Question about Konica Minolta Bizhub C451 Copy-print-scan
Konica Minolta C451 is ghosting only black color and ONLY when duplexing (first side is OK, just second side is ghosted). Black parts of print looks like smeared in direction how paper moves through p
Black printing ghosting problem when duplexing
  • Konica Minolta Master
  • 6,696 Answers
What media are you using and what is the weight of the media you are using and does the copier know this and is correctly set
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 14, 2016
5 Suggested Answers
SOURCE: Minolta 2300DL ghosting
I just had the same problem with my 5430DL. It was a bad toner cartridge. The bad cartridge is at 73% full, and had not been a problem until recently. I had been troubleshooting and finally remembered that I had the old cartridge with toner still left. I swapped them out and no more ghosts. Swapped back and the ghosts came back. I have ordered another new toner cartridge and fully expect the problem to be resolved.
Posted on Feb 02, 2008
  • 214 Answers
SOURCE: Magicolor 2300dl ghosting and smear - black only
if only black does that, then it can be black toner, but the best way to find out, print something and when printer starts to take paper open front door, remove waste toner box and take out pc drum and transfer belt and check the printed page from there, if it seems ok, print nex page and open door when page comes out from fusin unit, if quality goes bad before fusing unit, it may lead to 2'nd transfer roller / pc drum and transfer belt quality was ok / if after FU then you have a problem in fusing unit.
Posted on Jul 02, 2008
waqar697
  • 67 Answers
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
Posted on Mar 30, 2009
SOURCE: Color line along side of copies; doesn't always print; error message keeps blinking (no manual),
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Posted on Sep 12, 2009
I have a KM bizhub c 451 black imaging unit that prints faintly. I have replaced the following parts, PC drum, PC charger and starter( developer), yet it is not printing solid black.
replace the black image unit as a whole you do not replace the units as individual parts. Where did you get the drum from? or the PC charger as they come as one and you don't replace the developer as it is located inside the unit!!!!!!
Mar 22, 2017 | Konica Minolta Bizhub C451 Copier Print...
How can I solve colour registration error in konica minolta Bizhub c 451 printer. Thank you, Uchenna.
run registration procedure in service mode. any p codes check the black image unit as is the reference for color registration
Mar 18, 2017 | Konica Minolta Bizhub C451 Copy-print-scan
Blank copies on a Konica-Minolta c451 copier/printer.
Black or color or both? Check the transfer roller sponge looking roller on the right side cover that opens
Nov 09, 2016 | Konica Minolta Bizhub C451 Copy-print-scan
Konica Minolta c451 is showing white linen the printed work
for black and white??? or a color????? Means you might have something blocking the LASER for that color. print out a test chart for each color which one has the white line?
Jun 22, 2016 | Konica Minolta Office Equipment & Supplies
What's your question? my konica minolta c451e printing machine showed me an error code p21, what could that mean and it is not printing any image but black-green shade
P-21 - Color regist test pattern failure
• The number of points detected in the main scan direction is more or less than the specified value during main scan direction registration correction.
• The number of points detected in the sub scan direction is more or less than the specified value during sub scan direction registration correction.
P-21: Color regist test pattern failure
Relevant parts:
• Transfer belt unit
• PH unit
• Printer control board (PRCB)
Step/Action:
1/ Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2/ Change the image transfer belt unit if the transfer belt is damaged.
3/ Change the PH unit.
4/ Change PRCB.
(See Service Manual, pages 599, 603):
http://www.imcopexamerica.com/service-books/Bizhub/Color/bizhubC451_C550_C650FieldSvc.pdf
See also here:
Konica Minolta Bizhub c451 Reparacin de Fotocopiadoras YoReparo
Thread Problemas na C451 7 21
May 31, 2015 | Konica Minolta Office Equipment & Supplies
Poor print quality
The "ghost" image is "burned" onto the drum.
A laser printer is supposed to charge specific "dots" on the drum, and the toner-ink is supposed to stick only to those "dots", the paper is pressed against the drum, and then the "fuser" uses heat to "melt" the toner-ink onto the paper, to produce the printed page.
You need to replace the drum.
Apr 07, 2010 | Konica Minolta magicolor 2430 DL Laser...
Apr 01, 2008 | Konica Minolta magicolor 2300DL Laser...
Jan 28, 2008 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta Bizhub C451 Copy-print-scan Logo
413 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
