Question about Toshiba Office Equipment & Supplies
Problem in copying of Toshiba 523
Dear Sir/Madam, We have the Toshiba 523. It completely does not work in copying, although it works in first time after turning on. Unfortunately there is not any maintenance company and related services in here. It should be mentioned that the printer and scanner of the devise works properly.Thank you for your time and consideration. Best Regards, Amir Abdi
  • Toshiba Master
  • 1,087 Answers
If you try to copy, can you see the scanner light moving across? If not the lamp has failed. If it always works first time, that could be a failing lamp or a poor connection
Posted on Mar 23, 2014
SOURCE: Scanner Error Turn printer off & back on
i m italian my inglish is not good... i solve the problem clean the guide of the carrel of the light... so i can run more easy...
Posted on Nov 13, 2007
SOURCE: Devise won't work at all
I had the same problem but found the solution. Follow exactly: (1)With the power on unplug the printer (2)Open up the printer pull the ink carrier to the middle.Then raise the gray bar from the cartridges and remove the printer head (3) Lower the gray bar, with the head out, and close the printer (4) Restore the power, wait til the printer wakes up (5) The printer should then tell you to put in the cartridges (6) Restore the print head and everything should be fine.
Posted on Dec 21, 2007
  • 2072 Answers
SOURCE: service code 07.005.47:57306 on xerox 8200
That is something to do with the drum maintenance system.
1 of 2 thinhgs is most likely. Remove the maintenance tray and look at the tabs the stick out from it. About 1 inch long or less and 1/4 inch high or so. Those will wear and have sort of a step shape to them. That can be the problem itself, but more likely, the maintenance kit clutch is bad and slipping. The timing of the maintenance kit movement is off. Here is that clutch part number
401-0871-00. You can call 1-800-835-6100 and order it from Xerox, or look on google for it. I have found better prices searching, although its not real expansive. It is on the left frame, looking at the front.
You remove the left cover, the clutch is lower on the frame on the front 1/3 of the machine. Really easy to replace and I would say more than an 80 percent chance that cluch will resolve your problem.
Posted on Jul 15, 2008
SOURCE: hp psc 2175 all in one SCANNER PROBLEM
Thanks to the last comment, I was finally able to use the scanner of my printer by going through Vista Paint :) Thank you so much!
Posted on Nov 07, 2008
suben
  • 214 Answers
SOURCE: Software or driver download for free
download from hp.com by providing the above mentioned model no.
Posted on Jan 05, 2009
Hello sir copier Toshiba e studio 600. when I turn it on it shows 19 vertical lines standing in the screen display. Also it is still warming up .it makes me not able to copy . Please help me. Thanks
Display panel is properly shot. as warming up. try taking the toner bottle out after powering off. then power it on without he toner bottle let it go thru its cycle when asks for toner install
try this site for additional info
Toshiba STUDIO 520 523 600 623 720 723 850 853 Service Manual free...
Oct 19, 2015 | Toshiba Office Equipment & Supplies
Lost my cd to install printer can you help me install without the cd
Sir/Madam look for the brand or model of your printer then search it from the google,download the driver of the said model of printer or ask for another copy of cd to the store where your printer bought.Hope this solution can solve your problem.Sir/Madam don't forget me to rate me up,thanks a lot.
Jun 07, 2011 | Computers & Internet
Dear Sir, Madam My computer crashed and now all
If you have the software to your ( OS ) Operating System re-install and boot from the CD. There should be an operation for repair or reinstall for now choose repair. Allow the computer to boot and then reinstall all your software including downloading the latest drivers for your NEC be sure the drivers are compatible with the ( OS ).
Feb 28, 2011 | NEC ND-3550A DVD RW Dual Layer Burner
TOSHIBA E-STUDIO 161 error code show mw H and 4
How are you this is jack my id jack_pak@hotmail.com
your copier toshiba 161 show H...4
Dear, Follow the procedure.... press C(CLEAR) BUTON+ PHOTO BUTON+C BUTON+PHOTO BUTON..... Your copier enter special mode
Then you press 14 and start key.... copier ...ok
PLEASE VOTE ME
Thanks,
Best Regards,
Aug 31, 2010 | Toshiba e-Studio 161 Copier Copier
Sir\Madam
there is your issue you are trying to run a pirated software program. 1 this is illegal and you can go to jail for this. 2 you should go out and purchase this program if you like it.
Nov 02, 2009 | Computers & Internet
ISSUE WITH WINDOWS
It is OK provided that the Dell's Window CD's operating system is not installed on another working DELL computer. Otherwise you are violating the Microsoft license agreement.
Jan 25, 2009 | Toshiba P25-S670 Notebook
Toshiba Portege R205-S2062
Yeah i had a customer with that same problem firsti check the power adapter but it turns out it was good, then i looked at the battery but that was good as well..
It turns out the power coils on the mainboard was bad, since this doesnt have a replacable power controll circut he had to change the board.
HERE IS WHAT YOU SHOULD DO
Take you laptop to a store and tell them you want to purchase an adapter but you will likw to be sure its working. Jack it in and see if it works. If not tell them you want a battery and try it the same way. If it works thats fine if not, Tell them you want a replacement main board.
Jan 03, 2008 | Toshiba Portege R205-S209 Notebook
IDE #0 ERROR
It sounds like there is a hard-drive problem. To help you further I would need your complete laptop model number. If your hard drive is indeed dead, most likely it's not too difficult to replace and a 2.5" hard drive is not that expensive.
Hope this Helps
Nov 02, 2007 | Toshiba Tecra M2 Notebook
Oct 23, 2007 | HP OfficeJet 7110 All-In-One Thermal...
48 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
