Question about Emerald Honeybee Poster Of Historic Japanese Art: The Actor Iwai Hanshiro V In The Role Of A Woman, Fuji Musume, Speaking To A Man, The Actor Bando Mitsugoro Iii As Zato, Sitting On The Ground Holding A Stick Size 12 X 13
357cc yardman will on start with choke on then stops
Was running then stopped
Cold choke baffle has 3/16 opening minute I pump accelerator choke thermostat closes primary baffle shut no air to start I force choke open to start why insufficient air to run at high idle?
Your engine probably has an automatic choke device that adjusts automatically with engine temperature. To set the choke when the engine is cold you have to depress the accelerator to the floor and release it completely. You shouldn't have to depress the accelerator again to start the engine, turn the key the engine should start. As the engine begins to warm up it will also begin to initially run faster then it will start to run rough. At this point you have to press the accelerator and release it again. The auto choke mechanism should allow the choke butterfly to open. There may be a number of stops in the system and the choke butterfly will stop again still not fully open and only become fully open when the engine is at operating temperature. Hope this answers you question, Rgs. Bob
Jun 21, 2015 | Cars & Trucks
Yardman 3.5 cultivater starts but dies when choke is opened
Most likely the Carburetor is dirty and needs a good cleaning
Apr 30, 2015 | MTD PRODUCTS INC yardman"" garden tiller"
How do I keep my Yardman bp2 leaf blower running? will idle but not come off of choke.
It sounds like a carb problem. You can buy a rebuild kit on line for cheap and rebuild it.Should run fine then.
Oct 11, 2014 | Garden
Engine start to run rough and shot off after 3-4 minutes running
Possible solutions:
You could have water in your gas if so a $3 additive will unfreeze and eliminate this which will cause rough idling. If your carb is clean make sure to let the blower warm up for several minutes, take off the choke as it warms and it will run smoothly. Last if those dont work, adjust your carbs mixture setting screw (when the engine is warm). (and check your oil! Hope this helps.
Feb 04, 2014 | Mtd Snow Thrower 28" 357cc Ohv
Yardman snowblower won't self-propel
Do not start to do this but put the blower in gear like you would run to drive its self and try to turn the wheels by hand and if they turn easily then you may have a shear pin that is broken or missing in the drive pulley.
Just a thought.
Dec 12, 2013 | Yardman Yard-Man 31AH65LG701 357cc Gas...
I can't find the choke lever for my Yardman model number 31A 285 452 Snowblower, and I can't get it started. Any suggestions?
Here is a link to a parts diagram of your blower.; Part # 12 is the choke.Parts diagram choke location
I hope this helps. Please post feedback.
j
Dec 09, 2013 | Garden
What is the starting procedure?
Start with the choke on full press the fuel siphon button till the lines are full of fuel. pull handle until it tries to start but stops. move the choke to half then start again. let it run for 60 seconds on full. don't move the choke to full or it will stop. Either slow the revs and then put the choke on full or keep the revs high and slowly move the choke to full (to allow the governor to slowly advance with the new revs)
Nov 03, 2012 | kawasaki Krb750b Backpack Leaf Blower
Yardman seris 155 42 inch cut will only run for 30 sec to 1 min then stops why
try and run it with the fuel cap loose the vent in the cap could be plugged
Jun 04, 2012 | Garden
May mac 110 starts then it stops. I choke it it fires then i unchoke it and it starts and stops running.
Try backing the choke off about 1/2 way after it pops, and allow it to run for a few moments on that setting. Once the engine warms up, you can back the choke off completely. My Mac mini has no primer bulb, which means using the choke in a similar manner. Don't forget to set the 'fast idle' button on the throttle before starting (blipping the throttle will release the fast idle button). Hope this helps!
Sep 09, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
YardMan U804H lawn tractor idles too fast
Might want to remove the blower housing and check for trash blocking governor mechanism.
Apr 13, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Emerald Honeybee Poster Of Historic Japanese Art: The Actor Iwai Hanshiro V In The Role Of A Woman, Fuji Musume, Speaking To A Man, The Actor Bando Mitsugoro Iii As Zato, Sitting On The Ground Holding A Stick Size 12 X 13 Logo
80 people viewed this question
Top Emerald Honeybee Cooking Experts
Tom Chichester
ray gallant
Are you an Emerald Honeybee Cooking Expert? Answer questions, earn points and help others
