Question about Water Heaters
Glowworm f13 boiler shows f13 fault when turned on
3 Suggested Answers
  • 171 Answers
SOURCE: how do i servis a glowworm compact boiler
Hi, perrycallow,
I'm Harvey the Master Plumber,
You want to know how to service a Glowworm compact boiler
Glowworm is a United Kingdom company and here is the information you asked me for, to get their technical service line:
Technical Help: 01773 828300
technical@glow-worm.co.uk
Thank You,
Harvey your Master Plumber.
Please give me a good rating before you sign off.
Posted on Sep 09, 2008
mrhotandcold
  • 248 Answers
SOURCE: Combi boiler Glow worm 24ci digital fault
refere to glowworm expert advise
Posted on Oct 12, 2009
My new viessman boiler is showing F1 after it made a humming that went on for half an hour
F1 means burner is at fault ,lack of pressure, best to call viessman or the installer back as if its a new boiler it has a five year warranty
Jun 07, 2015 | Water Water Heaters
How do i reset the thermal cut off switch on a vaillent boiler?
Hi, what model Valliant and are there any fault codes showing?
Feb 21, 2015 | Water Water Heaters
Glowworm 24cxi
Check if you have the link still in place, it seems its wired incorrectly through the bus circuit remove link and re wire
Apr 06, 2014 | Water Heaters
Glowworm boiler making noises
You're probably getting what some call gurgling sounds because there is air in the system. You need to bleed the air out at all bleed ports starting with the lowest in the system and ending with the highest.It won't hurt if you do that process a couple of times. Once all the air is out, you should have a normal convection flow of water through the system. - Good luck!
Jan 30, 2013 | Bosch Water Heaters
I have an ideal standard he30 boiler instaled about 6 weeks ago. the boiler keeps losing presure about half a bar every 2 days if i dont top it up it will trip the fuse on the fuse board acording to the...
All the combis I've come across merely fail to fire if the pressure is not up. not only do they not fire, nothing else works including the pump and in any event the pump should not overheat just on low pressure.
water loss - try turning off the valves on the flow & return pipes [3/4 inch ones] 1 valve per pipe . This will isolate the rest of the system - rads etc Note pressure over a time period. In this mode the hot water circuit will still work but do NOT use the heating circuit
1/2 bar over 2 days is not serious but it should be found
Once you have either mended the leak in the rest of the system or found there is not one, insist on a replacement boiler
In any event having looked at the reasons given for the fuse blowing, I would definitely get a replacement.
These problems should not happen on a new boiler
I list Worcester.-Ariston-GlowWorm-Ideal- and many others who would confirm this
Dec 24, 2009 | Water Heaters
I have a Glowworm 30 cxi and the light is flashing, the pressure is 0.4.... i have no water or heating...help please
Under the boiler a little right of center there is a blue/other colour knob. Turn this anticlockwise [as you look up] [twist from right to left] This is the mains inlet tap to let water into the boiler and create the pressure shown on the guage 0.5 bar is the absolute nin.
allow the water to flow in until the guage reads about 1 bar then turn off the knob -not too tight as these are plastic
If you allow too much pressure- do not worry, there is an automatic relief valve.
If the boiler persists in loosing pressure, look for a leak in all pipes to & from radiators. If no leak then check the pressure relief valve outlet pipe, it usually goes through the wall to the outside. Look at the end for water drips & if there are drips replace valve
Oct 12, 2009 | Water Heaters
Were can i get glow work boiler manual for free my boiler does not ignite
{ Glowworm} any merchant will order you one best of luck
Sep 14, 2009 | Water Heaters
Apr 03, 2009 | Water Heaters
Fault light flashing 1 flash per second
Prior to writing the above fault I had asked the owner to turn the boiler temp controller , for the heating side, down just a fraction . I was phoned this morning to tell me that the boiler had stayed on allnight with no fault light . After consulting with the plumber who fitted the system it appears that there might not be a room stat ,
Nov 30, 2008 | Bosch Water Heaters
How do i servis a glowworm compact boiler
Hi, perrycallow,
Thank You,
Sep 06, 2008 | Water Heaters
Water Heaters Logo
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
