Security on router
Connection failing
  • 52 Answers
What router model / brand do you have?
are you connecting by wifi or LAN ?
Posted on Mar 25, 2014
Can't get blue ray to connect with wireless
If the login keeps failing it could be security level related. Some devices are not compatible with the higher levels of security settings that the router can provide. Try turning off the routers security and see if the blue ray can connect to the wireless network without having to log in. If it does then turn the security back on but at the next lower level. I find WPA2 Personal is the most compatible higher level.
Oct 20, 2014 | Computers & Internet
Connection failed
This is a message from the AVR2312CI attempting to connect to the Internet through it's local area network Ethernet socket. Turn this feature off in the setup section if you do not need to connect. If you do want to connect, make sure you have a good connection to your router and, if necessary, make sure your security software is not blocking the connection. If that fails, turn off modem, router(s) and amplifier then switch on in the order:
modem,router(s) and finally your AVR2312CI.
That should solve your error message.
Regards, Don.
May 31, 2014 | Denon AVR-2312CI
Router is secure, but cannot connect to wireless . Get error that SSID failed when I run printer test. It is a HP4180.
There is a chance that the wireless device on the printer can not process SSID's with spaces in them.
Also the wireless device may not be compatible with the type of security used on the router. So try changing the wireless security settings on the router as well.
Feb 24, 2011 | Linksys Wireless-G WRT54G Router
Power supply failed. Replaced. Even with no ethernet connections, power, and leds 1 through 4 are flashing rapidly.
Log into your router,check to see if your wireless connection is secure,If not secure it asap,flashing lights are a sign of connected systems.
May 27, 2010 | U.S. Robotics (USR8054) Router
How do I change my security settings in my dir 600
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable. Do not change wireless settings using a wireless computer.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Mar 01, 2010 | D-Link DIR-600 Router
3 failed attempts to connect HP DV6t laptop
First as a test, turn off the wireless security, and see if the laptop can connect.
If it can connect with security turned off, then it is likely that you are making some type of mistake with the password. (Such as caps lock being on, or having a keyboard error.)
Good Luck!
Jan 03, 2010 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Cant connect ps3 wireless to dlink router
The router should assign an IP address to your PS3 if it isn't manually configured. If you are connecting wirelessly make sure your security setting on your PS3 match your router. If the problem persists disable wireless security on your router and then try to connect with the PS3 with security disabled as well. Sometimes consoles have trouble connecting with WEP or WPA security encryption.
Jan 06, 2009 | D-Link AirPlus DI-524 Wireless Router
D-link router connection problems
I'm guessing you're saying you've left the security open on the pc's, but what about the router? You can connect to most wireless routers with a TCP/IP cable. Try that and see if you can check your wireless router's settings. It may have some security settings enabled.
Nov 18, 2007 | D-Link DI-634M Wireless Router (DI634M)
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
