Question about Electrolux EI26SS55GS Stainless Steel Side by Side Refrigerator
Error code throws up and frigerator continues to blink on and off over and over
When u open doors lights blink on and off with the fridge
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Not knowing the error code , be shure the wall plug is good, if loose the movement of opening the door dould cause it blink
Posted on Mar 24, 2014
  • marlin siecinski Mar 24, 2014
    not knowing the error code , be shure the wall plug is good, if loose the movement of opening the door dould cause it blink
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Have to slam freezer door to clear 88 error codes on samsung refrigerator
I am not certain on this, but my guess is that you have a problem with the door closed sensor, which should be attached to the door/ light actuating button. It may be faulty, or just out of adjustment. I assume that you have contacted Samsung about what error code 88 is. Do they have any other input? What doesn't make sense is that the fridge turns off. You would think that if the door sensor read "Open door" it would continuously run, rather than shutting off, unless it is causing an overload, or overheating condition. I have had good luck w/ Samsung tech dept., but they can be a little hard to reach. Hope this helps.
Mar 10, 2014 | Refrigerators
Fridge is constantly beeping at around about 2-3 second intervals and whenever I open the door the sound continues and the light inside flashes to the beeping sound.
most of the time the beep comes from the door being ajar i just finshed a chat with a gentlemen that because he had to much on his door he bent his hinges which caused a 1/8" gap in the seal of the door best thing to do is get some vaseline go over your entire seal if the seal is in good condition if its not replace the seal also check your upper hinge to make sure if it has an adjustment to move the door in closer if it doesnt then you would have to replace the hinge like the other gentleman i just finshed with has here is a complete schematic of your frigerator if you have any further questions message me back and if the door seal and hinged is ok message me back as well thanks again Rick
Jan 11, 2011 | Whirlpool GR2FHMXV Top Freezer...
I have a craftsman 1/2 HP door opener. When I attempt to open the motor clicks but there is no movement. I have tried reprogramming but the issue continued. The indicator on the back is blinking, the light...
Check your door springs. Could have a broken one. Also remove the cover from the motor unit and check the drive gear. It could be stripped. If the light on the back is blinking randomly that is normal. It can also send a code. See if it blinks a number of times, pauses and then repeats.
Aug 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Service light is blinking & code 06 EC flashes on Sub Zero 650
Turned the breaker off to the fridge for 15 minutes and turned it back on.
Jan 01, 2010 | Sub-Zero 650 / O Bottom Freezer...
LG WF-T700 Troubleeshooting DE blinking
The "DE" code indicates a door open error. This can be caused by the door not closing all the way (this could be because of bent door/hinges or the door gasket bunching up and not permitting the door to close properly), loose electrical connections at the door switch or powerboard assembly, or the door switch itself is faulty. It can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity would mean a bad switch. Also check the door gasket for "bunching" and you can unplug and reseat electrical connections. These are some areas to look at. Be sure to disconnect unit from power before attempting any repair/troubleshooting. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 28, 2009 | LG WFT1071TP Top Load Washer
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Fridge temp goes up and ice forms in fridge
CHECK THE BAFFLE IT MIGHT NO BE OPENING OR CLOSING PROPERLY, THAT`S THE SMALL DOOR LOCATED @ THE LEFT UPPER CORNER OF THE FRIGERATOR
Aug 19, 2009 | Samsung Refrigerators
Frigerator throwing off an odor
Begin by carefully wiping the door gaskets down with 2 cups of vinegar in 4 cups of water. If that doesnt solve it wipe down the entire inside of the fridge with the vinegar water and then put an open box of baking soda in their.and leave it to absorb odors.
Jun 23, 2009 | Jenn-Air JFC2089HE French Door...
Electrolux EI26SS55GS Stainless Steel  Side by Side Refrigerator Logo
79 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
