Question about Gordon Ramsay 6 qt. Nonstick Low Pressure Stovetop Cooker with Glass Lid - Bronze -
Glass of the cover is broken
The glass in the middle of the cover is broken
    New Friend:
  • 190 Answers
Sorry, you can't fix that. You need to contact the manufacturer.
Posted on Apr 08, 2014
Have a c970-440793 range. Need to replace the oven lamp light. I have the part in from Sears but there are no instructions.
Just slide the wire off of the glass lamp housing cover. It should just pop-off to the side. Then carefully remove the glass cover so as not to break it. Next, just remove the light bulb by unscrewing it counter-clockwise.
Screw in the new bulb (any small 40-watt appliance bulb will work,) hold the glass cove in place, then slide the wire back over the glass cover. The wire should be centered over the middle of the glass, towards you.
Sep 28, 2015 | In Microwave Ovens
The glass of scanner hp2510 is broken how can i remove it and fix it
I can tell you how to get access to the glass panel, although I cannot remember how easy it is to remove the glass itself:
First remove the lifting lid by unplugging the jack plug connector at the back, then riase the lid to vertical position, pull the plastic tab in the middle of the hige towards you and wiggle the lid upwards so that it comes out. Then pull off the keypad label plate, then gently pull off the control panel (which has two ribbon cables attached) by sliding it forwards from back to front of the printer. Disconnect the ribbon cables from the control panel (they pull off) and thread the cables back through their retaining clips on the top cover. Now you can remove all FIVE retaining screws (Torx T-10 driver required) from the top cover and lift it off, leaving the ribbon cables in situ. You can then turn the top cover over and work on removing/ repairing the glass. I would say it s not worth bonding - just get a new piece of glass.
Mar 25, 2013 | HP PSC 2510 All-In-One InkJet Printer
Neff B6774.0GB replace inner glass panel
open the door, loosen the two large screws (t20x or large flat head) near the top of the inner door, this will loosen the main outer door and you can slide it up and off. Look to the hinges and you will see retaining brackets held with two t20x screws, remove these and you then slide the rest of the door off enabling you to work on it on a flat surface. Lie it down with the broken glass as the lowest part. Remove two t20x screws from the two plastic holders near the top of middle frame, slide them out and remove the middle angled frame. Pay attention to which groove in the bottom of the door they are positioned for reassembly. You are now faced with a frame with absolutely mountains of t20x screws which will all have to be removed. when this is done, lift off the frame and you are left with the inner frame, broken glass and mesh panel. carefully take off the mesh screen and discard the broken glass ensuring that you do not inadvertently throw away the black thin seal (looks like a large rubber band). Use a toothbrush to ensure all glass is removed from the inner frame and that the inner edge of the frame is free from food debris etc (This is probably what caused the glass to shatter as the microwaves are attracted to food debris and would have cooked the glass causing a hotspot, this is usually evident if you look at the starting point of where the glass broke). Give the seal a clean also and reposition in the groove around the inner edge of the first frame. position the new glass panel, position the mesh screen and the middle frame. When putting all the screws back in, alternate them. left right top bottom until they are all back in (do not over tighten). Then reassembled the rest of the door by reversing the dismantling info. Let me know how you get on, please leave some feedback.
Nov 22, 2011 | Neff Ovens
My dishwasher isant getting enough water pressure to make middle tower come up and the arms will not spin
You have something stuck in the motor or something has broken the blades on the impeller. You will need to take out the racks and remove the rotor and the impeller cover.
BE CAREFUL!! Often it is broken glass stuck in there! Or, it could be a knife! Be sure you unplug it as well. It will be plugged in under your sink in most cases. If not, turn off the breaker.
Mar 23, 2011 | Dishwashers
My monitor case glas is broken is it covered of the warranty
unfortunately, no it does not cover the warranty. The broken monitor glass was an accident caused by you, so you will be the one to bear the consequence.
The warranty is void in this case. Warranty only covers factory problems.
I hope this is clear now. So you can go ahead and replace the broken glass.
Good luck.
Dec 06, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Can't get the light out to replace it?
You have to use a blunt bladed screwdriver to prize the edge of the glass cover away from the oven side. You should see a small cutout in the middle of the edge of the glass that is facing you, to put the screwdriver in. When replacing the glass cover, there is depression in the glass to allow for the bulb. Ensure you put the lense back the correct way.
Jul 31, 2010 | Stoves 720EF Electric Double Oven
Fax has stipe down middle
When you open the topt cover, there are 2 scanner glasses. A small one a and a big one, the small one is used when using the feeder. Spray some windex direclty on soft cloth and clean the 2 scanner glasses as well as the white reference above( there are 2 small and big). You may even see it, a mark it the middle of the glass.
This should resolve the issue
Apr 05, 2010 | Brother MFC 420CN All-In-One InkJet...
How do i take out the broken glass in wing mirror
it's just clipped on. order the new glass and it will be obvious where the clips are on the back. the glass and backing are one unit, this is clipped onto the mirror housing in the middle.
Jun 30, 2009 | 2003 Toyota Corolla
Line down the middle of copies
Clean the **** glass... usually a thin glass to the left.... check with a small flashlight, small blotch of ink or white-out can cause this... hope this helps.....
May 06, 2009 | Toshiba Office Equipment & Supplies
BROKEN GLASS COVER UNDER NIGHT LIGHT
SAME PROBLEM FOR ME...I REMOVED THE BOTTOM COVER AND FOUND THAT ONE LIGHT WAS NOT FIXED AND WAS LOOSE AND WAS TOUCHING THE GLASS. THIS HEAT WAS WHAT BROKE THE GLASS COVER. CLOSED INSPECTION SHOWED THE LIGHT SOCKET WAS TOO LARGE FOR THE CLIPS AND WERE NOT SECURED WHEN PURCHASED. I GOT SMALL SCREW AND NUT, BENT CLIPS SO THE SOCKET HOLE MATCHED THE HOLE MADE BY THE CLIP AND SECURELY ATTACHED THE SOCKET. THIS WILL SECURE THE LIGHT AND KEEP IT FROM TOUCHING THE GLASS..........IF I CAN EVER FIND A GLASS REPLACEMENT....MAY JUST HAVE ONE CUT. NOW THE PROBLEM IS TO REPLACE THE LIGHT AND MICROWAVE FUSE WHICH WAS BLOWN WHEN THE GLASS BROKE.
May 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Gordon Ramsay 6 qt. Nonstick Low Pressure Stovetop Cooker with Glass Lid - Bronze - Logo
104 people viewed this question
Top Gordon Ramsay Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Gordon Ramsay Kitchen Appliances - Other Expert? Answer questions, earn points and help others
