Question about Waterway 1.5 Hp 115 Volt 2 Speed Side Discharge Spa / Hot Tub Pump 1.5" Plumbing No. S15115
Motor siezed up and will not restart. - Waterway 1.5 Hp 115 Volt 2 Speed Side Discharge Spa / Hot Tub Pump 1.5" Plumbing No. S15115
    President:
  • Waterway Master
  • 1,378 Answers
Find a local electric motor repair shop and see if the motor is repairable. If not, a new motor and possibly the pump will be required.
Posted on Jun 14, 2009
Candy gofs262
BRUSHES ARE IN MOTORS STARTING MOTOR ALTERNATOR
Sep 25, 2012 | Cars & Trucks
Remove transmission on a 1998 Dodge Caravan with a siezed motor
I have done that job casually,I can tell you that it is safer to get down together
Be sure to remove the torque converter screws before separating the engine from transmission , May cause damage to the bushing inside the transmission oil pump
mecanica03@hotmail.com , @mecanicasesoria
May 25, 2017 | 1998 Dodge Caravan
Washer stopped working with low humming noise
Belt may have broken or come off, or idler seized or main support bearing siezed or even motor bushings may have seized. Best access is from above to check.
If you can spin the drum with ease from the inside, the belt broke or is off. If it will not turn, the motor bushings may have siezed, or the main bearing siezed.
Apr 12, 2012 | Kenmore HE2 Plus Front Load Washer
I was driving down the road my truck started too lose power and it shut off.. i crunk it back up then started back down the road and it died . i have a brand new battery with 800 cca and it could barely...
Sounds like a cooling issue. When the engine overheats it will get so hot that the metals expand making the motor sieze. When the engine gets that hot it thins out the oil making it less dense. This will make the oil thin thus reducing pressure.
When the motor restarts after cooling you will find the oil pressure returning to 40psi
The slow cranking issue is due to the engine being hot/siezed. Theadgasket damange, valve/piston dehere are other reasons for this condition to exist, but with the engine reaching 260 degrees, I would contribute it to the overheating problem.
Quite often when a engine overheats to this extent, it can cause other serious problems; ie, head gasket damage, valve/pistion deformation crack raidator and so forth , good luck
Jun 04, 2011 | 1997 GMC Sierra
My snowblower just died 2 years old its an ariens 8524 just sold it to a friend and he said it siezed up no iol is this possible or is there a saftey device on the engine that just shuts it down
there is a low oil sensor that does shut down the motor when the oil level gets to low -- fill oil to the correct height and try and start the machine.
now if the motor is infact siezed up and wont even pull ( siezed piston ) then there is a chance that the sensor failed and the machine did run out of oil and siezed up. if this is the case then the piston rings will need to be replaced.
c...
Feb 02, 2011 | Electric Garden
A/C-Heat fan rattling then siezing, blowing the fuse. 2002 Maxima
It's time to replace the blower motor, bearing in blower motor have gone bad.
Jul 15, 2010 | 2000 Nissan Maxima
Motor locked up during use pull string will not move
Sounds like your engine overheated and is siezed. Remove the exhaust muffler and inspect the piston, it should be shiny and oily. You will see if the piston is scored or if the ring is siezed. If this your problem you can replace the piston and cylinder, but it could be expensive. Stephen.
Sep 27, 2009 | Husqvarna Forest & Garden 125l 18" Gas...
Volkswagen polo, wipers just stopped working. fuses are ok...
check wiper mechanism thats connected to wiper motor,could be siezed.disconnect mechanism at wiper motor and try to move by hand,if not its siezed,needs replacing.
Sep 25, 2009 | 2002 Volkswagen Golf
Sharp ec-14twt6 won't start
if the motor spindle spins easily when turned by hand, the motor brushes need replacing. if it doesn't, either something is stuck in the turbine, or the motor is siezed. if the motor is siezed, it needs to be replaced.
Jul 22, 2009 | Sharp EC-S2365 Upright Vacuum
My wiper linkage has siezed i have removed the linkage and motor and found that the driver side spindle end is completely siezed and icant move it,the passenger side spindle end moves/seems fine also the...
it might be the motor has siezed. disconnect the linkage from the motor and turn wipers on if works then linkage at fault, if not then motor needs replacing.
Jun 03, 2008 | 2005 Ford Mustang
Waterway 1.5 Hp 115 Volt 2 Speed Side Discharge Spa / Hot Tub Pump 1.5" Plumbing No. S15115 Logo
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Craig Butler
Craig Butler
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
