Turntable crosley cruiser fuse
Fuse
I need a fuse panel diagram for 2011 vw jetta tdi. My radio and rear defrost are not working.
Fuse panel C (dashboard)
Volkswagen Passat B7 - fuse box - dashboard Number Designation in Wiring Diagram Ampere rating [A] Function/component Terminal F1 Fuse 1 on fuse panel C -SC1- 7,5 Headlight DRLs, HID Adjuster motors, Whistler Radar Detector 15a F2 Fuse 2 on fuse panel C -SC2- 15 Airbag control module -J234-, Front passenger airbag -disabled- indicator lamp -K145- 15a F3 Fuse 3 on fuse panel C -SC3- 7,5 Light switch -E1- (T10h/4), Oil level thermal sensor -G266- (T6z/4), ABS control module -J104- (47/8), Instrument cluster control module -J285- (T32/31), Power steering control module -J500- (T6z/1) Data, Engine control module -J623- (T94/87), DSG transmission Mechatronic -J743- (T20e/13), Starter relay 1 -J906- (T7/1), Starter relay 2 -J907- (T9c/1) 15a F4 Fuse 4 on fuse panel C -SC4 7,5 Back-up lamp switch -F4-, High pressure sensor -G65-, Air quality sensor -G238-, Garage door opener control module -J530-, Parallel parking assistance control module -J791-, 16-pin connector -T16- (diagnostic connector), Automatic dimming interior rearview mirror -Y7 -, Left washer nozzle heater -Z20-, Right washer nozzle heater -Z21- 15a F5 Fuse 5 on fuse panel C -SC5- - Not used F6 Fuse 6 on fuse panel C -SC6- - Not used F7 Fuse 7 on fuse panel C -SC7- - Not used F8 Fuse 8 on fuse panel C -SC8- - Not used F9 - Fuse 9 on fuse panel C -SC9- - Not used F10 Fuse 10 on fuse panel C -SC10- - Not used F11 Fuse 11 on fuse panel C -SC11- - Not used F12 Fuse 12 on fuse panel C -SC12- 10 Light switch -E1- (T10h/8), Tiptronic switch -F189, Vehicle electrical system control module -J519- (T52c/1), Selector lever sensor system control module -J587, Electronic steering column lock control module -J764, 16-pin connector -T16- diagnostic connector (T16/16) 30a F13 Fuse 13 on fuse panel C -SC13- 10 Instrument cluster control module -J285- (T32/32) 30a F14 Fuse 4 on fuse panel C -SC14- - Not used F15 Fuse 15 on fuse panel C -SC15- 5 Electronic steering column lock control module -J764- 30a F16 Fuse 16 on fuse panel C -SC16- 5 Data bus on board diagnostic interface -J533- (T20/1) 30a F17 Fuse 17 on fuse panel C -SC17- 10 Steering column electronics control module -J527- (T16l/1) 30a F18 Fuse 18 on fuse panel C -SC18- - Not used F19 Fuse 19 on fuse panel C -SC19- - Not used F20 Fuse 20 on fuse panel C -SC20- - Not used F21 Fuse 21 on fuse panel C -SC21- - Not used F22 Fuse 22 on fuse panel C -SC22- 30 28-pin connector -T28a/22- (right A-pillar), 28-pin connector -T28a/22- (right B-pillar) 30a F23 Fuse 23 on fuse panel C -SC23- 30 Rear window defogger relay -J9-, Rear window defogger -Z1- 30a F24 Fuse 24 on fuse panel C -SC24- 20 Fuel pump relay -J17-, Fuel pump control module -J538- (T10n/1), Transfer fuel pump -G6- 30a F25 Fuse 25 on fuse panel C -SC25- 20 Climatronic control unit -J255- A/C control module -J301- Automatic transmission control module -J217- F26 Fuse 26 on fuse panel C -SC26- 15 Rear lid remote lock key switch -E232-, Compass magnetic field sensor -G197-, Rain/light recognition sensor -G397-, Remote start system relay -J471-, Analog clock -Y F27 Fuse 27 on fuse panel C -SC27 - Not used F28 Fuse 28 on fuse panel C -SC28- 30 Automatic transmission control module -J217- 15a F29 Fuse 29 on fuse panel C -SC29- 20 Vehicle electrical system control module -J519- (T52b/1) 30a F30 Fuse 30 on fuse panel C -SC30- 20 Vehicle electrical system control module -J519- (T52b/42) 30a F31 Fuse 31 on fuse panel C -SC31- 30 28-pin connector -T28/22- (left A-pillar), 28-pin connector -T28b/22- (left B-pillar) 30a F32 Fuse 32 on fuse panel C -SC32- 40 Trunk 12 V Plug [OEM-Fresh air blower control module -J126-], Fresh air blower -V2- 30a F33 Fuse 33 on fuse panel C -SC33- 30 Front seat heating control module -J774- (T8z/3, T8z/6) 30a F34 Fuse 34 on fuse panel C -SC34- 20 Power sunroof control module -J245-, (T16s/1) Sunroof motor -V1- 30a F35 Fuse 35 on fuse panel C -SC35- 30 Driver seat lumbar support adjustment switch -E176-, Front passenger seat lumbar support adjustment switch -E177-, Driver seat lumbar support curvature adjustment motor -V125-, Front passenger seat lumbar support curvature adjustment motor -V126- 30a F36 Fuse 36 on fuse panel C -SC36 - Not used F37 Fuse 37 on fuse panel C -SC37- - Not used F38 Fuse 38 on fuse panel C -SC38- - Not used F39 Fuse 39 on fuse panel C -SC39- - Not used F40 Fuse 40 on fuse panel C -SC40- 40 400W Inverter in Trunk [OEM- A/C control module -J301-], Fresh air blower -V2- 75a F41 Fuse 41 on fuse panel C -SC41- - Not used F42 Fuse 42 on fuse panel C -SC42- 30 Cigarette lighter -U1-12 V socket 2 -U18 75a F43 Fuse 43 on fuse panel C -SC43- - Not used F44 Fuse 44 on fuse panel C -SC44- - Not used Fuse 44 on fuse panel C -SC44- F45 Fuse 45 on fuse panel C -SC45- - Not used F46 Fuse 46 on fuse panel C -SC46- - Not used F47 - Fuse 47 on fuse panel C -SC47- - Not used F48 Fuse 48 on fuse panel C -SC48- - Not used F49 - Fuse 49 on fuse panel C -SC49- - Not used
Fuse panel E (VR6 only)
Panel E is the one in the trunk with your battery on the VR6.
Number Designation in Wiring Diagram Ampere rating [A] Function/Component Terminal F1 -Fuse panel B -SB1- - Not used F2 -Fuse 2 on fuse panel B -SB2- 15 -Engine control module -J623- 87a F3 -Fuse 3 on fuse panel B -SB3- 30 -Reducing agent reservoir sensor -G697- 2, Reducing agent reservoir processing unit, G698- 2 Coolant fan control module -J293-, Wastegate bypass regulator valve -N75-, Positive crankcase ventilation heating element -, N79-Reducing agent reversing valve -N473- 2 87a F4 -Fuse 4 on fuse panel B -SB4- 15 -NOx sensor -G295-2 Oxygen sensor 1 before catalytic converter -GX10-Oxygen sensor 2 before catalytic converter -GX11- 1 Oxygen sensor heater -Z19-Oxygen sensor 2 heater -Z28-1 NOx sensor control module 2 -J881- 2 87a F5 -Fuse 5 on fuse panel B -SB5- 5 -Mass air flow sensor -G70-2 Oxygen sensor 1 after catalytic converter -GX7-Oxygen sensor 2 after catalytic converter -GX8-1 Heater for oxygen sensor 1 after catalytic converter -Z29-Heater for oxygen sensor 2 after catalytic converter -Z30- 1 87a F6 -Fuse 6 on fuse panel B -SB6- 10 -EVAP canister purge regulator valve 1 -N80- 1 Secondary air injection solenoid valve - N112- 3 Camshaft adjustment valve 1 -N205-1 Fuel pressure regulator valve -N276- 1 Exhaust camshaft adjustment valve 1 -N318-1 Fuel pump relay -J17-3 Secondary air pump 87a F7 F7 -Fuse 7 on fuse panel B -SB7- 20 -Ignition coil 1 with power output stage -N70-Ignition coil 2 with power output stage - N127-Ignition coil 3 with power output stage -N291-Ignition coil 4 with power output stage -N292-Ignition coil 5 with power output stage -N323- 1 Ignition coil 6 with p 87a F8 F8 -Fuse 8 on fuse panel B -SB8- 10 -EVAP canister purge regulator valve 1 -N80- 1 Camshaft adjustment valve 1 -N205-1 Exhaust camshaft adjustment valve 1 -N318-1 Reducing agent heater control module - J891- 2 Leak detection pump -V144- 1 87a F9 F9 -Fuse 9 on fuse panel B -SB9- 5 -Brake lamp switch -F-Rear air distribution motor position sensor -G478- 87a F10 F10 -Fuse 10 on fuse panel B -SB10- 5 -Mass air flow sensor -G70-1 Fuel pump relay -J17-2 Automatic glow time control module -J179- 2 87a F11 F11 -Fuse 11 on fuse panel B -SB11- 30 DSG transmission Mechatronic -J743- 1 30a F12 F12 -Fuse 12 on fuse panel B -SB12- 15 Coolant pump -VX20- 1 87a F13 F13 -Fuse 13 on fuse panel B -SB13- 30 -Radio -R-Radio/navigation display unit control module -J503-External multimedia device interface -R215- 30a F14 F14 -Fuse 14 on fuse panel B -SB14- 5 -Motronic engine control module power supply relay -J271- 1, 3 Terminal 30 power supply relay -J317- 2 Engine control module -J623- 30a F15 F15 -Fuse 15 on fuse panel B -SB15- 20 -High tone horn -H2-Low tone horn -H7-Dual tone horn relay -J4- 30a F16 F16 -Fuse 16 on fuse panel B -SB16- 40 -Amplifier -R12- 30a F17 F17 -Fuse 17 on fuse panel B -SB17- 30 DSG transmission Mechatronic -J743- 2 30a F18 F18 -Fuse 18 on fuse panel B -SB18- 5 -Telephone transceiver -R36- 30a F19 F19 -Fuse 19 on fuse panel B -SB19- 5 Vehicle electrical system control module -J519- (T52a/24) 30 Ref. F20 F20 -Fuse 20 on fuse panel B -SB20- 40 Wiper motor change-over relay -J368-Wiper motor change-over relay 2 -J369- 30a F21 F21 -Fuse 21 on fuse panel B -SB21- 40 Secondary air injection pump motor -V101- 3 Auxiliary heater heating element -Z35- (T3hr/1) 2 30a F22 F22 -Fuse 22 on fuse panel B -SB22- 40 Auxiliary heater heating element -Z35- (T3hr/3) 2 30a F23 F23 -Fuse 23 on fuse panel B -SB23- 50 Fuse 32 on fuse panel C -SC32-Fuse 33 on fuse panel C -SC33-Fuse 34 on fuse panel C - SC34- 30a F24 F24 -Fuse 24 on fuse panel B -SB24- 50 Terminal 75 power supply relay 1 -J680-Fuse 40 on fuse panel C -SC40-Fuse 42 on fuse panel C -SC42- F25 F25 -Fuse 25 on fuse panel B -SB25- 40 Terminal 15 power supply relay 2 -J681- 30a F26 F26 -Fuse 26 on fuse panel B -SB26- 50 Automatic glow time control module -J179- (T11a/11) 30a F27 F27 -Fuse 27 on fuse panel B -SB27- 50 Coolant fan control module -J293- 30a F28 F28 -Fuse 28 on fuse panel B -SB28- 40 Vehicle electrical system control module -J519- (T52a/1) 30a F29 F29 -Fuse 29 on fuse panel B -SB29- 40 Vehicle electrical system control module -J519- (T52c/42) 30a F30 F30 -Fuse 30 on fuse panel B -SB30- 40 ABS control module -J104- (T47/1) 30a F31 F31 -Fuse 31 on fuse panel B -SB31- 30 ABS control module -J104- (T47/32) 30a F32 F32 -Fuse 32 on fuse panel B -SB32- 40 Auxiliary heater heating element -Z35- (T3hr/2) 2 30a 1) Only for vehicles with a 3.6L gasoline engine and engine code CDVB
2) Only for vehicles with a 2.0L diesel engine and engine code CKRA
3) Only for vehicles with a 2.5L gasoline enigne and engine code CBUA
WARNING: Terminal and harness assignments for individual connectors will vary depending on vehicle equipment level, model, and market.
Passat, Volkswagen electricity
Jan 16, 2017 | 2011 Volkswagen Jetta
Turntable is starting to slow down as it is playing
This maybe a failing motor or belt. I would take it to the repair shop to be sure which.
Mar 07, 2016 | Crosley Cruiser 3-Speed Portable Turntable...
Crosley Cruiser turntable vibration noise
How to Identify Damage in Your Record Player ' eBay
www.ebay.com > ... > Record Players/Home Turntables
They produce audible sound by reproducing sound vibrations from tiny grooves etched on the surface of vinyl records. Record players have three primary ...
Crosley Cruiser Turntable Review - YouTube
? 2:26
https://www.youtube.com/watch?v=w5KVANeimVU
Dec 8, 2013 - Uploaded by DTM
This is a review of the Crosley Cruiser turntable. ... cartridges (the mechanism that converts the vibrations of ...
Just getting into vinyl. Is there any way to improve a Cros
Dec 14, 2015 | Crosley CR8005A-TU Cruiser 3 Speed...
Where is the location of 06 Saturn Ion 2 compressor relay?
Connector 1:
Fuse Block - Underhood Label (2.2L, 2.4L)
Connector 2:
Fuse Block - Underhood Top View (2.2L, 2.4L)
Connector 3:
Fuse Block - Underhood Bottom View (2.2L, 2.4L)
Connector 4:
Fuse Block - Underhood C1 (2.2L, 2.4L)
Connector 5:
Fuse Block - Underhood C2 (2.2L, 2.4L)
Connector 6:
Fuse Block - Underhood C3 (2.2L, 2.4L)
Connector 7:
Fuse Block - Underhood Label (2.0L)
Connector 8:
Fuse Block - Underhood Top View (2.0L)
Connector 9:
Fuse Block - Underhood Bottom View (2.0L)
Connector 10:
Fuse Block - Underhood C1 (2.0L)
Connector 11:
Fuse Block - Underhood C2 (2.0L)
Connector 12:
Fuse Block - Underhood C3 (2.0L)
Connector 13:
Body Control Module (BCM) Label
Connector 14:
Body Control Module (BCM) Top View
Connector 15:
Body Control Module (BCM) Bottom View
Connector 16:
Body Control Module (BCM) C1
Connector 17:
Body Control Module (BCM) C2
Connector 18:
Body Control Module (BCM) C3
Connector 19:
Body Control Module (BCM) C4
Connector 20:
Body Control Module (BCM) C5 (UE1)
2.2L
alt="Object Number: 1438995 Size: MF">
alt="Click here for detailed picture of above image.">
2.4L
alt="Object Number: 1583009 Size: MF">
Fuse Block - Underhood Label Usage (2.2L, 2.4L)
No.
Device
Rating
Description
ECM (2.4L)/TCM Fuse
10A
ECM (2.4L)/TCM
2-3
Not Used
RH HDLP Fuse
15A
Headlamp - Right
5
A/C Fuse
10A
A/C CLUTCH Relay
6-7
Not Used
8
ABS Fuse
10A
EBCM (JM4)
9
ECM/ETC Fuse
15A
ECM
10
EMISS Fuse
15A
EVAP Canister Purge Solenoid, Coolant Level Switch, MAF Sensor, HO2S 1, and HO2S 2
11
IGN Fuse
10A
ICM and PNP Switch (A/T)
12
Not Used
13
TRANS2 Fuse
10A
ECM, Automatic Transmission
14
TRANS1 Fuse
10A
TCM (MN5)
15
BACK UP Fuse
10A
PNP Switch (A/T) or Backup Lamp Switch (M/T)
16
INJECTORS Fuse
10A
Fuel Injectors 1-4
17
FOG LP Fuse
10A
FOG LAMP Relay (T37)
FOG LP Fuse
15A
FOG LAMP Relay (T96)
18
LH HDLP Fuse
15A
Headlamp - Left
19
WIPER Fuse
25A
WIPER 1 Relay
20
HORN Fuse
10A
HORN Relay
21
RADIO Fuse
20A
Audio Amplifier (UZ6)
22
ABS Fuse
20A
EBCM (JM4)
23
RR DEFOG Fuse
30A
REAR DEFOG Relay
24
A/C CLUTCH Relay
A/C Compressor Clutch
Jul 17, 2015 | 2006 Saturn ION 2
The turntable on the Crosley I have just brought,spins round unevenly(up and down),is this a problem as it plays some records ok but will not play others.
The platter should be level. If it is not then it could either be warped, by oil, heat affecting in the past. Or just faulty. Even if a warped turntable plays a record OK, it could damage it, as it is so easy for a record to be damaged, it could cause a scratch on the record. It should be checked out.
Feb 23, 2015 | Crosley Cruiser 3-Speed Portable Turntable...
Turntable troubleshooting
My guess would be Old Receiver, Amp ... have a phono input what is in a simple way a pre-amplified input , newer receiver don't . You just need to buy a small Phono Turntable Preamplifier ( less then $20 on line) you are going to install between the receiver and the turntable and you should get some sound at the right level.
Good luck.
Aug 01, 2014 | Crosley Cruiser 3-Speed Portable Turntable...
I need a fuse panal diagram for the 2013 VW Jetta, my 12 volt power ports are not functioning
Here you go. Fuses on E-box, on left in Engine Compartment
Fuse 1 - Not assigned
Fuse 2 - 10/15A - Engine control unit
Fuse 3 - 5A - Radiator fan control unit
Fuse 4 - 5/10/15A - Lambda probe heater,
Lambda probe 1 heater after
catalytic converter
Fuse 5 - 10A, 20A - Lambda probe heater1,
catalytic converter,
Fuel system diagnostic pump,
Charge pressure control solenoid
valve,
Exhaust gas recirculation cooler
change-over valve,
Crankcase breather heater element,
Vacuum pump for brakes
Fuse 6 - 5A, 10A,15A - Fuel system diagnostic pump,
Throttle valve module,
Activated charcoal filter system
solenoid valve 1,
Continued coolant circulation pump,
Auxiliary air heater heating element
Fuse 7 - 20A, 5A - Ignition transformer,
Fuel pressure regulating valve,
Fuel metering valve
Fuse 8 - 10A - Throttle valve module,
solenoid valve 1
Fuse 9 - 5A - Automatic glow period control unit,
Electric fuel pump 2 relay,
Fuel pump relay
Fuse 10 - 5A - Speedometer sender,
Brake light switch
Fuse 11 - Not assigned
Fuse 12 - 5A - Coolant circulation pump
Fuse 13 - 5A - Water pump
Fuse 14 - 5A - Engine control unit
Fuse 15 - 30A - Voltage stabiliser
Fuse 16 - 30A - ABS control unit
Fuse 17 - 30A - Automatic gearbox control unit
Fuse 18 - 20A - Automatic gearbox control unit
Fuse 19 - 1A - Onboard supply control unit
Fuse 20 - 30A - Onboard supply control unit (AW0)
Automatic intermittent wash and
wipe relay (AW1)
Fuse 21 - 50A - Secondary air pump motor
Fuse 22 - Not assigned
Fuse 23 - 40A - ABS control unit
Fuse 24 - 50A - Trailer detector control unit
Fuse 25 - 50A - Terminal 15 voltage supply relay 2
Fuse 26 - 60A - Automatic glow period control unit
Fuse 27 - 60A - Radiator fan
Fuse 28 - 40A - Onboard supply control unit (AW1)
Fuse 29 - 40A - Onboard supply control unit (AW1)
Fuse 30 - 50A - Terminal 75 voltage supply relay 1
Fuse 31 - 30A - Amplifier
Fuse 32 - Not assigned
Fuse assignment - Interior Fuse Panel
Fuse 1 - Not used
Fuse 2 - 5A - Electronic steering column lock control module
Fuse 3 - 10A - Instrument cluster control module
Fuse 4 - Not used
Fuse 5 - Not used
Fuse 6 - 10A - Vehicle electrical system control module,
Interior ceiling lights,
Tail lights
Fuse 7 - 5A - Fog lamp relay,
Instrument panel and switch illumination dimmer switch,
License plate lamps,
Fuse 8 - 7.5A - Windshield and headlamp washer pump switch,
Windshield washer pump
Fuse 9 - 5A - Airbag control module
Fuse 10 - 10A - Right steering column switch
Fuse 11 - Not used
Fuse 12 - Not used
Fuse 13 - 5A - Automatic dimming interior rearview mirror,
Light recognition sensor,
Parking aid control module,
Air quality sensor,
High pressure sensor,
Climatronic control unit,
Tire pressure monitoring button,
Back-up lamp switch,
Left washer nozzle heater,
Right washer nozzle heater,
28-pin connector
Fuse 14 4- 10A - Left steering column switch,
ABS control module,
Light switch,
Airbag spiral spring/return spring with slip ring,
Fuel pump control module,
Fuse 15 - 10A - 16-pin connector (diagnostic connector),
Headlamp range control adjuster,
Auxiliary heater operation relay,
Mass airflow sensor,
Positive crankcase ventilation heating element,
Left front headlamp,
Left headlamp beam adjustment motor,
Right front headlamp,
Right headlamp beam adjustment motor,
Fuse 16 - 10A - Engine control module
Fuse 17 - Not used
Fuse 18 - 15A - Left front headlamp
Fuse 19 - 15A - Right front headlamp
Fuse 20 - 10A - Automatic transmission control module,
Selector lever sensor system control module,
Tiptronic switch,
Ignition/starter switch
Fuse 21 - Not used
Fuse 22 - 10A - Ignition/starter switch,
Converter box,
Alarm horn,
Interior monitoring sensor,
Alarm horn relay,
Fuse 23 - 10A - Vehicle electrical system control module,
Light switch,
Rain/light recognition sensor,
Compass magnetic field sensor,
Fuse 24 - 10A - Vehicle electrical system control module,
Access/start authorization control module
Fuse 25 - 15A - Automatic transmission control module,
Multifunction transmission range switch
Fuse 26 - 15A - Brake system vacuum pump
Fuse 27 - Not used
Fuse 28 - 40A - Auxiliary heater operation relay
Fuse 29 - 1A - Vehicle electrical system control module,
Fuse 30 - 20A - Cigarette lighter,
12 V socket,
12 V socket 2,
Blocking diode
Fuse 31 - 30A - Light switch
Fuse 32 - 20A - Light switch
Fuse 33 - 40A - Heater/heat output switch,
Fresh air blower relay,
A/C control module,
Fresh air blower switch
Fuse 34 - 15A - Left front headlamp,
Fuse 35 - 10A - Steering column electronics control module,
Instrument cluster control module,
Signal horn activation,
Fuse 36 - 25A - Vehicle electrical system control module
Fuse 37 - 15A - Left front headlamp DRL
Fuse 38 - 15A - Right front headlamp DRL
Fuse 39 - 15A - Low beam relay
Fuse 40 - 15A - Towing recognition control module
Fuse 41 - 15A - Towing recognition control module
Fuse 42 - 20A - Towing recognition control module
Fuse 43 - 30A - Front passenger door control module
Fuse 44 - A25 - Rear window defogger relay,
Fuse 45 - 30A - Driver door control module,
Fuse 46 - 30A - Left rear door control module,
Right rear door control module
Fuse 47 - 15A - Fuel pump control module,
Fuel pump relay,
Fuel primer relay
Fuse 48 - 20A - Vehicle electrical system control module,
Fuse 49 - 20A - Climatronic control unit,
A/C control module
Fuse 50 - 30A - Front seat heating control module
Fuse 51 - 30A - Power sunroof control module
Fuse 52 - 20A - Dual tone horn relay
Fuse 53 - 15A - Front seat heating control module
Fuse 54 - 15A - Fog lamp relay
Fuse 55 - 20A - Light switch,
Fuse 56 - Not used
Fuse 57 - 15A - Radio,
Fuse 58 - 1A, 30A - Telephone transceiver
DC/AC converter with socket, 12V-230V
Fuse 59 - 30A - Amplifier
Fuse 60 - 30A - Auxiliary heater control module
Jul 20, 2014 | Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6...
HOW DO CHANGE A STYLUS ON A CROSLEY CRUISER CR8005A
Type Crosley CR249TA User Manual " into search engine and it will show sites to get manual. In manual there are instructions to help you.
Jul 08, 2014 | Crosley CR249TA Turntable
I bought a crosley cruiser turntable (orange portable) in NY USA. I brought it to Dubai UAE, plugged it in and the voltage was too high. It "cooked" Can this ever be repaired and if so what needs to be...
As with most things it depends on how much you are prepared to spend on getting it fixed and how much a new turntable would cost.
It's likely that damage is extensive and that the transformer would need to be replaced. If more of the power supply section is damaged then the bill will run up quickly. A look inside will give you an idea of the damage. If lots of parts look burnt or damaged, I think you can call it a day with it. If it looks good then contact Crosley for a list of authorised service centres.
Jun 08, 2014 | Crosley Audio Players & Recorders
93 people viewed this question
 Grubhead
Grubhead
