Not draining Has anyone the solution of how to solve the problem of what was first a crackling noise when draining. While now its stopped draining altogether and cycle just stops. There is ,also no normal drain pump sound,when machine attempts to empty. It then reverts to the 'Ready' light on front panel. The machine fills up and continues as normal until this happens. Could it be the drain pump needs replacing?
    Problem Solver:
  • 17 Answers
With front loading machines this is VERY common. My teenage Daughters wear underwear that are so tiny that they get past the drum lip and get wound up in the pump impeller. Same thing happens with stuff left in the pockets specifically coins.
At the bottom usually the front of the machine there is a bailing tube next to the pump. Take the plug out and put it in a shallow basin to drain the water out of the drum. Then remove the pump access cover, it usually twists out. Then remove what ever treasure is jamming up the pump. Put the cover back on, put the plug back in the drain tube and if you like add a quart of water into the front of the machine to prime the pump again. Then test the machine.
To keep this from happening they make laundry mesh bags - if you use them then nothing will clog the pumps ever again. I tell my Daughters to get underwear that actually covers their butts. For some reason my plea falls on deaf ears. Go figure.
Posted on Mar 23, 2014
SOURCE: SPIN CYCLE
Front load Neptune model
Posted on Nov 25, 2007
  • 1294 Answers
SOURCE: LG Fuzzy Logic won't drain out the water
Click on your brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line. And dont forget to rate me, on this great site.
Posted on Dec 21, 2007
SOURCE: Washing machine will not drain
I have a maytag washer that when it fills with water it wont drain out..the spin cycle just makes a noise and it wont do anything..any ideas what i can do to fix it thanks
Posted on Nov 24, 2008
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
I have a samsung dishwasher that won't drain it makes a cracklings noise then the quick light starts flashing if I unhook the drain line and hold it lower in a bucket it will drain
If it is making crackling noises, it has water on electrics and is shorting out. Unplug it a call a technician before you have a fire.
Unhooking the drain line and lowering just allows water to flow past the pump.
samsung dishwasher Google Search
Jul 10, 2017 | Samsung Dishwashers
How can I solve my problem of crackling noise coming from speakers when turning channels?
Are you meaning it crackles when turning a tuning knob? If so, it means the pot is dirty and needs a shot of cleaner.
Feb 25, 2016 | Audio Players & Recorders
Running a heavy load; stopped during rinse cycle; won't drain or spin;
There may be something stuck in the pump, did you hear a buzzing or crackling noise?
Jun 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
LG WD-3243RHD Front Load Makes grinding, crackling noise
Check the motor at the bottom of the machine. Also check the timer on the unit to make sure the timer is work
Feb 10, 2009 | LG WM2432H Front Load Washing Machine
Ge Triton dishwasher will not drain and makes a funny noise.
Yes!! The crackling noise you hear is small pieces of food stuck spinning around the moter drain....All you have to do is find the drain hose (some are located under the sink of the kitchen) disconnect it from the draining source (not the back of the dishwasher) now run a long thin wire through the drain hose line poke around and pull in and out!! it may take a few tries but its better then a large Bill!! replace hose and hit drain button!!
Please rate response and help keep this site free!
Jan 06, 2009 | Samsung HL-S5087W DLP TV
Crackling noise
I think I have solved the problem. I dusted the tv completely. Then took the cable box and with a hair dryer in the cool setting blew out the interior circuits to try to remove all dust. Turned the set on no more crackling. Thanks for the posting.
Nov 14, 2008 | Olevia LT37HV 37 in. HD-Ready LCD...
Intermittent Crackling noise in the right headphone
Hello Rachel, I use my QC3 for 2.5 years Mon-Fri for 3 hours a day. I have the same problem when battery is weak and/or it is cold outside. The cracking nose stops for me if battery fully charged. This is known problem andBose put it in the manual.
Vlad
Aug 28, 2008 | Bose QuietComfort 3 Acoustic Noise...
Fixed!
"LE" code Stator/Motor Error.
It was a simple fix and only cost $17.68 at PartStore.com no affiliation.
Hall Sensor 6501KW2001A
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6501KW2001A/New.aspx
Here is the Service Manual
http://oasisappliance.com/products/lg/LGComboServiceManual.pdf
Bonus, it actually completes a wash cycle and does not stick at 6 minutes, drying forever.
Freakin service tech stated it was the Power Control Board, IDIOT!
While I was in there, I cleaned out the heater blower assembly and sensors. They were full of caked on lint and the sensors had debris all over them.
Also cleaned out all the lint and debris around the rubber seal, this will eliminate those annoying mildew oders.
Hope this helps someone, Happy New Year!
Feb 11, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
