Question about Nuova Simonelli Mac 2000 Espresso Machine
Troubleshooting Nuova Simonelli espresso
It clicks repeatdly we changed the cold water mixing valve and now it clicks without shutting off. Before we changed it, it would at least shut off. Any Ideas?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 26 Answers
The water sonoled
You have to despatched it ,clean it you will find small break's there
Posted on Apr 19, 2015
  • 3 Answers
SOURCE: Pump keeps running and excess water goes into the cup tray
check the level probe on side of boiler may not be facing down as it should or need to be replaced.
Posted on Jan 04, 2009
SOURCE: Nuova Simonelli Mac 2000 - Boiler continues to fill up
I had the same problem of the boiler filling up all the way with water and the water was coming out of every hole in the machine. Turn the machine off, drain the boiler completely,
MAKE SURE VALVE #2 is CLOSED, this is the one under the drip pan all the way to the left. Turn on the water supply to the system and turn the system ON. The cup warmer on top will come on and stay on for anywhere between 10 to 20 minutes..... let it be,,, do not turn it OFF,, it will go off automatically. That should do it!
Hratch
Posted on Feb 17, 2009
SOURCE: Empty light on espresso machine won't turn off and tank is full
I have the same machine. I just went on the coffee geeks website and it is easily solved. Just add a few grains of salt to the reservoir - the sensor cant detect water that is purified - strange but true as four grains and it fired up just like that.
Posted on Jun 06, 2009
SOURCE: Need repair service in Denver, CO
Call Maric Beverage Systems they are very knowageable & the best service company in my opinion on Nuova Simonelli as well as all the others. 719-380-1610
Posted on Sep 09, 2009
EsWorld
  • 1618 Answers
SOURCE: mac cup V commercial Nuova Simonelli will not ****
First check the reset thermostat on the right side of the boiler below the level probe, make sure there is water in the boiler before resetting.
Posted on Nov 18, 2009
How do you manually fill the boiler tank of a Nuova Simonelli Premier Maxi 2 Group?
by opening the bypass valve under the tray need the drain. but certainly you have a problem with either pump motor or volumetric pump
Apr 14, 2016 | Nuova Simonelli Premier Maxi Espresso...
My nuova Simonelli oscar doesn't heat
This is a good little machine. its basically a commercial machine shrunk down for home and is worth repairing even if you have to take it in. go to nuova simonelli usa website and download the parts manual and check the 009500014 thermal fuse and the 09500004 highlimit thermostat and see if one is gone or tripped. check the pressure stat, check if power to elements and if there is check to make sure the elements havnt failed from being heated with no water. like i said this machine is on par with a rancilio silvia so well worth repairing.
NUOVA SIMONELLI ESPRESSO MACHINES
Apr 08, 2014 | Nuova Simonelli Coffee Makers & Espresso...
Need to drain old water from a Noava simonelli mac 2000, how do I do that?
if you look at the drain box, there is a plugged tube, remove the plug then open the bypass valve near it.
Jan 14, 2014 | Nuova Simonelli Mac 2000 Espresso Machine
No steam pressure
Leave the valve open until it starts slowly hissing, then shut off valve and wait for the pressure to build up.
Oct 03, 2013 | Nuova Simonelli Coffee Makers & Espresso...
Nuova Simonelli Mac 2000v Espresso Machinw: how do I completely drain the water tank
you can drain your machine by removing the plugging screw in the drain spout. You can see this screw where the drain water all go. it is a black plastic square thing where your drain hose is connected. After removing the plug, you have to open the bypass valve beside it and open all steam valve to make air come in. make sure the machine is cold.
Mar 23, 2013 | Nuova Simonelli Mac 2000 Espresso Machine
Nuova Simonelli Premier Maxi V , 2005...when water turned on machine constantly leaking from the pressure relief valve and the hot water valve.
Has the machine been in cold storage? If no then the inlet solenoid could be the culprit. There might be sediment keeping the valve open.
May 11, 2011 | Nuova Simonelli Premier Maxi Espresso...
Nuova simonelli vip over pressure problem
Could be lack of water in the boiler, could be a faulty pressure stat or vent valve. Check the level probe first, then the vent valve and then the pressure stat. You can also use the manual fill to make sure water is getting to the boiler.
Jun 27, 2010 | Nuova Simonelli Microbar Espresso Machine
Nuova Simonelli Mac 2000 Espresso Machine Logo
150 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
Andrew Taylor
Andrew Taylor
Gil Shultz
rhodesworks
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
