Question about Spirit Fitness Spirit XE295 Elliptical
Heart rate I have a polar heart rate monitor and I checked my own heart rate. The elliptical heart rate is showing my HR 20 points higher. How do I set my HR to the correct setting on the ellipitical.
Which Polar heart rate monitors work with Fuel Fitness FS320e Elliptical
Any analog signal Polar should work fine. Stay away from the RS-800 series.
Mar 26, 2011 | Polar Heart Rate Monitors
Changed the battery and now it won't pick up the heart rate monitor. I know the monitor works because it is picked up by all the equipment in the gym.
If Heart Rate is being displayed on the equipment in the gym, but not your watch, then your chest strap is transmitting fine, but the watch is not recieving the signal.
It is not uncommon that when a battery is changed outside of a polar authorized service center that something can happen to the internal electronics. I would suggest you send the watch into Polar and have them take a look. if you have had the watch less than 2 years they will most likely take it under warranty and correct the issue, at the very least they have equipment to test and diagnose both the watch and strap, although it sounds like your HR strap is fine since you are getting HR on the machines.
Dec 27, 2010 | Polar FT40 Heart Rate Monitor Watch
My heart rate is registering betwee 37 and 38...for resting. I know this is not accurate. This problem just started. When exercising intensely, it registers at 58 to 72. Any recommendations?
change you "HR view" to HR, not HR%. Currently you are seeing your heart rate as percentage of your Max Heart Rate (Max HR) but not by beeps per minute (bmp). Go in to the settings and see HR View.
Jan 24, 2010 | Polar F11 Heart Rate Monitor
How do I set the High hr and the low hr by the chart?
To change any of the settings, press 'set' until 'settings' is displayed, press 'ok', now you can either set the heart rate manually in 'limit set' (press 'ok' to change the settings and press 'set' to change)
or input your personal data to let it choose heart rate settings itself in 'user set' where you input weight, height, age and *** (sadly yes please is not one of the options ;¬) )
if you go to www.polar.fi the user manual is on there if you need more clarification.
Hope that helps,
Andy
Sep 18, 2009 | Polar F4 Heart Rate Monitor Watch
My F11 Polar HR monitor is not working correctly
You should have someone who is use to servicing heart rate monitors take a look at it. There are parts in the monitor that can corrode and would need to be cleaned. Also, look into replacing the battery in both units (Strap and wrist) and make sure the unit is reset properly.
Sep 14, 2009 | Polar F11 Heart Rate Monitor
Polar F4 monitor is reading about 30bpm less than actual
Check that the case back is on the right way. A spring sticking out of the watch mech needs to line up with a hole in the white sticker on the inside of the case back, I think this is the receiver aerial.
Jul 20, 2009 | Polar F4 Heart Rate Monitor Watch
Heart Rate monitor not working
Follow this link and download complete manual;
http://www.polar.fi/en/support/product_support?product=275&category=Downloads
Rate me, please.
Mar 24, 2009 | Polar F4 Heart Rate Monitor Watch
My Polar HR monitor ce0537 do not pickup Hart rate
Had the same problem. Just figured it out. The center Polar Logo on the strap needs to touch your chest in a firm way. Bend it back slightly so it fits snug on the middle of your chest.
Jan 31, 2009 | Polar S410 Heart Rate Monitor
Polar F6
It sounds like most of you have the heart rate set to display in % of max heart rate. Most Polar products have the option of heart rate in BPM(beats per minute) or percentage of max.
If you look at the display during the exercise, you will see a % icon. You can turn it off in by hitting the back button and go down to HR view settings.
Hope this helps.
Chris @ Polar USA
Aug 02, 2008 | Polar F6 Wrist Watch
Spirit Fitness Spirit XE295 Elliptical Logo
Top Spirit Fitness Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Spirit Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
