My siemens siwamat 565 washing machine
Door handle is broken and couldn't open the door please I need to know how to replace it and what is the reference of the door spar part to buy thanks in advance
gittos73
  • 244 Answers
SOURCE: Broken door handle for a Thor washing machine
there r 2 ways to get the door open 1)use a normal knife and place in front of the door handle push it in and it should open 2)pull the plug out take the lid off now place your hand down to where the catch goes into the washer using your fingers u should be able to pop it open with a bit off fiddling
Posted on Dec 16, 2008
  • 566 Answers
SOURCE: door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Posted on Feb 16, 2009
  • 13 Answers
SOURCE: Siemens Siwamat c12 manual needed
This site says they have the manual. I see it is not free, no idea how much they charge for manuals etc. Hope that will help you.
http://www.manualsnguides.com/search.php
Posted on Jul 17, 2009
SOURCE: Siemens Siwamat 2105 washing machine leaking
Ater beeing switched on the machine does not fill with water.
Posted on Jun 22, 2010
supernova278
  • 1932 Answers
SOURCE: Users manual for a Siemens combined washing
You can get your user guide from below website
https://www.2instructions.com/search.php?cmarque=SIEMENS&modele=SIWAMAT%20PLUS%205431
Thank you
Posted on Oct 14, 2010
Siemens siwamat 6140
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTMUse the link, you will need to enter the Enr number which is on the rating plate and should start W...
Nov 22, 2011 | Siemens WDi1640 Front Load Washer / Dryer
I can't get the door open on our washing machine, a SIWAMAT XLS 1650. Is the locking mechanism electronic, or mechanical?
The locking mechanism is electromechanical. If the machine is switched on for its cycle & then off, it takes about 2 minutes to open. In normal course it should open it immediately. Your locking mechanism is stuck & needs to be replaced.
Sep 18, 2011 | Siemens Washing Machines
I have a broken door catch for a Siemens Siwamat XB 1061. Can I get a replacement part
I feel for you because we have exactly the same problem : our door broke, the handle in fact. Everything else works wonder but the screw driver trick is bound to give in one day eventually and we'll be left with no washing machine at all. Has anyone found any infor on the door anywhere? thanks guys
Mar 19, 2011 | Siemens Washing Machines
Hi there does the siemens siwamat 6102 washing machine have an hot water inlet valve, Regards Robert
Yes - mine has just frozen in the garage and cracked whilst defrosting. Water everywhere. Does anyone know if I can bypass it and run the M/C on cold only?
Nov 25, 2010 | Washing Machines
Jul 17, 2009 | Siemens Washing Machines
Using of Siemens Siwamat
press the start button after the door is closed.
if it does not start - the door switch/latch is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Siemens Washing Machines
My siemens washer will not pump the water out or spin
Sounds like your pump went out on the machine. They are not ease to replace though. You might want to kall some one out to fix.
Dec 16, 2008 | Frigidaire ATF6000ES Front Load Washer
SIWAMAT 6102 (GB) Code 3 Flashing. What does this error mean
The pump was working but not pumping. The rubber hose from the bottom of the drum to the pump was removed and found to be partially blocked. The debris inside the rubber hose was cleaned out and reassembled with no further problems.
Sep 07, 2008 | Siemens Washing Machines
Washing machine
is all the water out of the machine if not the door wont open.
if all the water has gone, have a look behind the small flap on the front of the machine where the filter is and there might be a small plastic loop which when pulled should release the door catch.
please note i say might as some models have this feature and some dont.
hope this helps
Jul 22, 2008 | Washing Machines
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
