Question about Nintendo Wii Console
There is no power to the Wii console
I have tried plugging it in to a known working outlet and still no power. We had a power outage and hasn't worked since. It was working fine the night before. The hand controllers are blinking as is the fit board.
Please advise.
  • 27 Answers
Unplug all cords to the wii, also unplug the adapter from the plug let stand for 5 mins to reset.
Posted on Jun 14, 2009
  • 104 Answers
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqwtr-75
Posted on Jul 22, 2009
  • 31 Answers
I have had this problem b4 and all i did wus unplugged my wii . . came bak to it in like an hour . . . and then took it to a different room . . and plugged it in to a outlet u r sure is working and see if ur wii light has turned on . . . . and if u have internet on it make sure to get an update if not . . well idk wut to say . . but the point is try a different outlet and if it dont work ... go to a game crazy or sumin and buy a new power cord
i hope i helped1!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
-eli
Posted on Jun 16, 2009
Our wii is about 6 years old. It was working fine yesterday, today it doesnt even act likes it's getting power. No lights come on. Reset doesn't work, switched outlets...nothing happening.
Wii console's are known to over-heat. Try letting it cool down for a day with no power cables plugged in. Try and turn it on the next day, and if it doesn't work, my best guess is that it over-heated to the point of giving up. And when you plug it back in, blow in all the ports and cables just to be safe. If none of this works, it is either broken or needs more expertise than I can give.
Aug 17, 2014 | Nintendo Wii Console
My wii went off after a thunderstorm and doesn't get on anymore, can I do something to fix it? I've already changed the battery inside but nothing cheanged.
First make sure the circuit is live - Are there other things on that circuit? Do they work? If not, check that the breaker hasn't tripped, and reset it if necessary. Next, check that that specific outlet wasn't damaged. Plug something else into it. Does it work? If not, the outlet needs to be replaced. Also plug the Wii into another outlet. If it works, this also confirms the original outlet has been damaged. If the Wii still doesn't power on, the power supply has probably been damaged. Unless you can replace it yourself, it probably isn't worth having it repaired.
Apr 21, 2012 | Nintendo Wii Console
When i try to turn my Wii on it will not come on there are no lights or anything how do i fix this problem
This happens if you have had a power outage. Here's what you should do:
  1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
  2. The AC adapter must remain unplugged at both ends for a full 2 minutes.
  3. Unplug anything connected to the USB ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
  4. After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
Hope that works for you.
May 21, 2011 | Nintendo Wii Console
We had a power outage and no longer have power to our Wii game. We unplugged everything, waited and plugged everything back in. Still doesn't work. I know this work from some people, but, unfortunately...
This is most likely not an issue with the Wii. Try using it in a different outlet and a different TV. Most likely your circuit breaker needs a fuse to be reset. Check it out and see if there are any switches the do not face the same direction as the rest.
Apr 29, 2011 | Nintendo Wii Console
We had a power outage last night, and even though the adapter was plugged in through a surge protector, the console will no longer turn on, acts as if it is not getting any power. I have tried multiple...
Try using a friend's power adapter just in case yours got fried. If you don't know anyone that has a wii you can buy new adapters at stores like Gamestop for I think $20. If it doesn't work they have a policy now where you can return them even if they're opened within 7 days. If a new adapter doesn't work then your wii may be fried. Try calling Nintendo and see if they can do a repair for a cost, or if you are still under warranty and if they'll cover you.
Mar 31, 2010 | Nintendo Wii Console
My wii is plugged in and has been for awhile. recently i was trying to solve an electrical problem at home which involved switching breakers on and off several times which also involved the circuit in...
First I would try plugging in the Wii at another outlet. If that doesn't work I would try borrowing a friend's power cable for the Wii that is known to work (or buy a replacement) and see if that fixes it. If not, hope that you still have a warranty on it or you are out of luck.
Oct 17, 2009 | Nintendo Wii Console
The wii wont turn on
Try plugging the Wii into a known working outlet.
If that doesn't fix the problem, then try another known working AC Adapter if you can.
If you do these two steps and the wii doesn't turn on then the main board is bad and if your Wii is under warranty then contact Nintendo to have it repaired otherwise replace the system.
Aug 16, 2009 | Nintendo Wii Console
Won't work after power out
Just had the same issue after a brief power outage. Following the advice on this board, I simply unhooked the power cord to both the Wii and the outlet, waited a good 10 mins and hooked the cord back up - first to the outlet then to the Wii. Presto! Power light is back on.
Jun 19, 2009 | Nintendo Wii Console
Power Outage & Now Wii Won't Power Up...
When this same thing happened to me, I unplugged the Wii power supply from the wall (not just from the back of the Wii) and let it sit unplugged for about 10 minutes. When I plugged it back in, everything was fine.
Nov 11, 2008 | Nintendo Wii Console
Wii completely stops working after power outage
I just had the same problem as everyone else. I had a brief power loss and our new Wii system's power would no longer work. To fix the problem, I unplugged everything from our Wii and unplugged the power cord from the outlet. I let the system set for 10 minutes and re-plugged the power only. That did the trick. Then I was able to plug everything back up and we are now back to playing.
Supposedly, doing the steps above resets the Wii according to the Nintendo online trouble shooting guide.
Sep 28, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
372 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
