Question about Freezers
Fridge defrosted and the motor seems to have stopped working, electricity working fine to it
Electricity running fine into fridge just seems to have stopped functioning
    Sergeant:
  • 230 Answers
Most likely t-stat. If the t-stat is good then move to compressor. If you hear a hum then a click and it shuts off, that is the internal overload telling you the compressor is done and needs to be replaced.
Posted on Apr 13, 2014
Where is the evaporator fan motor? My Freezer and fridge would quit cooling/freezing. I took the back panel off in the freezer a week ago and the evaporator coils were completely frozen over with ice. I...
I do not believe the problem is the fan. sounds like the frig. is low on Freon this is what will cause the ice build up. you need to find the leak, you can do this by spraying soapy water on coil tubes & watch for bubbles. repair leak & recharge.
May 25, 2015 | Samsung RS261MDBP Side by Side...
Frigidaire freezer runs a lot. Located in garage. In summer runs almost non-stop. Currently outside temps are below 0 deg F and freezer still cyles frequently. Have replace the freezer tstat. Defrost...
Yup, these timers have a tiny clock motor that can get lint on them, causing motor failure, should be simple replacement. Refrigerators in cold garages run more to regulate their temperature below 45 degrees.
Jan 29, 2014 | Freezers
My freezer is not cold. The temperature dial reads 1-5 then an igloo and a snowflake. Do I put it on the snowflake to get it cold or the igloo?
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working.
* Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Take care in solving the problem....
May 01, 2011 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
My freezer is getting cold but the fridge is not getting that cold what do i need to do? the motor is working
Hi, Try to defrost the fridge. Sometimes air flows stops due to access of ice in the freezer. Try to defrost it and see if it works.
Regards, polysandy
Apr 24, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Fridge freezer side by side running constantly but not cooling.
Make it a habit to defrost it every week. You see, when ice forms around the evaporator tubes (which runs around the walls of fridge and freezer), heat exchange reduces (that means heat is no longer absorbed from the things inside the refrigerator) and cooling stops. See whether freezer walls or fridge walls are damaged. Do not use knives or any other sharp tools to remove ice. Do not forcefully remove items that are difficult to take out from the freezer. Defrost and remove them.
Aug 12, 2009 | Freezers
Freezer ok, fridge not cold
Often you can unplug it overnight and it'll melt out, correcting the problem for some time.  The electric element might be burned out, although I'd suspect the defrost timer.  It's usually located behind the unit, near the bottom.  Often all you will see is a 3/4" hole in the back plate with a flat screwdriver slot.  Turn it (only turns one direction) with a flat screwdriver, and all will work fine for some time (usually).  If not, standard procedure is to replace the defrost timer assembly, as the clock motor has likely gummed up.  Maybe available at http://www.repairclinic.com, or a local appliance repair shop.  They're often generic, as in not specialty oem specific.
Jul 16, 2009 | Freezers
BEKO Frost free freezer not as cold as it should be!
Sorry I don't have a solution for you, however would like to know if you found out what was wrong. I have an identical problem with my Beko fridge/freezer. It's only 14 months old and the freezer just wont freeze. I've turn it off for 24 hour and let it defrost completely (even had the panel off to make sure there was no ice left). I've turned it back on again and it still wont freeze. Everything seems ok, ie fan blowing, motor running etc. I really am beginning to regret buying Beko. thanks
Apr 12, 2009 | Freezers
Fridge freezer not working after power cut
If the fan motor is running at the compressor you should first replace the compressor start relay.
If the fan motor at the compressor is not running replace the defrost control.
Feb 21, 2009 | Freezers
Auto defrost is not working on my zanussi ice free fridge /freezer
You have a defrost problem. It means you have 3 parts that can be involve ( timer, defrost thermostat, element) most of the time it's the timer. Hope it was helpful. :)
Francois
Aug 25, 2008 | Freezers
Fridge freezer upright
Replaced the thermostat
Jun 22, 2008 | Freezers
Freezers Logo
107 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
