Question about Pleasant Hearth Home
Smoke and soot from my pleasant hearth stove
The baffle seems to be so large it blocks the flow to the chimney. Shifting it front to back seems to make no difference
    Scholar:
  • 43 Answers
Your chimney must be properly installed above the roof line to prevent downdraft. The soot issue may be cause by burning wood that is too green, not dry enough to burn clean.
Safety is a concern when using a wood stove in your house. Be informed about the dangers of Carbon Monoxide Poisoning.
http://carbonmonoxidedetectoralarms.com/
Carbon Monoxide Detectors are mandatory by law in some states. Protect yourself and your family.
Amazon com carbon monoxide detector Electronics
Posted on Jun 14, 2014
How to put the mantel and flue parts back on in the fireplace
Fireplace and Chimney Parts: Diagram and Anatomy
https://www.highschimney.com/.../parts-chimney-anatomy-fireplace-chi...
Nov 30, 2011 - A chimney is made up of up to 22 parts. ... Mantle - Also known asmantel piece or mantel shelf, this piece of hardware is more than a .... I have an old Blaze King Fireplace Insert that was purchased back in the mid 1980's.
How to install a wood burning fireplace insert - Hearth.com
www.hearth.com/econtent/index.php/articles/install_insert
A Heatform is a metal firebox which is built into a full masonry chimney. ... The distance to the adjacent wood trim and the mantle. ... All the way back in the fireplace, or out on the hearth? ... Rockford Chimney Supply - We are the best source forChimney liners and Stainless steel chimney liner kits to install your insert or ...
Dec 20, 2015 | Heating & Cooling
I have a free standing wood burning stove Hearth Stone brand Is there a product that one could wrap the chimney flue with to avoid a small child from burning its hand? Thanks
There is a completely double insulated flue pipe available on the market by SELKIRK and more
INSULATED stove pipe DIY CHIMNEY FLUE - YouTube
? 4:06
https://www.youtube.com/watch?v=D6AHJ_XbOCo
Oct 19, 2011 - Uploaded by ROCKNTV1
CHIMNEY FLUE DOUBLE WALL INSULATEDhttp://www.rockntv1.com/2011/10/insulated-stove-pipe-diy .. And see google for vendors
Nov 29, 2015 | Home
Pleasant Hearth WS-2417-B stove. Why doesn't air control work?
then call the installer back , there has to be a damper in the pipe going out ,
Oct 31, 2015 | Home
Laying stone around a wood stove
I don't know what your question is, but I have seen many hearths made out of stone or brick for the stove to set on. Usually the wall is bricked or stoned as wide as the hearth and up above the flu opening to minimize fire potential from excess heat radiated from the stove.
If the hearth is to be very large, the joists under the hearth/stove may have to be doubled to keep from bowing over the years.
Mar 07, 2015 | Home
Why does my blazeking wood burning stove get creasote in the fire box and how do i get it out?
Hi Darlene,
Creosote consists of combustion byproducts,[smoke] that gradually builds up in the stove & chimney.MOISTURE in the wood,and slow burning greatly increase build-up. 1/4 '' of creosote is considered a hazard. Consult a professional chimney sweep,then burn only 'seasoned' dry hardwood,and when you start or re-kindle the fire,burn it hot enough to thoroughly heat the flue; this will draw the smoke up the chimney faster,decreasing the time build-up can occur. Stay Warm!
Nov 25, 2014 | Home
Auger is not getting power
The auger may be jammed. If you cant wiggle it then it probably is. If not then you have an issue with a sensor....ie an air leak, bad igniter, heat sensor.
Mar 02, 2014 | Pleasant Hearth Ghp Pellet Stove Large...
I'm installing a wood stove insert with a 6" flu. Can I use a 5" or 5.5" chimney liner and be ok? Thanks in advance. Jacob Ullucci
If the stove exhaust pipe is 6", you need to have a minimum of 6" all the way up your chimney. If you use a smaller pipe you will limit your flow, which causes excess cooling and crystalizing of smoke creating more creosote, and more of a chance for chimney fire. The perfect solution would be to run a 6" liner down your chimney, and connect it right to the top of your insert. Make sure you install a top plate at the top of the chimney to insure pieces don't fall outside the liner. Lastly install a stainless steel cap to keep any animals out.
Sep 13, 2013 | Hearth Products Controls Round Match Lit...
Soot produced by propane heating stove
If it is still producing soot two problems blocked burners burning yellow causes soot , or blocked injectors, or pressure to burners is wrong needs seting to correct pressure
Feb 07, 2013 | Heating & Cooling
We do not seem to be getting as much heat from the stove this year as last year. The stove makes a loud clanking sound when it heats up and cools down. It is a regency wood stove Model R3/R9/RA3. There...
That stove has a metal baffle on top of an air tube that can warp with age. It might be changing shape as it heats up and making your sound. If this is the case it can block the path for the stove pipe and cause performance issues. The baffle plate and insulating blanket on top can be easily replaced.
Dec 07, 2010 | Stoves Heating & Cooling
Wood burning heater when putting wood into stove lots of smoke comes into the house when door is opened.
It ain't drafting right or you have the damper closed. Look for obstructions in the smoke stack.
Wood burning tips
  • Burn only wood. No garbage, plastics, rubber, paint or oil, briquettes, paper, etc. Burning these items releases harmful chemicals into the air.
  • Burn Wise Program from EPA: Emphasizes the importance of burning the right wood.
  • Build small, hot fires instead of large, smoldering ones.
  • Don't "bed the fire down" for the night. Holding a fire overnight is a fire hazard and can create serious indoor and outdoor air pollution problems.
  • Open your damper if the smoke is dark. Dark smoke indicates more pollution is being produced and fuel is being wasted.
  • Keep your stove clean and well-maintained. Follow manufacturer guidelines; replace catalytic stove filters every 1-4 years. Have your chimney checked and cleaned at least once a year.
Use seasoned wood The best fuel for woodstoves is dry, "seasoned" wood. Seasoned wood has a moisture content of about 20% or less. It tends to be dark in color, cracked on the ends, light in weight and has bark that is easily broken or peeled. Here are some tips for preparing seasoned wood:
  • Split the wood to help it dry. Wood will dry out more quickly and burn best if the wood is cut to about 3 1/2 inches to 6 inches in diameter.
  • Cover the split firewood to protect it from the weather and stack it loosely in alternating layers, at least 6 inches off the ground.
  • Time must be given to allow the wood to reach 20% or less moisture required for seasoned wood. This process takes approximately 6-12 months. Think ahead and buy next winter's wood well in advance.
It is recommended an annual chimney cleaning to remove creosote build up and to identify potential problems. Things to consider:
  • The Chimney cap may be plugged by debris.
  • Catalytic combustor and baffles are exposed to very high heat and deteriorate as used. Replace every 1-4 years depending on use.
  • Stovepipe angles and bolts are subject to corrosion.
  • Gaskets on airtight stove doors need replacement every few years. Gaskets and seals are used by the appliance designer to control the location and flow of air into the appliance.
  • Check seams on stoves sealed with furnace cement. Seams may leak and cause you to loose valuable heat and reduce the efficiency of the unit.
  • Replace broken or missing firebricks.
  • Keep the floor of your stove clean of debris and ash.
-from the web
Nov 02, 2010 | Heating & Cooling
Home Logo
201 people viewed this question
Top Pleasant Hearth Home Experts
Donni Steen
Tom Chichester
Are you a Pleasant Hearth Home Expert? Answer questions, earn points and help others
