Question about Polti Vaporetto Evolution Steam Cleaner
Cannot stop steam from coming out of the steamer
Having filled the steamer the steam keeps leaking without anything connected to it. If I fit the hose with the iron on it still leeks trough the iron without pressing the trigger
2 Suggested Answers
russell_b69
  • 4 Answers
SOURCE: Polti steam cleaner
Your polti is blocked up with limescale, you can try and decscale it but mine didn't work after that so I dismantled it, cleaned the valves out and now she's running at full steam ahead.
Posted on Oct 30, 2012
My compact steamer does not let the steam out when I press the black release button help?
I examined mine. There is literally NO hole in the steam wand for the steam to exit. It's a wonder the thing didn't blow up. Take it back and be glad you still have your face.
Jan 01, 2015 | Top Vacuums
Water is coming through steamer instead of espresso spout
There is something prob scale keeping the steam valve open it needs to be disassembled cleaned and inspected , they can wear out and need replacement
Aug 18, 2014 | Saeco 00034 Incanto Sirius Super Automatic...
My ez1 Monster Floor Steamer - green light goes off when I lower the handle and stops steaming
It could be calcium deposits in the tank. Clean it with white vinegar. Good luck!
Nov 10, 2012 | Euroflex Ez1 Monster Floor Steamer -...
I am having problems with my Delonghi Magnifica espresso maker. It is leaking steam when the knob is shut off. It also leaks steam from the vents on the side after using the steamer. It takes several...
To solve leak problem you can follow these links " http://www.homeespressomaker.org/2-delonghi-magnifica-espresso-machine-leaks-and-leak-problem-fixed/", " http://delonghimagnificaespresso.info/saeco-italia-espresso-machine-leak/". Hope these will help you.
May 31, 2011 | Vacuums
Saeco Magic Comfort Plus still producing steam in "off" position.
This may be something you can fix. It depends on your comfort level with mechanical repairs. You probably need to replace some o-rings in the steam valve. Don't keep trying to brew or steam because leaking water or steam inside may cause an electrical short. Decide if you want to delve into the repair, or locate a repair center near you. I could put you in touch with some.
Mar 18, 2009 | Saeco Magic Comfort Plus Espresso Machine
Steamer
Both tubes must be in the water. If you haven't used the machine for awhile, fill the water canister, turn the espresso maker on and also turn on the delivery switch (the top switch on the EC140). You'll hear the pump and in a second or two water will begin to exit the boiler nozzle. Immediately turn the delivery switch off. Wait for the "OK" light to come on. Press the "Steam" switch (the middle switch on the EC140, place an empty cup under the frother and turn the steam control knob on top in the counterclockwise direction. Steam will come from the frother. Be very careful to avoid contact with this steam.
Apr 23, 2008 | DeLonghi EC140 Espresso Machine
Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
Polti Vaporetto Evolution Steam Cleaner Logo
61 people viewed this question
Top Polti Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Polti Heating and Cooling Expert? Answer questions, earn points and help others
