Question about Radio Communications
I am getting a Negitive feed on my positive wire that hooks up to the battery
I am getting a negative feed on my positive cable going to my battery. This all started when I boosted my truck to get it started. Can anyone help me?
  • 396 Answers
Get the alternator checked. You may have damaged the voltage regulator or the diode bridge rectifier. Any parts store (Oriellys) can bench test your alternator. Just unbolt it and take it in.
Posted on Apr 02, 2014
What wires go to my positive and negitive side on my battery on my 03 yamaha r6
Positive wire is red whereas negative can be either black or brown.
Hope this clarifies your doubt.
Aug 14, 2014 | 2003 Yamaha YZF-R6
Battery isolator wiring diagram
The positives are separated by the selector switch.
Therefore negatives (or negative earths) can be commoned and left connected to batteries.
As a circuit needs to complete a closed loop from battery positive through the selected switch contact through the load 'caravan' then back to negative, the unselected negatives don't do anything.
So, YES WE CAN. :)
Hope this helps.
Clive.
Nov 18, 2017 | Office Equipment & Supplies
The battery has tested fine, the alternator is fine. But it won't start or hold a charge.
REPLACE POSITIVE BATTERY CABLE.CHECK ALTERNATOR FUSE AND CHECK ALTERNATOR VOLTAGE REGULATOR WIRES FOR DAMAGE.HOOK VOLT METER TO BATTERY FEED WIRE MAKE SURE 12 VOLTS GETTING TO ALTERNATOR FEED WIRE TO ALTERNATOR POSITIVE HOOK UP IF NOT YOU HAVE BLOWED FUSE TO WIRE FEEDING ALTERNATOR COULD HAVE FAULTY BATTERY POSITIVE CABLE OR CABLES CORRODED NEED CLEANING.
Aug 27, 2011 | 2005 Ford Ranger
Which battery cable is positive/negitive.
the one with the red connector, is positive, the one with black is negative..Another way to find out
is , you follow the wire.. the one connected to the engine block is negative.. the one going straight to the starter is positive...
Dec 28, 2010 | 1998 Mazda Protege
What wires need to be hooked up to the positive wire and which ones for negitive
Red = positive to battery
Black = negative/ground to body
solid colored wires - positive speaker
while lined wires = negative speaker
Yellow = starter switch
Jun 06, 2010 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Is the black wire negitive and white wire postive
The Black wire is the Hot or positive wire and the White wire is the nuetral or negative wire.
The green wire gets hooked to the frame or any metal part of the dishwasher...usually there is a green screw inside the little box where the wires hook up
Heatman101
Apr 15, 2010 | Bosch SHU9925UC Built-in Dishwasher
Battery wiring
Series or paralell?. Should be parallel so you get 12 v0lts. two positives together and two negatives together
Sep 26, 2009 | 2001 Toyota Land Cruiser
I need help installing a 4 Channel Power Acoustik Amplifier to Two Pioneer Subwoofers. I hooked up the power wire to the positive battery terminal in the engine compartment. I then cut the power wire and...
You are doing right on what you described. I really like to work with a clearly described what involved in an issue.
Now we have to use a Voltmeter to check if there is power to the amplifier. If there is power to the amplifier terminal, then the problem is at the amplifier, not the connection. Let check it out:
1- Turn on your Kenwood radio, make sure to hear sound from your regular speakers.
2- Turn remote control knob to the mid level between min and max.
3- Measure the blue wire where you spliced to ground to see if you have 12V, if it is not then the problem is right there.
4- Measure the Red wire power from the Amplifier to ground ( the bolt that you connect the negative power to see if there is 12V, if not trace back to the Fuse that you inserted between the positive terminal of the battery and the wire going through the firewall to correct it.
5- If you have 12V at step 3 and 4, then you have a defect unit, return it to the manufacturer for a replacement.
Sep 06, 2009 | Car Audio & Video
How do i put a battery back in the hood of a 2000 cadillac catera
hook the positive cable up first,,,then the negitive
Apr 18, 2009 | 2000 Cadillac Catera
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
