Question about Toro Snowblower 826 Oxe 38624w With 3 Year Warranty26 Inch 9 Horse
Got a 1978 ds100 wont start when i put sparkplugs next to motor little if no spark but when i hold it ,it shocks me
Was thinkinging may be coil
  • 1,162 Answers
If you see a spark most likely you have enough energy to fire it. If it wont start more than likely your carb needs to be rebuilt. Kits are cheap, just remove carb, clean with carb cleaner, clean all orifices with a piece of brass or steel from a brush. Try not to enlarge the holes, blow out with air if you have it, be careful to put it back together. Clean out tank an replace fuel lines. If you have compression it should start after rebuild. If you want you can just purchase a new carb an make it easy on yourself. Somewhere between $30-50 to replace. That should do it.
Posted on Mar 26, 2014
Kohler courage 6.5hp wont start?
Could be a short in the coil for the sparkplug. Check the magneto- pull the plug wire off the spark plug and hold it close to the frame of the while someone tries to start it. Keep all parts of your body clear of the mower- only hold the sparkplug wire. When the motor turns over, verify spark from the wire to the frame. If no spark, you likely have a bad magneto coil. If you have a good spark, try taking the air filter off and use some engine starter fluid (not much) and then try and start again. If it starts and runs for a second with the starter fluid, you probably have a problem with your fuel not getting in, which leads to troubleshooting the carb and intake.
Apr 26, 2014 | Cars & Trucks
1969 triumph t120r has spark and fuel going to motor but wont start
180 DEGREES OUT OF TIME??? IF YOU HAVE SPARK AND FUEL. AFTER REMOVING ALL SPARK PLUGS HAVE SOMEONE PUT THERE FINGER OVER SPARKPLUG HOLES AND CK THAT PLUG IS SPARKING WHEN ON COMPRESSION "WHEN KICKING HER OVER". IF NOT SWITCH POINT WIRES GOING TO COILS.
Apr 10, 2014 | 2001 Triumph Triumph Bonneville
I have a 67 triumph 650 bonniville tr120 custom chopper kick start only, it wont start. i put my hands on a spark plug wire and try to kick start and it wont shock me. what could it be?
just because you put your hand on the wire doesn't mean its not getting spark, pull the plug wire off the plug,, insert a screw driver in the end of the plug wire (you'll need help with this,,) have a friend hold the screwdriver close to a bolt on the motor,, crank it over and see if you see spark , It should arc from the screwdriver to the bolt, ( it has to be very close to the bolt but not touching, if you see spark,, pull the plug,, attach the wire back on the sparkplug,, and repeat the same thing, Only place the tab of the plug next to the bolt,, spark = you have spark,, if not ,, replace the plug
May 04, 2011 | Triumph Bonneville Motorcycles
How do i check to see if im getting any spark
Pull one of your spark plug wires off and put a sparkplug in it. Touch it against the motor or frame(somewhere grounded) And crank it over. Don't hold onto the plug! It will shock you if it is getting fire!
Please Vote! Thanks!
Aug 31, 2010 | 2000 Honda CBR 600 F(4)Y
It wont start how do i check for spark it gots a 3.5l v6 motor in it
remove a sparkplug wire from the sparkplug or from a coil and place near a ground have someone crank the engine and it sound spark, you must place the open wire near a metal ground. if you remopve from coil just unplug it and leave the wire near the coil connection.
Aug 29, 2010 | 2000 Oldsmobile Intrigue
It will turn over but it wont start ? how can I test to see if I'am getting fire from the coil 1987 Nissanpickup 4 wheel drive
Take out a sparkplug, put it back into the spark plug wire. Hold the plug against a metal part of the engine and crank the vehicle over. You should see it sparking at the tip of the electrode. You can also buy a pen like device that you can hold against a spark plug wire and it has a little window in the pen. If it detects spark there will be an orange flash in the window indicating you're getting spark. You can find one of these in most automotive tool stores.
Dec 05, 2009 | 1987 Nissan Pickup
Yamaha yz 426 2002 set timing with crankshaft with index marks done this and camshafts oppisite facing , cylinder head lined with cam wheels how do i tell which is the compression stroke as might be 180...
take the sparkplug out and crank it over slowly when air pushes out is usually a compression stroke stop when the piston reach's the top..spin it over 2-3 times make sure you feel air rushing out the sparkplug hole put your finger in the hole it should push your finger out .
Nov 19, 2009 | 2002 Yamaha YZ 426 F
1978 YAMAHA RD400E NO SPARK ON ONE CYLINDER BIKE RUNS ON
Remove both sparkplugs from engine. Plug them back in the sparkplug cables and let them rest on the engine.
Make sure your battery is well charged.
Check for sparks while kick-starting...
Interchange the sparkplugs in the cables:
-Same plug give sparks: replace the spark plugs.
-Same side of engine sparks: interchange the low-voltage connector at the ignition coils.
Give it a try:
Same engine side sparks: Replace the defective ignition coil.
Other side of the engine sparks: Check the circuit harness for loose connectors, and/or Clean-replace the breaker points ( left side of the engine carter ).
Aug 28, 2009 | Yamaha RD 350 Motorcycles
No fire to sparkplug
you may not be getting electricity from the battery. you can check this but it is kind of dangerous. you stick a metal object in the spark plug cap and hold onto the other end. crank it over just a little bit and if you get a small shock then it works. you may just need a new spark plug.
Jun 20, 2009 | Garden
Toro Snowblower 826 Oxe 38624w With 3 Year Warranty26 Inch 9 Horse Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
