without coffee it runs fine. When I add coffee it stops after the grind cycle. I have replaced the microswitches and cleaned the...
I had a similar problem
Mine was caused by an "oily" type of coffee beans. Grind was accumulating in the grinder.
I did open the machine and cleaned the grinder physically. At least, try to remove all beans and sucked with a vacuum the interior of the grinder screw.
Good luck
Jun 18, 2014 | Saeco Odea Giro Plus Coffee Maker
Why when grinder is on finest setting
Did you clean the grinder before using it? Did you run a 1/2 kilo or so of junk beans through to clean out any oil/grease that was in the system from manufacture? How old are the coffee beans? If you grind at a 4 and run it through the drip machine, does the coffee still taste off?
Apr 30, 2014 | Mahlkoenig K 30 ES Grinder
Coffee grinder is not grinding beans fine enough
Try it with less beans, or the motor is not running at full speed, no other fix
Mar 24, 2013 | Coffee Makers & Espresso Machines
Grinder runs but will not accepts beans for grinding.
Hi Try turning the big knob up to 18 and the small knob down towards the minus. If that doesn't work your are going to have to disassemble the grinder and clean out all the passages. What is causing this to happen is your grind is too fine and the grinder is compacting the coffee in the passage. Once it is cleared, turn the grind down but higher than you had it before.
Nov 26, 2010 | Starbucks Saeco Italia Digital Barista...
Saeco machine grinder
Due to the use the grinding burrs are slightly move and wire out. So I advice you to move only one max two step to more fine coffee grinding from the one you have and try the coffee.
The test you have to do is that for about 30 cc of coffee the time that the coffee will run should be about 20 to 22 seconds. If the coffee more faster you need more fine grinding. If the coffee run more slower than 28 sec you need more gross coffee grinding.
Good luck
Mar 23, 2010 | Saeco Incanto Rondo Fully Automatic Coffee...
Coffee beans out of message
HI
I hate to tell you this but your grinder is bad. The sensor in the grinder is messed up, and thinks its done grinding after 3 seconds. The grinder will have to be replaced. Sorry
Dec 16, 2009 | Saeco Incanto Sirius Fully Automatic...
I have a Divina Deluxe and the coffee grinder is moving but it does not appear to be grinding it justs runs until the cycle stops. The machine turns on and gets ready but not grind. I have opened it up and...
Remove brew unit and check the grounds chute from the grinder, if that is clear, then re-insert unit, then when the grinder is grinding adjust to a coarser grind.
May 31, 2009 | Spidem Divina De Luxe Espresso & Coffee...
Grinder will not turn off
It is possible that the relay, or the micro switches on the grinder are defective.
Jul 27, 2008 | Bunn -o-Matic G3 (3 lb. Commercial Coffee...
Mr. Coffee IDS77 Electric Burr Grinder Logo
117 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
jmt
Level 1 Expert
Craig Butler
Craig Butler
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
