Lg flatron w2453
With PC in DVI port stays in standby mode on PC turn on. Monitor starts working after some resets. Works fine if before turning off PC switch monitor to analog output.
    Problem Solver:
  • 24 Answers
Tried to understand, but I really can't. Can you please reformulate ?
Posted on Apr 16, 2014
SOURCE: Connecting an LG TV to my PC
switch to any setting as long as it is only in 60hz and nothing above that the monitor cant handle it
Posted on Sep 11, 2008
  • 414 Answers
SOURCE: Computer not communicating a signal to monitor
You can fix that by getting a new graphics card
I'm assuming you have a T3830 emachine.
here's the link to replace video card
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
Mark
Posted on Apr 09, 2009
  • 76 Answers
SOURCE: DVI output problems with Acer Veriton M464
If you are comfortable with opening the case, you can try this: Unplug the power supply, make sure are constantly grounded (touching metal)remove add-in video card. Locate the "Clear CMOS" jumper (usually 3 pins in a row with two shorted via a plastic jumper). Remove the jumper and short the other 2 pins (if originally pins 1-2 with 3 open, short 2-3 with 1 open) for a few seconds. Then replace on original pins. Plug monitor into motherboard video port and power on. If it works, you can leave as is or try to re-install your video card following the same precautions when opening the case and probably changing BIOS settings to utilize the add-on card.
Posted on Sep 12, 2009
Jta91
  • 99 Answers
SOURCE: My hp2009m monitor goes into sleep mode
Monitors are programmed to go to sleep when there is no input. If you shut it down on the other "tower" also it will do the same. You need to physically hit the power button on the monitor to actually shut it off.
Posted on Feb 24, 2010
  • 25 Answers
SOURCE: LG flatron w2061tq unwanted standby power saving mode
Go to "start>settings>control panel>Display>Screen saver>Power>
Turn off monitor : Never
System Standby : Never
I have tested and its working fine.
Thanks,
Viju
Posted on Apr 08, 2010
Flatron W2353 monitor wont turn on
LG W2353 dvi power saving mode
how to fix ?
Dec 22, 2012 | LG FLATRON W2353V 23 inch LCD Monitor
I bought a new LG Monitor, W1946S, a couple of days ago. First time I used it after connection it worked fine, since then it is in Power Save Mode when switched on and stays that way. If I press the...
Firstly take it straight back and change it, if its a hardware issue then you want it changed sooner rather than later when it might run out of short term warranty.
Secondly, be sure that the vga/dvi cable is plugged in securely at both ends, it has to recognise the signal from the pc to turn its monitor on and start displaying. But change the monitor and fast!
Jan 07, 2011 | LG Flatron L1951S 19" LCD Flat Panel...
Thanks,
Viju
Apr 08, 2010 | Computers & Internet
Lg flatron w1952tq goes into power saving mode on boot computer works fine on other monitor. Running Kubuntu linux.
your LG monitor is bad then if you put another monitor on the computer and your getting video. Just as a last resort, you might want to put the LG monitor on another computer and if it stays in sleep mode then you know for sure at that point, the monitor is bad.
Feb 06, 2010 | LG 22" FLATRON LCD Monitor
Screen flashes on for around 1-2 seconds before turning off
Your TV has a defective component on the power supply section. Need service by electronics technician.
Jul 27, 2009 | Computers & Internet
LG Flatron - Power button flashing blue
i get a similar thing, i accidently entered sleep mode then turned off my computer at the power button on the back, now i turn on my monitor( i dont get blue flasjhing but it jsut goes on and it doesnt register, then says going into power saving mode and the colour on the button turns yellow its very frustrating :(
Apr 20, 2009 | Computers & Internet
LG FLatron W2252TQ Not working properley in DIgital mode.
Fixing power problems with your LG Flatron Monitor (LG1753S) ' Just ...
blog.lopau.com/fixing-power-problems-with-your-lg-flatron-monitor-lg1753s/
Fixing power problems with your LG Flatron Monitor (LG1753S) ... So after checking the power isproperly plugged, I shut down my pc again. .... I can start a game and then change the resolution, Popp of "energy saving mode digital" led goes ..
Mar 21, 2017 | Computers & Internet
22" flatron (W2252TQ) Monitor Will not stay on after windows logo comes on
Reboot the computer and start in safe mode.(Press F8 at start-up in WIN XP).Change display resolution to 800><600 and restart in normal mode.
Your original problem must be monitor hardware related ie some loose connection or dry solder on invertor /power board inside the monitor.
Please provide feedback and rate the solution.
Samir
Jul 25, 2008 | LG Computers & Internet
Analog power save mode
Are you connect via Analog (Blue VGA connection) or DVI (White Digital connection?
If you are connected via DVI, then you have to change the input select button to DVI
If you are Connected VGA, make sure the system doesn't have 2 VGA ports. If it does, connect to the other port.
May 02, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
