Mp495 paper jam
Rollers are working fine but only right side is pulling the paper through. Why is that?
  • 365 Answers
It appears that on the left side you have a blockage.
Look at the feeder thouroughly
Posted on Mar 23, 2014
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: mp495 Pulling one side before the other causing it to jam
The roller maybe sticky and cause the paper not to feed evenly. Clean the rollers with methylated spirits.
Posted on Mar 05, 2012
My canon pixma mp495 printer keeps sayig papaer jam and pulls the paper in on one side only
There may be a bit of paper or a foreign object (paper clip, staple) stuck in the feeder rollers inside the printer. Lift and open every panel that you can and have a good look with a torch. pick out any foreign material you find.
Sep 17, 2015 | Canon Office Equipment & Supplies
Canon pixma mp495 rear tray rollers only pulls paper in on one side then it jams
When the paper does not feed straight, dirty or sticky rollers can cause it to jamb or crinkle, also failure to remove all traces of paper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these pieces of paper. The rollers may be dirty or sticky and causes the paper to not feed straight.
Try cleaning the rollers with methylated spirits.
Mar 30, 2013 | Canon PIXMA MP495 Wireless Photo...
Mp495 Pulling one side before the other causing it to jam
Mar 04, 2012 | Canon PIXMA MP495 InkJet Printer
Canon pixma mp495 error
Solution 2 is correct there is either a paper jam, or somthing obstructing the print path. First check to make sure you don't see no paper jamed, if not look in were you would put the paper to see anything that may have fallen that is causing jam, gentel turn printer side to side to see if u see hear or see anything moving around. If u see nothing then somthing has surly has fallen in printer has gotten stuck in printer rollers more then likly. To find out what's stuck find a piece of thin cardboard, I used the front cover of my phonebook and push cardbord through printer and what ever is jamimg the paper should pop out on the other side. In my case it was a flower seed and I was able to use twizzer to remove and issue was resolved. Printer is working fine
Feb 25, 2012 | Canon Office Equipment & Supplies
Canon Inkjet, Not Printing?
Hi Rosa,
There was a paper jam and you cleared the jam, however you missed out to do one other thing. Cleaning the Rollers.
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the g0081065_tcm14-774017.jpg (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Regards,Suhail
Nov 03, 2011 | Canon PIXMA MP495 InkJet Printer
CannonMP495- paper jam when there isn't
Because there might be small dust/paper part would be stucked at the roller sensor just make sure and make it clean you can find some dust or small paper piece stucked with your roller so its showing paper jam error when theres no paper inside.
Aug 12, 2011 | Canon PIXMA MP495 InkJet Printer
I have a cannon Pixma Mp495. THis morning some paper that was wrinkled went through it when it was printing. THere was not any paper left in the printer. I did pull a sheet out the top that was stuck...
I believe that you tried to turn the printer off, then on. Did you? If so, and the problem persists, I belive that the jam sensor became damaged.
In a last instance, you can turn off the printer and see if you can turn a little (with your fingers) the roller that pulls the paper.
Jul 20, 2011 | Canon PIXMA MP495 InkJet Printer
Paper getting stuck
the reason the paper is going in sideways is because one feed roller has more pressure than the other
try cleaning the rollers with alcohol and cotton cloth
If that does not work remove the paper tray t
take your fingers and see if the feed rollers turn freely or turn in only one direction( some rollers are half moon and only turn a half turn)
Just try to make sure that the roller that is not working is in the same position and turns the same as the one that does feed properly
Jan 04, 2009 | Office Equipment & Supplies
Paper wont feed propaly
Something probably fell into that tiny pinch of an area where the paper goes. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over, poke it if you have to, and shake it around til the little bugger falls out.
Sep 22, 2007 | Lexmark X1270 All-In-One InkJet Printer
Paper pull only fron the right side
You may have a jam insude the unit. Open it up as if you are replacing cartridge, check everywhere for a tiny paper jam, with a torch, near roller, carriage etc. good luck xxx lilacgerry
Dec 30, 2006 | Lexmark X4270 All-In-One InkJet Printer
k24674
