Question about Mitsubishi WD-82837 82 in. HDTV DLP TV
How to replace power supply board on wd-82837
Tv comes on and goes off
    Scholar:
  • 195 Answers
How do you know it needs one ? That sounds more like a lamp, color wheel or DM module issue (if set uses one.)
Posted on May 08, 2014
  • 1779 Answers
SOURCE: Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Posted on Feb 14, 2009
Slinteriors
  • 8617 Answers
SOURCE: lite doesn't work need to put repair kit for
You can get the V26 Power board repair kit at the following link the kit contains step by step instructions with pictures.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Posted on Jun 10, 2009
  • 115 Answers
SOURCE: Unit was on and I heard a loud pop like a fuse
Did you check the lamp?
Posted on Oct 05, 2009
  • 8457 Answers
SOURCE: Mitsubishi wd-62725. 8 power supply caps replaced
Replaced the FBT,that help the power too.
Posted on Jan 07, 2010
  • 8457 Answers
SOURCE: i have a mitsubishi
Ur tv"LAMP"LED light indication flashes or stay on?Ur tv projection lamp been inside this tv like a 1 1/2 or 2 years and tv been on an in used like 4 or 5 hours every day.Yes to all of this,than the tv projection lamp is the causes and it life are ending.The tv projection lamp require replacing.
Posted on Dec 09, 2010
Mitsubishi WD-82837 pop noise and no power
Sounds like your bulb blew. Here is a link to a very good priced replacement bulb with housing . These are very simple to change yourself. http://www.projectorlampsworld.com/projector-manual/mitsubishi-wd-82837.html
also, here is a link to a video showing how easy it is. They are made to be replaced by the consumer.
How to replace the lamp in your Mitsubishi TV: http://youtu.be/_ONPuB5L-x4
Note, your bulb assembly may vary slightly from the one in the video, but it should come out and go in the same way.
You will need a plastic grocery bag or small garbage bag, some rubber, or latex, or clean cloth gloves, and a medium phillips screwdriver.
May 04, 2014 | Mitsubishi WD-82837 82 in. HDTV DLP TV
Wd-82837 status light blinking tv tries to turn on blue sreen comes on then tv shuts off.
My status light is flashing and I cannot get an indication that the TV is actually on. There is no sound. I cannot get any display whatsoever. The blue light across the bottom is not on. Thus, the TV is probably on in the 1st place. Ideas?
Sep 22, 2012 | Mitsubishi WD-82837 82 in. HDTV DLP TV
What is causing the lamp to keep going out on an 82" 837 Mitsubishi TV?
If a OEM Mitsubishi lamp was used you likely have a problem with the Ballast that drives or powers the lamp---the two pin socket for the lamp goes directly to the Ballast.
May 30, 2012 | Mitsubishi WD-82837 82 in. HDTV DLP TV
I have a mitsubishi the model number is wd-82837 it keep shut down after blue screen show
Dec 09, 2010 | Mitsubishi WD-82837 82 in. HDTV DLP TV
I have a mitsubishi wd 57734 tv. when trying to turn the tv on, the green light is displayed at the bottom of tv. You can hear the tv trying to boot up, but it never comes on. After 3 tries the tv just...
The power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem.......
Oct 16, 2010 | Mitsubishi WD-57734 57" HDTV
Tv will not come on
Ur tv the power supply board is dead.Take the tv aparts,the board where the a/c power cord plug into it.That the power supply board,replaced it,ur power problems will be solved.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jun 17, 2010 | Dynex DX-LCD37 TV
My tv wont trun on, push power, the grenn light flashes and then goes off
If the whole TV system goes off, there is a possibility that there might be a glitch with the Power Supply Board. And I mean a glitch, because the green light comes up flashing.
Nov 18, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-82837 82 in. HDTV DLP TV Logo
88 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
