Question about Belkin Bluetooth Music Receiver
My Belkin bluetooth music receiver will no longer connect to my ipad
It is paired with my ipad but will no longer connect to it. It just says that it can't connect.
  • 34 Answers
Put the receiver in pairing mode again and retry.
Posted on Jun 20, 2014
Can I pair my Bluetooth earphones to my iPad?
How to pair Bluetooth headphones to IPAD?
Most headsets have a power button or a switch to turn the device on. Press the "Pairing" button on your Bluetooth headset, if necessary. Select your headset from the Devices list on the iPad's Bluetooth window. Enter the passkey or PIN for your headset, if prompted.
Does the iPad Pair With Bluetooth Headphones? ' Chron.com
smallbusiness.chron.com/ipad-pair-bluetooth-headphones-62883.html Search for: How to pair Bluetooth headphones to IPAD?
Dec 05, 2016 | Radio Communications
How can I get a Bluetooth adapter?
This should do the trick:
http://www.bestbuy.com/site/rocketfish-bluetooth-music-receiver/5654132.p?id=1218679203690
Apr 20, 2015 | Pioneer VSX-515 Receiver
Bluetooth will not activate, tx-nr636 setting says its on but no light and device will not connect
To connect a Bluetooth-enabled device (phone, tablet, iPad, iPod, computer), follow the steps below:
1. Press and hold the button to put the receiver in "Pairing/Connecting" mode. You should see a red and blue light flashing in rapid succession somewhere on the receiver.
2. Turn on Bluetooth on the device you want to connect with the receiver and tap on Scan. The device will start scanning for nearby Bluetooth devices. When you see that it detected a device with a name similar to the receiver's name, tap on the name to pair with the device. If you are asked for a passcode/passkey, enter '0000' or '1234' (without the quotes). If the two pair, the light on the receiver will turn to a steady blue and you will see 'Connect' on the device. The two are now paired.Tap on Connect and then you will see Connected on the device. Your device and the receiver are now connected.
The steps above should be detailed in the set up guide that came with the receiver. There may even be a passkey/code provided in the guide. Use that one for pairing instead of the passkey I suggested above. Please note that pairing is a one-time procedure, required only the first time you are connecting the device to the receiver, a "get to know you" process. After that, you just need to connect the two.
I am assuming that you have already hooked up speakers to the receiver. Start playing music from your device and enjoy listening to it through the receiver's speakers !
Dec 28, 2014 | Onkyo TX-NR636 Receiver 7.2 Channels, 95...
How do I pair my I Pad with my new Philips portable speaker using bluetooth ( can connect fine using a cable)
If your portable speaker is Bluetooth-enabled, here is the general procedure:
1. Press and hold the function control button on the speaker until you see red and blue lights flashing in rapid succession on the speaker (the speaker is now in "pairing" mode).
2. Turn on Bluetooth on your iPad and then tap on Scan. iPad will begin scanning for nearby Bluetooth devices. When you see a name similar to that of your speaker, tap on it . You will be asked for a passcode/passkey to pair the iPad with the speaker. Enter '0000' or '1234' (without the quotes).
3. Once the passkey is accepted, the two devices are now paired. The light on the speaker should become a steady blue.
4. On the iPad, tap on Connect. If the iPad connects to the speaker, you will see Connected. You are done. Play some music from the iPad to see if you can hear it coming through the speaker.
You should have this procedure detailed in the set up guide that came with the speaker. Please note that pairing is required only for the first time you try to connect the two devices, to get them "acquainted" to each other. After that, all you need is to connect the iPad to the speaker every time you want to listen to your iPad through the speaker.
Nov 30, 2014 | Philips Audio Players & Recorders
My speaker does not connect to my ipad
The speaker has to be paired with your iPad before it will work. Check your documentation on how to put your speaker in "discoverable" mode long enough for the iPad to find it. If you have previously paired your speaker and it at one time did function is your iPad, make sure that Bluetooth is turned on on the iPad. Also, check the batteries on the speaker if it has previously functioned with your iPad...
Jun 21, 2014 | iLive Bluetooth Speaker System
How to pair belkin fastfit keyboard to iPad
Make sure the Belkin FastFit keyboard is powered on, turn on the iPad and goto Settings. Make sure Bluetooth is On ... the Keyboard should appear in the list of discoverable devices. Select the Belkin FastFit keyboard ... when it connects, you should be able to enter any text field using the keyboard rather than the on-screen one ...
May 16, 2014 | Computers & Internet
Hi,Just purchased 2 antec gain Bluetooth receivers type bxr 100. Operating instructions are not included. Maybe it's just me, but i'm not succeeding in getting them to work. No lights at all when they
Make sure that the unit is fully charged by a micro USB the light on it will be red until it's fully charged put phone in search mode and press the center button until the light flashes red and blue after the phone finds it you should have an option to auto pair when it's not in use it will turn off when paired and working pressing either track button will start the music player then just play with the buttons and see what it does you can stop anything from the phone controls
Mar 18, 2014 | Antec BXR-100 Gry Audio...
Ipad and beikin keyboard
You will need to enable bluetooth on your iPad and then pair the keyboard to the iPad. Try the following:
  • On your iPad, tap the settings icon from the Home Screen.
  • Tap on General.
  • Tap on Bluetooth.
  • Toggle Bluetooth to On
  • Turn on the Belkin keyboard.
  • The keyboard will show up under Devices on the iPad.
    Select Belkin Bluetooth Keyboard.
  • A code will appear on the screen.
    Enter this code on the keyboard and click Enter.
A message will pop up when pairing is successful. If pairing fails, repeat the steps above. If you're still unable to pair the two leave a comment and I will help further troubleshoot.
Hope that helps!
Jan 15, 2014 | YouTube Videos
I have a JBL wireless flip speaker and even after reading the so-called manual, I have absolutely NO idea how to use it . My iPad has blue tooth capability but,I,don,t even know what,exactly is Bluetooth...
Once you put the JBL speaker on, turn on bluetooth on your ipad, search for bluetooth device, it takes a few minutes sometime to locate your speaker, once you see your speaker listed in the bluetooth device, click on the device. IT will connect but at times it might ask for a PIN.
Oct 01, 2013 | Radio Communications
Belkin Bluetooth Music Receiver Logo
322 people viewed this question
Top Belkin Audio Players & Recorders Experts
woodzowl307
Renee Knafel-Bullock
bill tarkulich
Level 1 Expert
Are you a Belkin Audio Player and Recorder Expert? Answer questions, earn points and help others
