Question about Schwinn 430 Elliptical Trainer
430 elliptical - knocking, loud squeaks.
Brand new 430 elliptical. Very quiet for first few moments, but then starts making knocking noises which are quickly joined by loud grating squeaks.
4 Suggested Answers
  • 13 Answers
SOURCE: NOISEY SCHWINN 430 ELLIPTICAL
Hi I'm Ryan, do you know where it is squeeking from? if you can find the squeek try 3 in 1 oil that should stop it.
Posted on Dec 31, 2008
I solved the problem by the following: take all the joints apart and grease with white lithium grease. Don't put them back together too tight! Don't take the little rollers apart; they're too hard to get back together. Just spray the whole area with silicone spray. Here's the real fix: our flywheel cover (and i guess the whole flywheel assembly) was loose. Take the half dollar-size black cover off the center of the flywheel. Tighten the nut inside. You need a socket wrench; you can't do it with the multi-wrench provided. The 'Cruiser' is much queter now! Good Luck, David
Posted on Jan 04, 2010
biggerc
SOURCE: My Schwinn 430 elliptical makes a clunking noise when pedalling backwards but not forward. What is causing this?
I have a iron man cdt elliptical that was clunking . I found a shaft on the end of the crank was slipping in and out, inside the bearings. I shimmed it and retightened the retaining washer which prevented it from slipping . Smooth as silk now. It was very frustrating because all seemed tight at first.
Posted on Jan 16, 2013
Knocking noise
check the sprocket sometimes they are put together with screws and it might be extruding out and rubbing.
Mar 04, 2014 | Yowza Fitness CAPTIVA - Worlds 1st...
Squeaky elliptical
You can download the picture and zoom it ! Has a few options of the possible squeaking noises. Hope this helps. Could be level, screws, guide rails 6_7_2013_7_23_55_pm.png
Jun 02, 2013 | Exercise & Fitness
My Nordictrack E9.0 Elliptical machine has a loud squeek
I have found a possible source for your squeak. I have the same elliptical and had an annoying squeak in the front end of the machine. The squeak could be coming from the roller arm flex bracket and/or the pedal arm flex bracket. These brackets are secured to the front of the roller arms and the pedal arms with a single bolt. Tightening these bolts may help get rid of the squeak. If you don't have your manual, you can download the manual at the nordictrack website. The manual will have an exploded drawing of the elliptical. The roller arm bracket and the pedal arm bracket are numbered 135 and 136 and you will see which bolt I am talking about. I have had numerous issues with my elliptical but after changing some parts under warranty, it is working like new. Good luck.
Mar 19, 2013 | Exercise & Fitness
My dryer has developed a loud squeak when it is drying. Some times it is quiet but other times it is very loud. How what is causing this issue?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Nov 30, 2010 | Fisher and Paykel DE09 Dryer
Making a loud noise when you first start the dryer. Starts to quiet down after a couple minutes. Thanks
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker
Nov 13, 2010 | Maytag Dryers
My LEV 4634 PQ0 dries the clothes fine but make a very loud rattling noise-anyway to quiet this machine?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 13, 2010 | Whirlpool LEV4634 Dryer
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
GE Electric Dryer DBXR463EG0WW making loud griding noise when on
heatman101
Feb 22, 2009 | GE DBSR453EBWW Electric Dryer
Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Schwinn 430 Elliptical Trainer Logo
545 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
