Question about Ovens
Main oven doesn't come on
My bottom oven does not come on although the top one does , there are three buttons that operate the timer that do not appear to be working could this be my problem
    Prodigy:
    An expert who has answered 500 questions.
  • Ovens Expert
  • 650 Answers
Check to see if one of the knobs on the timer has a "man" setting. This is for manual. Many times the clock will shut off the oven and moving the clock dial to man will close the switch in the clock to allow the oven to work. If it doesn't have this "man" setting check to see if there is a start and stop time. Make sure the start is out and the stop is pushed in.
Posted on Mar 29, 2014
Amigaman
  • 248 Answers
SOURCE: Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Posted on Nov 04, 2007
SOURCE: Main bottom oven not working
i solved the problem by replacing element . new one cost 23 euro from electrolux spare parts dealer .1 undo 4 screws of plate inside the bottom oven . [ plate has holes in a circle patern in the middle of it ] . 2 gentle remove plate and expose the element .3 element has 3 srews .undo these and gentle take away from ovens backwall wall this will expose 2 wires that are connected to the element .3 very gentle unclip the wires from element . {grip the clips not the wires } connect new element and replace all screws and outer plate . this worked for me ....... remember to turn off the power to the oven before you go at it .
Posted on Apr 17, 2008
  • 1214 Answers
SOURCE: bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
Posted on Jan 14, 2009
  • 228 Answers
SOURCE: tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Posted on Jun 05, 2010
barkencoa
  • 3463 Answers
SOURCE: I have a Hotpoint BD32 double oven. The top oven
You need to replace the oven element,, located at the rear of the bottom oven compartment behind a removeable panel.
Posted on Oct 03, 2010
Frigidaire wall oven CPEB30S8CC2 lower element does not work
We have a Frigidaire CPE30S8CC2 with the bottom bake element not working. We tried to replace it with no luck. The old element does not look burnt out at all. The timer, clock and broil all work just fine. The bake button works and you can set the temp. it just doesn't actually heat up at all. There are no knobs on the controls for any cook top. it is all on a circuit board for overn only. help?
Jul 16, 2012 | Frigidaire Ovens
The main (bottom) oven does not seem to be heating up. I can hear the fan working but that is it. The make and model is Zanussi ZKC5030X1 I have tried the obvious solution, or pressing the buttons...
Most likely it is a failed heating element although it could also be a faulty thermostat, the only way to tell is to have them checked over with a circuit tester which will tell you which it is
Dec 14, 2010 | Ovens
Tecnick tck 8522/2 oven
Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
We have Smeg DUCO8CSS double electric oven. Bottom oven does not work, clock is blank and fan doesn't work. Top oven OK ! - though usually the fan runs when this is operating.
If the clock is blank, then the main oven will not work, as the clock timer is linked with the main oven.
You need to to get the clock working, or you will not be able to use the main oven
Jan 19, 2010 | Smeg DO81CSS Electric Double Oven
Stoves 720EF - main fan not working
When you say the main fan, do you mean the background cooling fan or do you mean the circulating fan in the bottom oven?
Do you have the handbook for this oven as the wiring diagrams are included in it. If you haven't, you can take a copy from my BT Digital Vault - all I need is an email address to register you.
Looking at the diagram, the power for the cooling fan comes via the timer board. If, as you say, the fan doesn't work at all, the timer board could have gone faulty.
Nov 15, 2009 | Stoves 720EF Electric Double Oven
I have a very old tricity double oven with a top part and bottom part of the oven it doesnt have a hob as thats separate.It has three nobs to the left that are for the grill, the lower oven and the main...
I think I might have a manual for this oven! Is it a built-in job with the grill at the bottom and main oven at the top, made by Thorn Tricity?
Aug 07, 2009 | Ovens
Oven won't heat
Check your main panel. If you ran it for a long time with the door open, the elements never reached their shutoff temperature. Quite possibly, you burned them out.
Feb 19, 2009 | Ovens
Just brought a bosch oven and there no life in the bottom oven
If it has a timer, then make sure it is set manual and not auto, or the oven will not work.
Try pressing 2 buttons at the left of timer and one button on right of timer to set it to manual, if it does not work this way, then try another combination of buttons.
Hope this helps.
Plz rate my solution.
Thanks.
Jan 03, 2009 | Bosch HBL 435 Stainless Steel Electric...
Neff Oven
It appears that the timer has gone faulty, possibly because of a short in the bulb holder, which probably explains why there is no display and the main oven not working. the top will still work as it is not controlled by the timer.
the solution hear would to be fit a new timer.
Sep 30, 2008 | Neff U1661 Double circotherm super...
Main Oven Issue??
the clock need to be set to work the main oven
Dec 03, 2007 | Tecnik TKC8525 Double Oven
Ovens Logo
104 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
