Question about Light Boating
Trim relay solenoid 1993 mercury 75hp
Trims up not down replace relay or solenoid or trim motor?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Light Master
  • 1,190 Answers
Swop the solinoids and try again if then goes down and not up then the solinoid is duff ! if nothing then check the trim switch wires with a multi metre , check wires not broken etc also !
Posted on May 02, 2014
  • 3 Answers
SOURCE: Volvo-penta aq271c, trim will go down, but not up.no pwr at relay
First check the switch-- does it have power, then check the solenoid to see if it works-- there are two. One is for down, One is for up. If you get power from the solenoid-- outgoing-- check connections going to pump motor.
Posted on May 17, 2009
SOURCE: tilt trim relays just click, when trying to engage
replace 55amper fuse for trim motor
Posted on Aug 17, 2009
  • 15 Answers
SOURCE: need to replace the trim/lift motor on a 225 hp
There are lots of deals on line for better prices, get exact model and year. Have a pro marine tech install it, because of liability and no loss of money out of your pocket.
Posted on Apr 16, 2010
  • 44232 Answers
SOURCE: i have a 1986 mercury 115 and need to replace the
remove motor from boat . then take side mounting plates off.
Posted on Apr 25, 2010
shujat_hussa
  • 24 Answers
SOURCE: Downloadable free repair manual
you can download this manual from here.
htttp://freedownloadbook.blogspot.com
Posted on Oct 29, 2012
Suzuki 175 trim motor wont trim up but trims down??
Mark,
There are a couple relays which control the up/down. I'm pretty sure your "up" relay has bought the farm. Easiest way to test is to locate the two relays under the engine cowling, cover, hood (call it whatever) and swap them. That's how we test them. If you swap them you will probably see that it now goes up but not down. Depending on your budget I would recommend replacing both at the same time. Usually when one fails the other is not far behind.
Easiest way to find yours is to follow the wire harness up from the trim motor into the top of the motor and you will then see that wiring go to the two relays. Other wires on the relays are for your trim switches. Power comes in from them, energies them, then they send the power out, down the other wires to the trim motor. Again, just swap the wires from one to the other and hit the switch. It'll most likely go up this time and not down.
Hope this helps,
Fred-
Dec 01, 2016 | Boating
How to remove trim panels in rear of vw caravelle t5
with a lot of difficulty and utmost care
as the trims age they crack at the holding clips easily
finding good replacements is getting harder
trims are held in with plastic trim clips
some clips button types
others under the edges along the underside of the trims out of sight
you know about them when the trim has resistance as you try to remove the trims
Aug 27, 2016 | Cars & Trucks
Trims up while running
Check for hydraulic leaks at trim cylinder. Possible that a check valve is leaking or the electric solenoid may be stuck. in the trim up position. I have included a link that may help you. Of course I don't know what unit you are running. Mercury stern drive, outboard etc.
Mar 05, 2015 | Boating
Tilt and trim wont trim up taking off works fine running down the lake
Check trm/tilt release screw,does trim motor run but motor doesn't lift,if trim motor doesn't run then it's probably trim solenoid/relay
Oct 09, 2014 | Boating
Install tilt and trim 75hp mercury
pending on how old your engine is coz the price of the full system is lots and mite be more than what your engines worth so check on price of engine with it fitted !
May 09, 2014 | Mercury Mark 75 Outboard Boat Motor...
1988 johnson trim wont go up or down replaced relays still wont work
Try going directly to the trim pump with 12 volts bypassing the solenoids, go directly to the green and blue wires, disconnect the relays first, see if it works, if it does, your problem is before the motor, if it doesnt your problem could be bad or dirty brushes in the trim pump motor which usually can be fixed on the cheap !
Apr 24, 2012 | Boating
Replaced motor 01 taurus 3.0 run great but kicked up p1309 after attempting to correct misses real bad got #1 up and used tool to install but dont know if maybe 180 out or other problem replaced sensor but...
does your scanner that read the engine code give you any live data? if so look at the fuel trims, if it shows positive fuel trims on one bank and negative fuel trims on the other then your synchronizer is 180 out ouf time.
Jul 28, 2011 | 2001 Ford Taurus
Power trim on 60 hp yamaha quit working
find the solenoid for the trim it will be a the engine or on the trim motor it self get a test lite and find the power wire on the trim motor and with someone pushing the trim button test the hot on the motor if there is no power it is the solenoid if there is power u my have a brush stuck in the trim motor itself but 99% of the time it is the solenoid u can tap the trim motor and see if that gets a result but dont hit hard
May 08, 2009 | Yamaha 12V Air Pump
Mar 28, 2009 | Boating
960 leather inner door trims
I dont believe that there is a factory available part. You prob need new panels.
Jul 19, 2008 | 1993 Volvo 960
Boating Logo
47 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
