Question about Dell Computers & Internet
Dell XPS 8300 CD (rewritable) tray broke in half from an accidental downward force; I still have the piece that broke. Is this something someone can tell me how to replace internally? Would an external drive work just as well if connected via USB? I need specific details (links if possible) for instructions. Am medium tech savvy, have done operations on the inside of my computer before and feel comfortable with that, but if external is just is good would rather do that. I just sometimes need to load programs that come on CDs and would like to burn them again. Thanks in advance for any help! Kirsten
  • Kirsten Chepeus
    Kirsten Chepeus Mar 23, 2014
    Hi Brad, Do you mind going to amazon.com and telling me which one specifically to buy? Hope that's not a pain. Thanks!
  • Dell Master
  • 16,387 Answers
You can replace the drive with any internal dvd read write drive
Posted on Mar 23, 2014
  • Brad Brown Mar 23, 2014
    Post the service tag number!
  • 13 Answers
SOURCE: Matshita UJ-840D CD-Rom Drive
it seems that the best firmware for your drive is here:
http://www.techzilla.info/uploads/MatshitaOEM.rar
read the nfo inside.
Posted on Mar 08, 2008
Fixe_You
  • 1800 Answers
SOURCE: Dell XPS 200 CD/DVD reading problem?
the reade part of ur CD/DVD drive is damaged while the Burner is still ok .
1/use the cleaner disc.
2/replace the part.
3/replace the drive as a last solution.
plz do rate this post.
Posted on Dec 29, 2008
rtrahan
  • 741 Answers
SOURCE: my windows media player wont burn cds no more
The free one with Dell does not burn CDs it only writes data..download a good free DVD burner like ImgBurn from CNET.com and save yourself some headaches.
Rate this solution
Posted on Mar 15, 2009
louislevel_2
  • 374 Answers
SOURCE: I have corrupted files in Windows XP and EMachines
hi there! if you can configure your bios set up and go there, priority yout cd rom as first on the list,2nd your hard drive, in able to start and configure your windows set up promptly.How to open your bios set up,after switching on your pc, press F2 or delete depend on your start up windows appear on left bottom of screen if cmos/bios appear on blue screen select the boot sequence and arange the list of booting up your windows.In your screen resolution this will be adjusted after you finished the windows set up to new xp,you can adjust your scrren resolution, by left clicking on your windows xp on screen,click proreties, on properties box there adjustment of screen resolution there slide function key to 1680 X 1200.then click apply,click ok then restart your pc for effetivity or sometime it was auto restart after you change your screen resolution...,regards
Posted on Mar 27, 2009
leecom72
  • 4806 Answers
SOURCE: My Compaq Presario desktop will not burn CDs
Perform a system restore and take the computer back to a time before the problems started with burning, or you can download a different media player and try burning with that, real player as a good bit of software to use for burning and Nero is too (Nero is a devoted burning suite)
Get real player here >>>>>>
http://uk.real.com/realplayer/
Get Nero 9 here >>>>>>
http://9-burning-rom.com/index.asp?aff=101&camp=gg_nero_uk&se=google
Good luck
Posted on Jul 08, 2009
Its not booting and the back light a and c are yellow
The service manual for the Dell XPS 8300 doesn't show ABCD LED diagnostic lights. On other Dell models Y-G-Y-G indicates a video problem.
Mar 12, 2015 | Dell XPS 8300 Desktop
Sata port 2 does not work
Remember always downwards compatible as a rule of thumb. You may not be able to connect a SATA 3 drive into a SATA 2 port.
Ports 2 and 3 are SATA 2.
http://support.dell.com/support/edocs/systems/xps8300/en/sm/techov.htm#wp1268982
GL
Nov 12, 2012 | Dell Xps 8300 Desktop Computer (Intel CORE...
Won't Boot after pressing the power buttton
Unplug the tower and press power button for 60 seconds, if this fails the motherboard should be suspect, check all plugin connections to the motherboard especially power supply connectors.
Jun 17, 2012 | Dell XPS 8300 Desktop
Ram rewrite error on dell 8300
One of the ram memory is bad, sub out one stick at a time till you find the bad one.
Jun 03, 2012 | Dell XPS 8300 Desktop
How to burn a CD using the desktop DELL xps 8300
If you have a CD-ROM burner installed into the tower (The hardware and drivers in place) You can usually burn an audio or video CD using iTunes, or download and try out Nero in order to burn data CD's
Aug 15, 2011 | Dell Dimension 8300 PC Desktop
Dell XPS 435T/9000 Drive F drive tray auto opens and closes. Will not remain closed after CD drive inserted. Can activate open and close ok from side switches, but drive tray will not remain closed with or...
That's probably someone who pranked you by setting scripts or programs on your machine to do that. Just run dtrace or something to find out what programs are looking at media status (for 'closed') and decide whether any of them aren't familiar. Depending on your OS it could be a pretty small script or program....
It may on the other hand be something familiar whose backup function you haven't used or addressed in a while....
May 23, 2011 | Dell Studio XPS 435 PC Desktop
Stuck cd inside dell xps laptop's cd drive. How to remove outside?
I had the same issue with my Dell XPS 15z, after looking every where to get instruction to get the CD out. I decided to call Dell Tech Support and it did work.
1. Turn off the laptop
2. Turn on the laptop and press F2 several times until the setup menu come up
3. Then press the eject botton from the keybord, the Cd should come up.
Good luck
Mar 13, 2011 | Dell Studio 15 Laptop
SGI O2 CD-ROM drive tray repeatedly opens
I am having the same problem. I haven't resolved it entirely, but at least I managed to get it working again by the following steps.
First, disassemble the part of the computer chassis around the CD-ROM drive. Follow the instructions for "replacing the CD-ROM drive" in the SGI 02 hardware maintenance manual. It can be done in 10 minutes with a screwdriver.
After you have gained access to the CD-ROM drive itself, take off the top metal cover. Then you will be able to see the tray and the white gears underneath.
In my case, the problem seems to be caused by some misalignment between some wire springs and the white gears. Note when the CD tray closes, the manual eject button (a black plastic rod on the right) should stick out, and the white piece of plastic with a triangular end on the left should push against the front of the CD tray.
Somehow, the gears failed to push the white plastic piece all the way to the edge of the tray, and the CD-ROM drive thinks the tray wasn't fully-closed, and ejects the disc.
To force the drive to read the disc, pull the white plastic piece on the left with the triangular end towards the edge of the tray. (Pull it towards you if you are facing the front of the drive.) You might need to use some force, but I can get the drive to work this way, even though it still "sticks open" half the time.
Good luck, and if you happen to find a better solution, I look forward to hearing it.
Jan 07, 2009 | SGI Silicon Graphics (P-CDR32-EXT) CD-ROM...
My dell xps wont run my dvd
you have a few options, 1. call the xps support line. 2. try running it in windows media center.
Dec 24, 2008 | Dell XPS M1530 Notebook
Computers & Internet Logo
32 people viewed this question
Alun Cox
