Question about DeLonghi MW 605 Convection/Microwave Oven
Main oven doesn't work
Main oven doesn't come on although top oven does there are three buttons that operate the timer that don't seem to be working , is that my problem
In oven the start button is not working
see the details and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Nov 15, 2012 | Whirlpool Microwave Ovens
I want whirlpool oven mechanic in kakinada
see the details and proceed according. fix it. God bless you
My microwave keypad wont work the light is on and the reading says please touch clock and set time of dry
SEE THIS CAUSES AND FIX IT. God bless you
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Oct 01, 2012 | Kenmore 80809 Microwave Oven
Maytag microwave keypad
see this causes and fix it. God bless you
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Time and weight setting doesn't works
There will be a reset switch button on your microwave's timer or somewhere on the appliance. Try the button and if it doesnt work then call customer care. It seems like a minor problem and can be fixed quickly..
Jul 29, 2012 | Panasonic NN-C994S Convection/Microwave...
Microwave is less than a year old. It looks like everything is working, timer, light, air, turntable, etc., but it doesn't cook.
HI..there is a heating filament of an oven MAGNETRON..it s responsible of producing heat to the oven..possibly this is defective ..this filament must be replaced by a new one..theres no problem with the motor cos it runs the table power and light button seems working..HOPE THIS HELPS
Jul 06, 2011 | Oster Microwave Ovens
Hi there, everything seems to be working fine -- lights turn on, fan works, buttons all work, clock working, timer working, etc. -- but the microwave won't heat anything. any recs?
Generally, there are one of three failures.
Blown fuse in the Magnetron circuit.
The main capacitor failed (Required to power the magnetron)
The Magnetron itself has failed.
My local appliance repair guy helped figure out my last microwave failures. Once was the fuse the other was the capacitor.
The fuse was a couple bucks, the capacitor was $25 or so.
Generally, if you are not familiar with repairing a microwave, it is best to take it to a repair shop to be evaluated/repaired as it is real easy to get shocked working on one.
Dec 06, 2009 | Microwave Ovens
No heat in Microwave operation
Check High voltage rectifier diode if it is ok replace the Magnetron.
May 03, 2009 | Panasonic NN-9804 Microwave Oven
Can't use the microwave at all
you have either a bad keypad or control board.
If you have operation of some buttons and not others its the keypad. if you have no operation out of the buttons at all you have a bad control board.
If you turn your microwave on and it sets and the timer counts down you have a bad interlock switch..
please let me know exactly what your microwave does when you set the cook time
Jan 08, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
DeLonghi MW 605 Convection/Microwave Oven Logo
19 people viewed this question
Top DeLonghi Microwave Ovens Experts
William Miller
William Miller
Steve Mason
Are you a DeLonghi Microwave Oven Expert? Answer questions, earn points and help others
