Question about Yard Machines Garden
Craftsman 357cc snowblower
Was running then stall like it was out of gas now only starts with choke on then stalls
    Genius:
  • 1,114 Answers
Remote possibility the spark plug needs to be replaced. But it sounds more likely that the fuel system is the problem. Is the gas relatively fresh? The Carburetor may have gunk/dirt build up. Some will say not to use carburetor cleaner in these engines, but I have been cleaning out my small engine equipment when needed for many years. At times I've had to replace the gas in the tank first because it was too stale. Then with fresh gas, I put about 1/4 of can of carb cleaner in with the gas and run the engine. It may take awhile for the system to clean, so you have to just keep starting the engine and let it run for as long as it will, and try to take off the chock as it's running....
Posted on Mar 23, 2014
Craftsman snowblower 179cc ohv
clean the carb , make sure you are shutting off choke after start this fouls the plug , good gas ?
Jan 11, 2014 | Garden
My snowblower will not start. Brand new just out of the box.. craftsman model 247.881730
Do you choke it? They also have a primer bulb do you use it.
There should be a screw on the carb to adjust the gas flow. If it appears no gas is getting to the spark plug open that screw up a little at a time.
Turn left to open and right if too much gas is choking it to death.
If that does not work take the spark plug out and put a Tablespoon of gas in the spark plug hole and put the plug and plug wire back in place and try that. If it runs and stalls after 10 or 15 seconds then your carb needs attention.Like maybe the float could be stuck.
Dec 12, 2013 | Garden
Mower will run then starts running bad turn the choke off and it stalls stalls after i choke it also blows gas out of the top of the carburator how do i adjust the vaalvesType your problem for a solut
Using the choke as you did,mentioned in your problem,you have flooded the carburetor. DO NOT USE THE CHOKE,ONCE THE TRACTOR IS RUNNING. Choke is used to start the motor only. When you run with the choke on,the motor gets to much gas and the plug(s) get fowled up and gas comes out of the carburetor. Remember the motor is hot,when gas comes out of the carburetor,the amount of over flow (flooding),could cause a FIRE. Lay off the choke,clean the spark plug(s),they will most likely be fowled up. The filter will be soaked with gas,remove the filter,soak up the gas,using a handy wipe,let filter dry out. Once dry replace filter. You should be good to go. Remember,do not over choke,use when starting a cold motor,usually when motor is hot from running,you may not have to use the choke at all. Hope this helps. Sincerely,Brad Locke
Apr 22, 2013 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Manual for a craftsman weedwacker model 31679108
Trimmer Starts but stall out as soon as throttle is used and choke turns off. if I hold the throttle and pull the choke it runs but will stall as soon as choke is let go.
Jan 31, 2011 | Craftsman 27cc 2 Cycle Crank Straight...
Briggs and Straton 8 hp, craftsman snowblower stalls
Sounds like you coil is over heating after running a few minutes. The windings are seperating, then when it sools they make contact again. Try replacing the coil.
Feb 05, 2010 | Craftsman Garden
Craftsman 32cc Trimmer Runs with choke at idle, then stalls
Sounds like somewhere you have a air leak. Most likely it's somewhere near the carburetor intake or maybe the carb itself. Could be a line from the primer if it has one and i do believe it should that could be leaking or loose. Good luck.
Aug 02, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
Top Yard Machines Garden Experts
Phil Walker
Phil Walker
Dean Gruber
Tim Whalen
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
