Question about Bosch Ovens
Bosch oven hbl 546
Trying to locate a replacement knob for this wall oven
    Problem Solver:
  • 12 Answers
Here is one place to try http://www.appliancepartspros.com/ You can also contact a used appliance store a lot of them do Appliance repair and may even have one in the back.
Posted on Mar 23, 2014
  • 491 Answers
SOURCE: Door Hinges for Bosch oven HBL 545
CONTACT BOSCH FOR INFORMATION
Posted on Jul 18, 2009
  • 36 Answers
SOURCE: Bosch oven won't pre-heat/heat with door closed
hi ,
according to me ,there is some issue with the cables that are connected the heat functionality of oven , because the same happned with my lg microwave , then the tech checked it , it was a cable fault , one of the cable was loose when the door was fully closed microwave was not working but when we leave some space while closing it it was working , so it is recomended if your oven is in warranty the call the company technicans to fix it , plase dont try if dont have expertis on it take help of tech who knows about microwave
Posted on May 24, 2008
SOURCE: Bosch HBL 645 Convection Oven -- No Heat
first out put voltages measures,when output voltages ok , then see the control circuit.after tnat every thing ok. replace heating elements.
Posted on Dec 11, 2007
SOURCE: Bosch Oven Door Problem - doesn't close at top
On our oven (Bosch Evolution 700 Series HGS7152UC), the problem was getting worse and worse. I found it is was worsening simply because the hinges had started to come loose. I removed the door as suggested above, and although there are no adjustment screws on this model I tightened the now-loose hinge mounting screws. For each hinge there are three screws altogether: two (phillips heads) on the bottom of the door and one (torx head) on the inside wall of the door. After tightening those screws it is a lot better, only leaks as much heat as it did when it was new which is tolerable. Still a bad design.
Posted on Dec 09, 2009
barkencoa
  • 3463 Answers
SOURCE: Bosch HBL 645 oven door won't close all the way
I am afraid that the door hinges are non adjustable, and the only solution is to replace them as a pair.
There should be some kind of latch mechanism at the end of the hinge
where it is fastened to the door to compress the hinge to enable you to remove them.
Hope this helps.
Posted on Jan 04, 2010
How do adjust the clock to daylight saving?
Touch TIME then the display will begin flashing timer
Use rotary knob to change this to CLOCK
Touch TIME again and it will say ENTER TIME with the time flashing
Use the rotary knob to change the time as required
Touch START and the time is now changed
Page 12 if you need it
Bosch HBL745AUC Use and Care Manual
Oct 07, 2014 | Bosch HBL 745 Stainless Steel Electric...
I need to download a manual for this product. Where can i find it?
I found a users manual for Bosch wall ovens at Retrevo.com
http://www.retrevo.com/s/Bosch-HBL755AUC-Ovens-review-manual/id/925ci470/t/1-2/
Feb 12, 2011 | Bosch HBL 755 Stainless Steel Electric...
Do the knobs on bosch ovens retract when the oven is in use
Hello, Most of the temp. & select knobs do extend out, but not automatically. If you push the knob inward and release, they should individually "pop" extend out to allow them easier to function. As I indicated this is how most modern bosch work, with the acception of some models. Please provide your actual model number if you require further help. Hope that answer's you question, let me know if I can assist you further. Good luck, please rate this solution accordingly and thanks for coming to "fixya". Macmarkus :)
Apr 01, 2010 | Bosch HBL 5032 Electric Single Oven
Can i replace the oven light myself on the double wall oven,hbm43b550a ?
Yes your owners manual will show how.Replace the bulb with a similar bulb{ heat resistive}
Sep 28, 2009 | Bosch HBL 755 Stainless Steel Electric...
Mar 02, 2009 | Bosch HBL 742 / HBL 746 Electric Single...
Wall oven error code
Having the same problem.
Has anyone found a solution to this problem?
Thank you
David
m5beemer(at)gmail.com
Sep 03, 2008 | Bosch HBL 745 Stainless Steel Electric...
Ovens Logo
59 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
