Question about Cameras
How do i remove protection from my cam - Cameras
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
You didn't state the make and model of your camera so I'm assuming it uses SD cards.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Mar 23, 2014
How do i remove protection from my cam screen
Mar 23, 2014 | Cameras
Tip
How to protect ur Digi cam?????
If u have Digital Cam and you want to protect then don't touch the cam lans because if u touch it and try to clean them u scratch the cam lens cover..after do this the pic who u capture is not so good and the life of the Digital cam is too low ...so b careful about your cam lens and cover it very carefully...if u want to clean your cam lens then u use a cotton..because cotton is less harmful for cam lens as compare to another source ..Thanks..
on Jan 27, 2010 | Cameras
Ge cam
Do you mean the memory card? SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 01, 2013 | GE X500 Digital Camera
I can't use my cam (olympus fe-340),"WRITE PROTECT" is shown
ur memory card is write protected...theres this lil switch on the memorycard jus flip it the other way n ur good as new
Jun 07, 2010 | Olympus FE-340 Digital Camera
Hello! I have a problem with my cam. When I put the memorycard into the cam, it says - memory protect! What does it mean and what should I do? Thanks in advance!!
Actually your memory card is 'memory-protected' ! You cannot use it without making it 'unprotected'.
Try these steps to unprotect it :
1. Remove the memory card from the camera.
2. On the down-end (which faces outside when it's inside the camera) of the card, you will find a small sliding switch.
3. Move the switch to the opposite direction (left or right) of the present position.
4. Now, it is unprotected and you can use it!
please rate me if it helps....tc! :)
Jan 08, 2010 | Fuji FinePix A800 Digital Camera
Fix a cambelt on a freelander
start by removing top front camshaft cover ,revealing camshaft sprockets. now jack veihcul up and place on stands. remove left hand front wheel (cam belt side) . remove power sterring belt and alternater belt.looking at crankshaft pully and using an 18mm socket and bar rotate pully until all three marks line up. crank on 1st timing mark and and cam marks facing each other when all three line up you can then remove crankshaft pully , you will need an impact wrench that can torque up to 300lbs .when pully has been removed you can then remove the lower belt cover you will then see the belt tensioner and unbolt and remove , now place a jack with protection under sump and remove bolts on engine mount, when you have separted the 2 halves of the engine mount you can remove the belt and install new belt , k,series cam holder tool is use full for re-alineing cam marks camshaft marks facing each other and crank line up with raised mark on engine block,it is then a case of putting every thing back inthe same order it came off.there are 2 type of cam belt tensioner you can email me and i will tell you how to do each type. marcusloud@blueyonder.co.uk.
Sep 11, 2009 | 2002 Land Rover Freelander
Unwrite protect olympus Fe 280
go to set up and reformat. This will fix the problem
John Harlow
Jun 20, 2009 | Olympus FE-280 Digital Camera
Protected pics on cam
remove the memory card, there is usually a switch on them - move it to the other position.
its to protect the data on the card (so you can't write to the card).
Mar 22, 2009 | HP Photosmart R927 Digital Camera
Paper feed
Your friction pad needs replaced
P/N RF5-2886
Remove toner cartridge and protect from light
carefully pry off two blue base locks.
remove rear cover screws and pop off back cover
facing front of printer open cover remove paper feed tire and note position of driveshaft {2 screws}
engage paper feed cam solenoid with small screwdriver and using main drive motor spin release cams to lowest point of resistance
carefully pry separation assembly from printers frame and install new one noting spring on rear of assy'
when installing new pad if you have difficulty rotate cams via main drive motor to allow more clearance.
reassemble and be careful when installing feed tire on driveshaft .
Jul 10, 2008 | HP LaserJet 1100 Printer
Cameras Logo
13 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
