Wd8074fhb my washing machine is working fine but its not sucking the softner when its rinse
There is no error code showing on the LCD screen
  • 1294 Answers
SOURCE: WF860 error code
Click on your model numbers (below FIXYA) on this website, & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. You might find the mysterious codes there.
And dont forget to rate me on this great site.
Posted on Jan 17, 2008
  • 26 Answers
SOURCE: Washing Machine does not work and shows error code E40
E40 is a door related problem. Possible causes are faulty door interlock or door circuit triac on the main PCB.
Most likely cause is the door interlock.
Posted on Nov 19, 2008
stephanos18
  • 144 Answers
SOURCE: Leaves white marks on coloured clothes
I'd try putting the machine on a hot fill wash, max water level put in half a cup of baking soda when the machine starts to washer turn it off and leave it to soak overnight, then let it finish the cycle the next day. Also make sure you tip some of the hot water down the beach dispenser and clean all around the top of the machine
Cheers
Posted on Mar 25, 2009
SOURCE: Washing maching not taking fabic softner.
Take the top off, three screws in the back, top front left is the dispencer assembly, you will see some crusties(thats what I call them) on the top next to the moving parts, brush them off and wet that area down and blow to remove other, The moving piece should move freely now, going back to the roman numeral one. the spring is what pulls it back to one but the crusties keep it from moving.
Posted on Dec 31, 2009
blueextc3221
  • 15935 Answers
SOURCE: Washing machine displays an LF error code.
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 07, 2010
Testimonial: "We followed your suggestion and disconnected the hoses and they had "gunk" in them. We flushed them out, reconnected and everything seems to be fine."
Water is coming up in fabric softner cup during rinse time front loader
this is normal
water should go thru the softner and into the drum when the machine rinses to introduce the softner to the drum
Dec 05, 2014 | Kenmore Elite 45986 Front Load Washer
Kenmore Oasis HE 27082 Front Load Washer
ohm the release solenoid. could be shorted or open. check for voltage to the circuit
Sep 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
I have a BOSCH washer/dryer WVTI2840 which keeps showing the error code E06. I have checked the pump and also had a new one fitted! The code still appears but now the machine will not spin on a rinse spin...
This error is indicating drain problem.You will have to manually drain the machine. E06 is a draining problem.
When you took the filter out did you check there was nothing jamming the impeller at the back?
Make sure the impeller turns ok. It should ping round in stages.
Also check were it drains to. If under a sink check the pipes there.
If after that its still not draining then its likely to be the pump which is faulty.If you have already replaced the pump then check the connection of pump to the hose.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 31, 2010 | Washing Machines
Have error code 5Ud can you explain what this is as manual does not have code listed?
It is actually "SUd" probably didn't use enough softner/too much detergent. i clear it by running "quick wash" with no addidtives, gives me two rinse cycles in 35 minutes, done.
Jul 09, 2010 | Washing Machines
Doesn't drain in rinse mode
Hi just read your posting.Now when it stalls in the rinse cycle does it start to beep and light up a couple of lights to indicate a fault code? Or do you have the LCD display model that shows the error code.If your machine shows some light on the same line of lights, there are 8 in a row , which ones are lit? Is it the 2nd and 4th or 1st and 6th--etc .Also if you have the LCD display model what is the error code?Please reply for further help.Hope this helped.
Jun 05, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fabric conditioner compartment will not empty when in cycle
FJS1225W Front Load Washer This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Zanussi FJS1225W Front Load Washer
Lg wd8074fhb will not rotate drum on was or rinse
LE=Load Error CE=Cycle Error
Unplug at socket for two hours will reset the Error Sensors. The sensors are there to prevent overheating of the motor and the possible risk of a fire.
Load Error is linked with too much weight in the drum. Cycle Error is limked with an uneven load.
If it happens again, unplug for two hours to reset the Error Sensors.
Hope this helps.
Nov 16, 2009 | LG Washing Machines
FABRIC SOFTNER TRAY STAYS FULL AND IS NOT RINSEING OUT
HiYa dh1200s
The softener tray needs to be cleaned out or the sensor for this replaced.
Yes, not enough water entering machine so not enough water to rinse out the softner
Please leave a good rating before you sign off.
Mar 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Softner does not rinse away
HI deannaschair,
ngafm to your rescue,
Happy to be of assistance.
You put the recommended cap full of softener in the draw but does not rinse away.
I have cleaned the draw and the inner part of the machine. The washing powder part is working fine.
The softener is electronically controlled and needs hands on service from a trained tech to diagnose the choise of which part needs to be replaced.
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New applinces are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
You will be fine
Bless You ,
ngafm
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Sep 10, 2008 | LG WM-12230FB Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
