Question about Tomtom VIA 1605TM - GPS receiver
Not working after update
Update will not install to unit
Kenwood kna-g610 map upgrade problems
Which Garmin update did you use?
The correct update is Garmin Part Number: 010-10679-13.
You may also want to contact Garmin Support for assistance.
1-800-800-1020
Jan 08, 2012 | Kenwood Kna-g610 Car GPS Receiver
How often do I need to update my Magellan 2200t gps.and how do I do that????
When available, map updates can be purchased from the Magellan website. For the latest map update please visit our software page by Clicking Here
2010 Spring Map Update has been released. Please refer to the map's product page for unit compatibility and installation instructions. You may need to install Magellan's Content Manager on your PC in order to download the latest maps for your unit. To install the Content Manager please click here
*For specific map update installation instructions please see the installation instructions included with your map update version.
Hope helps.
Apr 09, 2011 | Magellan RoadMate 2200T GPS Receiver
How can i download philippine map on my magellan roadmate tnxs
Hope helps.
Apr 09, 2011 | Magellan RoadMate 1440 Car GPS Receiver
Failure to initialize after a microsoft update was installed
Go into the control panel and find the device manager. Then locate the UPS unit and right click and update driver. Then pick roll-back driver. This should install the prevous driver that was working properly. Then when you do windows update make sure to set it to hide that update so you don't re-install it again.
Sep 26, 2009 | Cybernet Systems CyberPower CP1200AVR...
I have had a mackie onyx satellite preamp for over about 2 years and it has worked flawlessly for recording on my computer. A week ago my computer suddenly couldn't find the unit when I turned it on and...
Did your computer recently update? If so, any changes to any drivers might be causing this issue. It's not good to regularly download and install Windows updates, as most are not stable releases. Download updates only after stable releases have been issued. Or, don't do the update at all, unless it's a security update.
You'll probably need to contact Mackie Support for this one. They might have to send you updated drivers or update the firmware on your unit to address this problem.
- OPTiC
Master Tech
Digital Analog Therapy
Mackie Parts : Mackie Repairs
Aug 29, 2009 | Audio Players & Recorders
Plz help...
A firmware update. Same happens to my friend's unit yp-u2(x) a 512 mb model.
In XP OS.
1. Download and install firmware updater.(manufacturer's support site)just key in model number and type.
2. Run updater, press and hold play button until its been detected fully by the updater.
3. Check the format box(My friend's unit firmware ver is 1.xxx to 2.xxx something when updated).
4. Hit the update button or something like that. do not detached the unit until its done. Unmount the unit using unmount method "Safely remove hardware".
5. Turn on the unit it should pass the 20 percent mark. When its good it has no file yet coz of format option. Just load your song.
I think it happens when too much file is upload in the unit. 60 percent of its capacity may be enough.
Hope it helps............
Jan 16, 2009 | Samsung YP-U2X Digital Media Player
How to update softwrae
The simplest thing to do is as follows: Go to the following website-
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Follow the instructions from there which state:
WebUpdater is a free application that lets you update your unit software from home. Download it once at the link below, and you can check for and install software updates without using your Internet web browser. Simply run WebUpdater from your computer, and it will do all of the work for you.
Step 1: Download and Install WebUpdater Click the link above to download WebUpdater. Next follow the screen prompts to install the application on your pc. If you have already installed WebUpdater on your computer, skip to step 2.
WebUpdater updates most Garmin products, excluding Palm and Pocket PC devices, fixed-mount marine units, chartplotters, fishfinders and certain discontinued units we no longer support. It does not perform Beta updates. WebUpdater only updates unit software. See our All Updates & Downloads web page for related utilities, drivers, add-ons and the unit software for the excluded units mentioned above.
Step 2: Connect GPS to PC and Run WebUpdater After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater".
Hope this helps.
-Martin
Nov 06, 2008 | Garmin eTrex Legend GPS Receiver
Voice is on but the unit stopped talking.
I don't know if this will help any, but when I updated my recently purchased tomtom go 720 with the newest app (8.3) and the new voices, map, etc...the voice feature completely stopped working on my unit. Everything else was working fine except the voice. However, I had installed an 8 gig sd card into my tomtom and put all the updates on the sd card because I was running low on the internal memory. Bythe way, only the voice instructions were not working..it would still play mp3's through the internal speaker, so I knew it must be a software problem. After several days with no voice instructions, I then proceeded to re-format the sd card and start all over, as the problem appeared to be a software issue. After re-formatting the sd card, I removed it and installed the back-up file from my tomtom before I did the first update. This time, I deleted a couple of the voices in the update package, so that I would have enough room to install the updates to the internal memory. "Bam" now everything is working perfectly again. I believe for me...the tomtom was having trouble communicating with the new application that I had previously installed on the sd card. I hope this may help someone.
Sep 28, 2008 | Tomtom GO 720 GPS Receiver
Update my garmin streetpilot i3
GARMIN offers a free download called "WebUpdater" for these products. Once you have the GARMIN USB driver for this unit installed on your computer (also avail. at GARMIN.com), you can run the WebUpdater, and it will update all known updates to the unit.
Downloads here
Installing "new" maps...
If you don't mean "updated" maps, then you would have to use another GARMIN mapping product like MapSource, then load the new maps into the unit via an SD FLASH card.
Mar 09, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin etrex legend
I had this problem today, updated the software, now the unit seems to be working perfectly. The unit "crashes" (single line down screen center) as soon as it get enough satelites to work with WAAS.
Go to Garmin site for software updates. Download and install the WebUpdater. Once or unit is hooked up to your computer and you have internet access, the software will download and update your GPS with the latest software fixes. I had software Version 3.7. For the Legend, Version 3.9 fixes the problems with WAAS.
Jan 04, 2008 | Garmin eTrex Legend GPS Receiver
Tomtom VIA 1605TM - GPS receiver Logo
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
