Question about Samsung BD-EM57 Smart Wi-Fi Blu-ray Player
Can not connect to wireless network
Can not connect to a wireless network
    Problem Solver:
  • 12 Answers
If the signal strength is low, consider using a simple wi-fi repeater, or relocating the wi-fi router so it is closer to the Player
Posted on Apr 05, 2014
Hi i am using the pc sony vaio i have the problem on wireless adabter it was in desable mode and difficutl to active it ,while i am useing the bottom in front of pc on and off of wirless adabtor but i i on...
In Vista, you can either go to control panel, device manager and right click on it and click "eneble"
or go to control panel > network sharing and set up wireless network connection
or
go to task manager (press and hold ctrl . alt . delete for a couple of seconds), until task manager comes up. Then click on the services tab, scroll down till you see "Plug Play or Plug and Play and make sure it's running. If it's not, right click on it then click "enable"
In XP
Open Network Connections
Right-click Wireless Network Connection, and then click Properties.
On the Wireless Networks tab, do one of the following: •
To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
To connect to an existing wireless network, do one of the following:
Access point (infrastructure)
To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
In Wireless Network Properties, specify the wireless network key (Wired Equivalent Privacy) settings, or, if the network key is automatically provided for you (for example, the key is stored on the wireless network adapter given to you by your administrator), select the The key is provided for me automatically check box. If you are unsure about whether a network key is needed or which settings you need to enter, contact your network administrator or the wireless network adapter manufacturer.
Important
If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
Computer-to-computer (ad hoc)
To connect to an existing computer-to-computer (ad hoc) network, under Available networks, click the network name, and then click Configure.
If you want to connect to a computer-to-computer (ad hoc) network and both computer-to-computer and access point (infrastructure) networks are within range of your computer, click Advanced, and then click Computer-to-computer (ad hoc) networks only.
To configure a new wireless network connection, click Add, and then do the following: •
If the network connection that you are configuring is to a computer-to-computer (ad hoc) network, select the This is a computer-to-computer (ad hoc) network; wireless access points are not used check box.
To change the order in which connection attempts to preferred networks are made, under Preferred networks, click the wireless network that you want to move to a new position on the list, and then click Move up or Move down.
To change the wireless network connection settings for a network that is listed in Preferred networks, click the wireless network for which you want to change settings, click Properties, and then change the settings as needed.
To remove a wireless network from the list of preferred networks, under Preferred networks, click the wireless network that you want to remove, and then click Remove.
To update the list of available networks that are within range of your computer, click Refresh.
To automatically connect to available networks that do not appear in the Preferred networks list, click Advanced, and then select the Automatically connect to non-preferred networks check box.
To open Network Connections, click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.
When you enable automatic wireless network configuration, you can connect to an existing wireless network, change wireless network connection settings, configure a new wireless network connection, and specify preferred wireless networks. You will be notified when new wireless networks are available. After you select a wireless network, your wireless network adapter will be automatically configured to match the settings of that network, and a network connection attempt will be made.
To configure settings on the Wireless Networks tab, you must be logged on as an administrator, and you must use a wireless network adapter that supports the Wireless Zero Configuration service. If you are unsure whether your wireless network adapter supports the Wireless Zero Configuration service, contact your network administrator or the wireless network adapter manufacturer. For more information about automatic wireless network configuration, see Related Topics.
If you are using third-party wireless networking software, clear the Use Windows to configure my wireless network settings check box.
If you are unable to connect to an existing wireless network and the name of the network that you want to connect to appears under the Preferred networks list, click the preferred network name, and then click Properties. In Wireless Network Properties, review the settings to ensure that they are correct. If you are unsure whether the settings are correct, contact your network administrator or the wireless network adapter manufacturer.
If the Preferred networks list includes both access point (infrastructure) and computer-to-computer (ad hoc) networks, you cannot move a computer-to-computer network to a position in the list that is higher than the position of an access point network.
To provide enhanced security for 802.11 wireless networks and for wired Ethernet networks, IEEE 802.1x authentication is enabled by default. For more information about how to set up 802.1x authentication.
Hope this helps
Dec 12, 2010 | HP Broadcom NetXtreme Network Adapter
Tip
How to connect your wireless computer to the wireless network ?
Connecting your wireless computer to the wireless network:
Make sure the wireless switch is turned on in the laptop, now look for the available wireless Networks in range, select your network name, enter the security key and get connected. You may also follow the navigation below according to your Operating System
WINDOWS XP: Start > Control Panel > Network and Internet Connections(Network connections) > Right Click Wireless Network Connection icon > Click on View Available Wireless Network
WINDOWS VISTA: Start > Control Panel > Network and Internet (Network and Sharing Center) > On your left hand side click on Manage Network connections > Right Click on Wireless Network Connection icon > Click on Connect/disconnect
WINDOWS 7: Start > Control Panel > Network and Internet (Network and Sharing Center) > On your left hand side Click on Change Adapter Settings > Right Click on Wireless Network Connection icon > Click on Connect/disconnect
MAC OSX: Select airport icon from desktop, turn on Airport, you will be able to view the available networks in range. Select your network name enter key and get connected.
You may also click on Apple logo > System preferences > Airport > select network name
You will be able to see the Network name (SSID) which you gave in the Router, try to connect to this it will ask for password type it and click on Connect. You will get connected wirelessly and able to go online.
on May 19, 2010 | Computers & Internet
Tip
Configure Wireless Zero Configuration to configure wireless connection on XP...
Configure Wireless Zero Configuration to connect to wireless network on your wireless XP computer.
Below mentioned steps will help enable Wireless Zero Configuration on your XP computer and achieve wireless connectivity. These steps applies to your XP wireless computer (Desktops and laptops) with external or built in wireless cards.
Please perform the following steps on your wireless computer to enable WZC (Wireless Zero Configuration):
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
7. Highlight the SSID from the list that you want to connect to.
8. Type the security Key here and click on the 'Connect' button. You should have successfully established a wireless network connection.
The above steps will help you in the configuration of wireless connectivity if you are not aware about the settings of wireless connection utility installed on the computer.
on Mar 18, 2010 | Computers & Internet
I have a new toshiba laptop that I can't get to connect w/o wires to my lynksys...how do I get my laptop to be wireless??
In order for the wireless computer to connect to the router wirelessly, the router and the computer's wireless settings should be the same. Before trying to connect your wireless adapter to a Linksys wireless router, please know the following: SSID or Network Name, Wireless Security and/or Network Key.
Connecting to Wireless Networks Using XP's Wireless Zero Configuration
To connect to the wireless network using Windows Vista, click here.
Follow these steps to connect to your wireless network using XP's Wireless Zero Configuration.
Step 1: Right-click the Wireless Network Connection icon at the bottom-right of the screen and select View Available Wireless Networks.
NOTE: If Wireless Zero Configuration (WZC) is disabled or other wireless network monitor is running, the Wireless Network Connection will not appear at the bottom-right corner. To enable WZC on the computer, contact Microsoft or consult the computer manufacturer.
Step 2:
Select your wireless network
Nov 05, 2010 | Computers & Internet
Can not connect to network
Connecting to a Wireless Network Using Linksys Wireless Manager Article ID: 17673
Follow these instructions to connect to a wireless network using the Linksys Wireless Manager.
Step 1:
Launch the Linksys Wireless Manager. To learn how to access the Linksys Wireless Manager, click here.
Step 2:
In the Connect to a Wireless Network screen, locate the name of your wireless network in the list.
NOTE: If your wireless network is not in the list, click here to learn How to Connect to a Hidden Wireless Network. If your wireless network supports Wi-Fi Protected Setup kb17673-005_en.png, click here to learn How to Connect Using Wi-Fi Protected Setup.
Step 3:
Select your network. Then click Connect.
Step 4:
If the wireless network uses wireless security, enter the security key or network. Then click Next.
Step 5:
The Checking Connection screen appears while the Wireless Manager establishes the wireless connection. When it is finished, click Next to continue.
Step 6:
The Connected to Your Network screen appears. If you want the Wireless Manager to remember your network settings select Remember this network. Click Finish to exit the Wireless Manager.
NOTE: Saving a network's settings will make it easier to reconnect to the network.
Nov 04, 2010 | Linksys WRT160N Wireless Router
Having trouble with initial connection to an existing wireless network wireless router is a cisco wireless-n broadband router and we have 2 laptops and a printer on a wirelss network already
Step 1:
Step 2:
Step 3:
Nov 01, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Cant get wireless router to work on laptop
First, try to connect your laptop hardwired to the router, if it works fine, its just the wireless configuration. Make sure you are using the correct wireless network key to connect to your wireless network. Go to the Control Panel > Network Connections > Right-click Wireless Network Connection > Properties > Wireless Networks Tab and delete all the names listed under Preferred Networks box. Click Ok. Right-click on Wireless Network Connection again > View Available Wireless Network > Choose your own network and click Connect. If it asks you to type the network key, type in your WEP or Wireless Network Key and press connect. That should do it.
Oct 06, 2009 | Computers & Internet
Unable to activate wireless lan
TRY GOING TO START, START SEARCH TYPE WIRELSS DEVICE
LOOKE IN DEVICE MANAGE FOR WIRELESS FOLDER
INPUT DEVICES
AS SO CHECK THE FOLLOWING FOLDERS ALLOWING COMMUNICATION BETWEEN THE LABTOP AND THE WIRELESS DEVICE AND THE COMPUTER.
NETWORKING AND SHARING FOLDER
PROBLEMS AND REPORTING
SECURITY FOLDER
SYNC CENTER IF YOU HAVE ONE
WINDOWS DEFENDER
WINDOWS FIREWALL
THE LAST 2 PROGRAMS IN THE LIST ABOVE CAN STOP THE DEVICE FROM WORKING.
YOU WANT MORE HELP I WILL HELP YOU IF YOU HAVE THE SITE CONTACT RODGANDYSR@GMAIL
ROD
May 12, 2009 | IBM TP R51 - P M715 1.5GHZ 256MB 40GB...
I can't get it to work.
To view the wireless network connection dialog box, follow these steps:
  1. Click Start, Run, and type ncpa.cpl, and then click Ok.
  2. Right-click the Wireless Network Connection icon, and then choose Properties. (Or you can right click the Wireless Network Connection icon and choose View Available Wireless Networks from the shortcut menu.)
  3. Click the Wireless Networks tab.
  4. Under Available networks, click the View Wireless Networks button.
From the wireless network dialog box, you can refresh the network list. This performs another scan of wireless networks within range. The wireless network connection dialog displays the following for each detected network. The following shows the new connection box.
When the wireless network adapter displays the detected networks, you'll able to select a wireless network name and attempt to connect to it. The antenna icon indicates an infrastructure mode wireless network. The icon that shows two wireless client computers indicates an ad hoc wireless connection.
The lock icon and the "Security-enabled wireless network" label indicate that the wireless network has security enabled. The gold lock means you need a network key in order for you to connect to a wireless network. If it's not security enabled, you'll be able to connect to the network without a network key.
Apr 28, 2009 | Airlink AWLH3026T 802.11g/b Wireless...
Can't connect to netwoork
Just configure the wireless settings your laptop. Go to Network Connections > Right-click on Wireless Network > Properties. Go to Wireless Network tab and look for Preferred Networks. Just remove all of them and click OK.
Now, On the Network Connections, right-click on Wireless Network Connection > View Available Wireless Networks. Connect to your own wireless network and enter your wireless network key if it tells you to type it. That should fix your wireless connection. Now if your wireless network is not showing, you need to change the wireless channel of your router by accessing the router's setup page using your wired computer.
Apr 18, 2009 | NetGear WGR614 Wireless Router
Samsung BD-EM57 Smart Wi-Fi Blu-ray Player Logo
104 people viewed this question
Henry  Thomas
Henry Thomas
