Question about JVC Audio Players & Recorders
Vibration through speakers on my jvc home cinema system
My tv sound comes through my home cinema system, it vibrates / sounds distorted some times anyone got any ideas of thr problem please
  • 24 Answers
Try tightening the screws on the cabinets or buy a full set of
Wharfedale Modus Cube Main Stereo Speakers to replace the bad ones
Posted on Apr 13, 2014
  • 93 Answers
SOURCE: home theatre problems sound
Did you try to connect AUDIO OUT from your TV to AUDIO IN on your package?
Posted on Oct 04, 2007
SOURCE: no speaker sound from tv
in your tv headphone out connector if yes you connect cable if sound not out you cheq from your cd walkman or any other player like mp3 ,ipod if it sound come , it means some problem in your tv.
Posted on Nov 17, 2007
SOURCE: samsung ht-z310 home cinema no sound rear speakers
I seen the same thing when I first opened mine except my "center" speaker wan't working. It had to do with the "Mode" it was in. The Mode button at the botoom of the remote changes the speaker configuration.
There is also an option in the setup that allows you to turn on/off speakers for the system, all of mine were either Present or Small which enables them to work.
Posted on Aug 11, 2008
SOURCE: No sound through the Panasonic cinema surround sound on TV
Had a similar problem mate. I solved it by connecting the tv to the PT460 system with a scart lead. You then have to have the AV channel selected on the PT460 system to listen to the tv. You will always have to have the AV channel on the PT460 selected to listen to any sound transmitted through the tv - be it playstation/xbox or any other device that you may connect in the future with HDMI leads or otherwise. Hope this helps
Posted on Jan 04, 2009
  • 7 Answers
SOURCE: no sound through my lg home cinema system when watching tiv
fiirst of all you should buy a converter..........which has a multiple use
Posted on Mar 04, 2009
Tip
The Best Place to Put Your Surround Sound Speakers
If you can’t feel the vibrations everywhere—in your cheeks, ears, toes—you’re not getting the most from your surround sound system. One easy way to improve surround sound quality is to focus on speaker placement. Crutchfieldadvisor.com has a detailed tutorial, offering such tips as:
  • Place your center channel speaker directly above your TV—centered if possible. Align the front edge with the front edge of your TV screen to reduce distortion caused by sound reflecting and diffracting off the TV’s cabinet.
  • Position your front left and right speakers in front, and at equidistant points to the left and right, of your primary listening spot. Your front speakers should be at a 22°–30° angle with respect to your television.
  • The tweeters should be at ear level when you’re seated.
  • Position surround sound speakers so that they’re ear-level when you’re standing.
on Dec 18, 2009 | Audio Players & Recorders
Connecting TV, cable decoder and xr29m80
you have two choices. a newer connection you must have on both devices is a optical connection. if you have this buy a digital optic cable.
if you dont have this connection. look for a red and white connection on both devices this is just a simple audio lead .
To recieve the sound through the speakers after you have installed the leads make sure the home cinema function is set to "tv"
Aug 07, 2009 | Sony FD Trinitron WEGA KV-XR29M80 TV
The tv vibrates and distorts sound when at sound level 20 or more so I play it with 5.1 sound sistem
Yes it is just the way the speakers have been mounted with no padding on the casing causing the vibrations. A design flaw
Aug 06, 2009 | LG 32LG30 32 in. LCD HDTV
LG flat screen TV speakers make a vibrating noise
I have this problem with my 37LG30.
They all seem to have the same factory flaw.
The plastic bezel and rear is vibrating against itself I have found.
Tonight, just now, I just took all the front bezel screws out,(from the back) loosened the other 4 big screws in the rear center(I don't recommend removing them)and loosened the stand screws also and tried separating the bezel from the back as I went around the set. This did not really help much except around the bottom where the noise/vibrating comes from-the speaker area.
The two plastic pieces are vibrating against one another.
The vibrating was coming from the speaker area without doubt.
The next thing was to try separating at the bottom where the speakers are with my fingers and a stiff metal nail file carefully..fingers seemed to work best for me.
As I separated the front bezel from the rear housing (at the speaker location)most if not all the buzzing/vibrating /distortion went away.
I then inserted small pieces of cotton (you can use felt, or similar I suppose) and buttoned it all back up;put the screws in
Almost all the distortion and speaker buzz/vibratingis gone except on very low frequencies.
good luck!
Jan 29, 2009 | LG 42LC2D 42 in. LCD HDTV
Problems with sound
Bang on it when the problem appears. If the sound returns, you have a loose connection or a cold solder joint. If the sound comes and goes independently of physical shock or vibration, you have a circuit defect in the control unit and should return it if possible. A weak part will pass final test at the factory, then fail in the field after several hours.
Dec 27, 2008 | Eltax Millennium 150 Speaker
Speakers on the tv vibrate and it distorts the sound
The speakers on the Sansui aren't very good. Its better to buy a surround sound speaker system to compliment your tv.
Dec 08, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Can't get tv sound from home cinema system speakers
you need an optical cable going from the TV to the home cinema for an audio output, it worked for, had the same problem!!
Dec 04, 2008 | Panasonic Home Theater System System
Distorted sound
Sounds like you have a bad speaker or where the mounts for the speaker are broke.
Dec 03, 2007 | Televison & Video
66 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
