Question about Go Ped Know Ped Goped Push Scooter
Goped is running but wont go faster than idel when i give it gas it wants to bogg down and shut off
I crashed last week bad. got up and ran it home full speed. i ran it a week later full speed for less than a minute. that's when the bogging started. it wont go faster than idle, the carb is clean and adjusted right, im using a new gas mix the engine is running great so is carb
5 Suggested Answers
SOURCE: Once i Turn the throttle my goped turns off
it may be over fueling if you have turned the jet id sugest hold at full throttle and adjust jet whilst running it on full power
Posted on Feb 11, 2009
SOURCE: just bought a used goped for my nephew, runs
i hve a MOB n73... \r\nand my seriaL NUMBER is 353548024388283
Can sum one tell me da license key of this serial number..... SMAR MOVIE 4.01
plz plz plz plz..... i Shall be thnk ful 2 all
Posted on Jul 06, 2009
  • 31 Answers
SOURCE: my engine will not stay started.
get someone to fix
Posted on Jul 14, 2010
SOURCE: the goped was running fine
Make sure you using fresh and properly mixed fuel, airfilter is clean, choke lever is set to the right position of opened not set at closed, and spark plug is still good. Then make sure there are no parts on the engine that are getting loose and the carb jet settings are correct if your engine has an adjustable carburetor.
Posted on Sep 16, 2011
My goped sport engine shut off and wont start again, what I can do?
Try the steps on this website. http://goped.8m.com/racingpages/troubleshooting.html
May 30, 2014 | Go Ped GSR Sport Gas Powered City Scooter
2007 kawasaki Ninja 250r Cranks but wont startt
It sounds like the float needle valves are lletting gas run into the bowl,in turn running gas into the motor,and fouling the spark plugs. Have you noticed if the oil level seems to be going UP,or the fuel level is going down? Kawasaki motorcycles are prone to leaking needle valves in the carbs for some reason. And the longer it sits,the worse its going to get.Try this,...pull the spark plugs and see if they are wet with fuel.Then,unhook the coils,and spin the motor over with the plugs out.If it shoots raw fuel about a foot out of each or ANY cylinder,then that is your problem. JUST BE SURE TO DISABLE THE COILS BEFORE SPINNING MOTOR OVER,AND DONT BE CLOSE TO THE PLUG HOLES WHEN YOU SPIN IT OVER!!
Good Luck!
Sep 26, 2012 | 2007 kawasaki Ninja 250R
99 eddie bauer explorer bogging out after driving a while
sounds like catalytic converter is going bad? put your hand by exhaust pipe and have someone rev engine. if not much exhaust coming out then converter is about to get clogged up. had the same prob 5 years ago. another question......when you are driving and give it gas does it take a while to gain speed? if so it's definitely the cat converter.
Aug 06, 2017 | 1999 Ford Explorer
Just turns off on it's own, Wait 60 sec. restart press pedel it dies.
This engine is electronically controlled so the first thing that must be done here is to have the systems control computer tested for fault codes and then do the proper diagnostics based on those codes.
Jun 07, 2012 | 1995 Plymouth Voyager
Car wont start
It is very bad to let your car run out of gas. You may need to give it exessive amount of gas when starting it.
Apr 23, 2009 | 1996 Oldsmobile LSS
Runs but boggs out when given gas
If you don't already, pump the primer/purge till it's full of fuel before starting
Apr 05, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Car hesitation
had a problem with a grand prix like that once, was the fuel filter, and injectors, all needed replaced, and it only had 89,000 miles.
Would check fuel filter first. Is it possible you got some bad gas??
Jul 05, 2008 | 2004 Chrysler Sebring
Go Ped Know Ped Goped Push Scooter Logo
Top Go Ped Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Go Ped Toy Expert? Answer questions, earn points and help others
