Question about Whirlpool LER5636P Electric Dryer
My whirlpool dryer will not start - Whirlpool LER5636P Electric Dryer
  • 6,784 Answers
OK, check the following areas to combat this no start issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
If all the above checks out ok, replace the timer or control board.
Posted on Jun 18, 2009
98 series. Why doesn't it run?
Kenmore Whirlpool Dryer Won't Start - Easy Fix - YouTube
? 3:52
https://www.youtube.com/watch?v=MhVUEhngZMg
Jul 21, 2012 - Uploaded by Bill Newberry
This video will show you what you need to check if you press thestart button on your Kenmore or Whirlpool Dryer and it does notstart up. ... the button won't start it, and putting those wires together doesn't start the dryer, what ...
What to Test When Whirlpool or Kenmore Dryer Won't Start ...
? 7:17
https://www.youtube.com/watch?v=sTRP6kHqAFs
Jan 24, 2013 - Uploaded by canyonman1963
What to Test When Whirlpool or Kenmore Dryer Won't Start orRun ... discusses all of the common causes of an electric dryernot starting or running. Category. People & Blogs. License. Standard YouTube License. Show more
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...
? 7:29
https://www.youtube.com/watch?v=SPRqKVE8JfY
Oct 21, 2011 - Uploaded by canyonman1963
This video is the 2nd of several that will show you how to diagnose and repair a Whirlpool or Kenmore electric dryer that will not start or run.
Jan 13, 2016 | Kenmore Dryers
Whirlpool electric dryer will not start when start knob is pushed
First check beaker flip it off than back on next check the door switch if tab missing or loose it should spring back when pressed next the dryer may have over heated the thermal fuse may have blown
Nov 03, 2015 | Whirlpool LER4634J Electric Dryer
My whirlpool dryer won't start. I have taken the
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 20, 2011 | Whirlpool Dryers
Whirlpool duet dryer Starts and runs a couple of
This website may help Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 19, 2010 | Whirlpool GEW9200L Electric Dryer
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool dryer does not start and beeps.......
Same problem here, however I can assist the start by rotating the drum while pushing start. May be a capacitor problem???
Jul 25, 2008 | Whirlpool GEW9200L Electric Dryer
WHIRLPOOL DRYER WON'T START
It may be as simple as a thermal fuse. Some Whirlpool dryers have power for the motor going through the theraml fuse.
Mar 08, 2008 | Whirlpool LEQ9858P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
577 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
