Question about Cell Phones
A78 i have tablet Ampe A78.My tablet have software problem.As i also tried to reboot by pressing volume down button and power button several times but an image appear showing software problrm.plz guide
I need to know how to reset my Hisense Zero 7 Lite tablet. I forgot my password
you will need to hard reset the tablet
turn off device
press volume down and power button at the same time when u see the hisses logo release the keys
you will see android man press the power and volume up button at the same time and release the keys
you will see writing go down to wipe date with the volume down button highlight wipe data press power button to ok it
then go down to yes highlight yes with the volume down button press power button to ok then it will reset it then will come back with writing
go down to reboot highlight reboot then press power button to ok it
the tablet will restart
Mar 15, 2018 | Tablets & eReaders
I want to activate my RCA tablet.
unlock a RCA tablet hold down power button and the volume down button till no command screen then press home button 5 times till the android man comes up with writing go down to the with the volume down button highlight wipe data press power button to ok it then go down and highlight yes go down to yes with the volume button press power button ok white all the writing back on go to reboot press power button to rest your tablet
Mar 11, 2018 | Tablets & eReaders
How do i factory reset my verizon samsung 10 tablet?
To help you perform a factory reset if your Samsung tablet is working and powered ON, please follow the instructions mentioned below:
- It is recommended to back up all the data like Phone contacts, Email accounts, App settings and Downloaded apps, Music-Picture-Videos, Internet browsing data and Personal data from the tablet before performing factory reset.
- From the Home screen, navigate: Apps > Settings > Privacy.
- Click on 'Factory data reset'.
- Click on 'Reset tablet'.
- Click on 'Erase everything'.
- Allow several minutes for the factory data reset and reboot processes to complete.
Now, if in case you need to perform a factory reset if your Samsung tablet is powered OFF, please follow the instructions mentioned below:
- Press and hold the 'Volume Up button' and then briefly press the 'Power button' to power on the device.
- Release the 'Volume Up button' and the 'Power button' when the Samsung logo displays on the screen.
- Use the 'Volume Up button' to select the 'small android with an arrow' icon.
- Press the 'Volume down button'.
- From the Recovery Console screen, use the 'Volume button' to select 'Wipe Data / Factory Reset' then press the 'Power button'.
- Use the 'Volume button' to select 'Yes' then press the 'Power button'.
- Once the Wipe Data / Factory Reset has completed, use the 'Volume button' to select 'Reboot System Now' then press the 'Power button'.
GuruAid.com
May 24, 2016 | Samsung Tablets & eReaders
I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO...
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Oct 29, 2014 | Tablets & eReaders
How do i get to the BIOS on a craig 7" netbook clp218?
I have no idea about these craig things which are Android machines, Try this.
Cannot be worse than you got.
How to do a hard reset using external keys? If your tablet is completely locked up and you cannot access the menu functions, use the following method to perform a hard reset using external keys on your tablet:
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
If it doesn't work try search engines for 'Android tablet hard reset'
Sep 10, 2014 | Computers & Internet
How do I reset my factory settings on my Proscan Tablet PLT7810K? I forgot the screen lock password.
I'm not an expert on this particular machine but please try this method:
  1. Press Power button for 2-3 seconds and select Power off.
  2. Press and HOLD the Volume Up button.
  3. Press Power button and release it. Still hold Volume Up button.
  4. When you see the Android screen, release all buttons.
  5. Press both Volume Up and Power buttons for 2 seconds.
  6. You should then see a blue menu. Use Volume Down to select wipe data / factory reset. Press Power to select.
  7. Use Volume Down to select Yes - Delete data. Press Power to reset
  8. Select Reboot system now. Press Power to reboot.
  9. Setup your tablet again and use it as a new tablet.
I hope this helps - Good Luck.
Aug 25, 2014 | Proscan 8" Tablet with 4GB Memory
Locked out of my tablet by my child entering a new pass word...
To unlock your tablet, you will have to perform a factory/hard reset of the device.
Performing a hard reset will DELETE ALL DATA from internal device storage and reset the tablet back to the state before you turned on the device for the first time. Resetting the tablet does not erase any system software updates you have downloaded or any files on your SD memory card, such as music or photos.
To perform factory/hard reset please follow those steps:
1. Turn the power off.
2. Press and Hold the Volume Up and Power button at the same time.
3. When the start up screen show (Samsung logo displays on the screen), release all the buttons.
4. Use the Volume Up/Down button to navigate to "wipe data/factory reset", select with Power button
5. Select "wipe data/factory reset"
6. Select "Yes -- delete all user data"
* Allow several minutes for the factory data reset process to complete.
7. Select "reboot system now"
* Allow several minutes for the reboot process to complete.
Oct 10, 2013 | Samsung Xe700t1a-a05us Tablet
English manual for a AMPE A78 tablet
Please send for me user manual ampe a78 in English. frahaas@gmail.com
Apr 10, 2013 | Tablets & eReaders
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
