Question about TruTech PVS31170S1W 17 in. LCD Television
I have green pixels going through my screen where dark/black color should be. It's a Sharp Aquos and only a 1 1/2 yrs old. Is this common? How do I fix it?
    Guru:
  • 161 Answers
You could try the fixes at this site, but no guarantees
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Posted on Jan 15, 2010
Green screen upon shutting down or green color replacing black .. Fuzzy green on some dark scenes.. Sharp Aquos LCD TV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 29, 2015 | Sharp Televison & Video
My flat screen hd sharp aquos color turns green when we are watching it. it is only 3 three years old. what can this be? thanks
I'm not sure if this is the same, but people were green no matter how i adjusted the tint, and lacked overall color. I doubled checked the component cables, taking each one out, and putting it back firmly,
Picture is back to normal. Easy fix.
Feb 10, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Large red bar lower half of tv sharp aquos 52" 2.5 yrs old
some parts inside your tv is damage or short circuited. too expensive to fix or replace
Sep 08, 2009 | Sharp Televison & Video
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
Apr 26, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Green vertical line on the right side of screen
Warranty still alive?
Hope so; the problem could be an expensive one.
The screen appearance is controlled by allowing light from a backlight through by turning pixels off and on.
This switching is done by a matrix that turns on vertical and horizontal pixels of the right shade at the right time to produce the image you see.
One of the control elements for the vertical that controls the transmission of green light from the backlight, has died (no longer switching off and on when told) and these are normally a part of the LCD screen assembly itself and not easily replaceable.
I would be talking to Sharp - this shouldn't happen in 6-7 months of use.
Jul 09, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Toshiba regza lcd 46x3500
This is what is known as a dead pixel. If you have a standard wide screen lcd monitor it has over 1 million pixels. It is not super un-common for one to go bad. It will either always be dark or in your case always be lit. It is not worth it to repair, and in most cases unless you have multiple dead pixels with in a square inch of screen, it is not covered under warranty either.
Each pixel is individual and the problem will most likely not spread.
Jul 08, 2008 | Televison & Video
SHARP aquos 1080p HDTV: VCR image flickers when playback
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
Jun 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
** picture - solid green power light - relay clicks
yes,the set has a main video processor board bad.Sharp is well aware of this problem,and with persistence sharp will give in.
Mar 10, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TruTech PVS31170S1W 17 in. LCD Television Logo
215 people viewed this question
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
