Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Gsc3pgxcfss warm fridge, freezer working fine, lights off in fridge
My refigerator is getting warm and both lights go off. The fan is still running, but no cold air is coming from the freezer. freezer is working fine. when I pulled the fan and light assembly off, the light started working again. the model number is gsc3pgxcfss. Any help would be appreciated.
  • 245 Answers
James, not sure I understand your message when you say both lights go off, but later say lights begin working. Do you mean they go off when you push the buttons at the door? And when you say no cold air comes from the freezer, is the freezer door closed? See if air begins flowing with freezer door open. If so it would indicate the return air path from the refrigerator to freezer is blocked.....damper staying closed or evaporator coil frozen up. The return air path has to be open to allow the freezer to keep sending out cold air to refrigerator when freezer door is closed. You might thoroughly defrost to make sure coil is not frozen.
If the door button for the refrigerator light is bad it can signal that the door is open all the time, so the freezer will never send cold air to the refrigerator. And that will be good news. Door switches are cheap. If you don't have a volt meter and know how to check switch, just remove the door switch from the refrigerator, leaving wires dangling, and close the door with a thermometer inside to see if it begins cooling (or just wait a while) I had that problem a year ago and was happy to find a bad door switch. More often it's a frozen coil, and that can be more expensive to fix. Sometimes you can discover a bad switch by pushing in the door button and the light stays on, but it doesn't sound like your situation.....sounds more like a frozen coil. If so, maybe all this extra information will help someone else.
Posted on Mar 23, 2014
fridgetech
  • 473 Answers
SOURCE: Freezer works; fridge side doesn't
First thing to check is look and see if there is  thick frost build up on the back lower panel inside the freezer?  If not there must be a problem in the damper (vent).  Let me know what you find so I can help.
Posted on Oct 21, 2007
SOURCE: ge side by side not cold enough in fridge or freezer
the fan behind the freezer panel inside
Posted on May 31, 2008
Krames
  • 18 Answers
SOURCE: Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Posted on Nov 15, 2008
SolutionGuy
  • 331 Answers
SOURCE: Frost in frostless freezer, fan not blowing into warm fridge
There are 2 things that cause these to not defrost. Kinda like the "Achilles heel" of GE fridges. The first one is the Defrost heater itself. And the second is the evaporator thermister (GE calls it a "sensor"). They are both very easy to replace. The part numbers are; WR51X10101 (heater) and WR55X10025 (sensor). If you don't have a local appliance parts retailer, just plug those numbers into a search engine. I highly recommend getting both parts because if the sensor hasn't failed yet, it will. The same goes for the heater...
Now for the fun stuff... Turn the temp knobs all the way counter clockwise to kill power to the fridge. Unload all the food from the freezer and remove all the shelves and the basket. Remove the screws that are holding the evap panel (the flat panel on the back wall, it's about 2 1/2 ft tall). Remove the panel to expose the evaporator. You'll see the heater at the very bottom of the evap connected by 2 screws, remove these and pull the heater out. Your new heater comes with instructions on how to install it.
After you have done that, look at the top of the evap. On the left, you'll see a little white sensor clipped to one of the evap tubes (shiny little clip), that has 2 wires feeding it. Remember which tube it's clipped to then unclip the sensor and pull it toward you. Snip the wires right at the base of the old sensor and completely remove it (leave the wires in there). Now separate those 2 wires and strip about 3/8" of insulation off. At this point, you are ready to follow the instructions that came with your new "sensor". Oh! and if it's all frosted up on the evap? Take this time (before you re-install the panel) to use a blow dryer and melt it away. All that'll be left to do is rebuild it.
There ya go! Job completion time= ~45 minutes. Easy breezy, right?
If this has been helpful, please don't forget to rate my solution. Thanks!
SG
Posted on Apr 05, 2009
tborn6
  • 700 Answers
SOURCE: GE Model GSH22JFTA Top of Fridg and Freezer not cold
check the door gaskets for air leakage
Posted on May 21, 2009
It could be the servo on the diverter door, but it's most likely to be the main control board. Sorry.
Mar 23, 2014 | GE Refrigerators
Freezer works fine but the refigerator does not get cool
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Oct 11, 2010 | Frigidaire FRT17G4B Top Freezer...
Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2010 | Jenn-Air JCD2389G Side by Side...
My freezer alarm won't stop beeping or blinking. Freezer is warming up. Help
If this is a refigerator / freezer and the fridge is fine, then most likely the freezer coils are frozen up and the fan can't blow the air through them.
If that is the problem, you will need to defrost them.
Jun 17, 2010 | Refrigerators
I have a monogram ZIS420 the freezer works fine
Sep 24, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Freezer working, fridge not
Possibilities include inside fan unit not running for some reason, thermostat cycling the unit off before its cold, compartment light staying on, damper adjustment set too warm or broken or blocked. There are others but less likely.
Jun 04, 2009 | Magic Chef CTB1922 Top Freezer...
Refigerator is blowing warm air
EITHER THE FLAP THAT SEPERATES COLD AIR FROM FRIDGE TO FREEZER IS CLOSED
OR
COILS ARE CAKED WITH DUST
OR
FREON IS WORN OUT
Mar 31, 2009 | Refrigerators
Cold freezer warm fridge.
That sound was the evaporator fan motor in the freezer. This circulates the cold air from the freezer into the fresh food section. If this is not running you need to check for power to it. If the fan has power to it but not running, replace it. It should be located behind freezers back wall inside of freezer near top.
Oct 09, 2007 | Refrigerators
Maytag side by side model GS24C8C3EV Refrigerator too warm
it is almost certainly a defrost problem. when fault has occured, remove freezer bzck panel and see if there is ice build-up. if so this confirms a defrost problem - possibly that the element is open circuit
Jun 21, 2007 | Maytag MSD2434GE Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
83 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
