Question about Optoma HD80 Projector
Optoma HD80 flashing blue lights
When switched on it self-tests OK then starts noises of fan, color wheel, lamp lights then after 10-20seconds all stops no fan or color wheel noise and lamp goes off and all control panel lights continuously flash blue together, no red warning lamps. Cannot switch off with Power switch only unplug mains lead, when reconnected after 15 minutes exactly the same problem, lamp is about 200 hours old and was Optoma genuine lamp. Can anyone help please
  • 790 Answers
Sound like the original color wheel for Optoma HD80 is bad.
If the unit has been moved when hot.
If not, try un-plugging the unit for a few minutes and re-connect.
Hope this helps
Posted on Mar 23, 2014
  • 4 Answers
SOURCE: Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Posted on Mar 10, 2009
vortash
  • 431 Answers
SOURCE: optoma projector switches off after 5 mins
AS regretable as this sounds component failiure was my first thought .. It's not the bulb temp sensor as the fan is opperating and that usually cuts all power .
You may find that as you have a bulb ( usually worth more than the units they reside in ) rather than a repair another unit of Ebay would be a safer and more economic conclusion ... Regards Vortash
Posted on May 10, 2009
  • 4 Answers
SOURCE: The lamp of my optoma hd80 shut down after 20
Hi Pierre,
Did you resolve this issue. I am facing a similar on. After a few minutes, the lamp shut down and the the red lamp light turns on. I was thinking it is an overheating issue.
Regards
Ludovic
Posted on Mar 31, 2010
  • 4 Answers
SOURCE: optoma hd80 lamp cutting off,then unable to turn
did u find a solution?
Posted on Apr 01, 2010
SOURCE: Optoma EP719 lamp does not come on
I have the same problem. The 10V 3200uf capacitor is bulged. Can't find one on the web. Where did you get yours?
Posted on Apr 18, 2010
MY PROJECTOR TURNS OFF AFTER A COUPLE MINUTES
- Check LED Status
a. Lamp LED Light
- Check Lamp
- Check Lamp Driver
- Check Main Board
b. Temp LED Light
- Check Thermal Sensor
- Check Thermal Switch
- Check Fan
c. Color Wheel
- Check Color Wheel
- Check Photo Sensor
Sep 03, 2014 | Optoma Hd70 Dlp Hd High Definition 720p...
Optoma gt700 is all green after replacing color wheel
we mainly retail or distribute color wheel, light tunnel ect sparet parts for projector or TV, so we have experience on that problem you faced.
perhaps you ordered a compatible color wheel,but it is not big trouble. compared with your old wheel, you will find a black tape, just make it as the same position as your old wheel, it will be ok.
Jun 25, 2014 | Optoma Office Equipment & Supplies
Projector
What is the model number?
Nov 23, 2013 | Optoma Office Equipment & Supplies
Buzzing/humming noise won't stop. Lamp was replaced a year ago. This just started and the noise is near the lamp. The noise won't stop while the TV is on and lasts for a minute when the TV...
If its a DLP with a high pitched or even fan like sound it is the color wheel--Mitsubishi does not sell them as a part---you would have to replace the entire light engine (expensive and may not be available any more on a older set) .
Nov 08, 2012 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Samsung dlp tv HLP5663W makes loud noise
Yes, the set uses a color wheel and the lamp faces it.
The wheel turns at over 8,000 rpm and is well known for this problem=bearings in the tiny motor go bad.
The high pitched or fan like noise (classic description) is this part.
Sooner or later the wheel (plastic colored segments) will shatter and set will shut down lamp and not operate---set monitors the speed of the wheel so if it slows down or stops it knows.
The part is readily available on the internet (Google the model number with "color wheel").
This can be a do it yourself repair and You Tube has video instructions for replacing the wheel by model number.
There are two common pitfalls to avoid which the instructions that come with the replacement part usually do not mention---if you decide to do this repair let me know and I will explain.
SD TECH
May 26, 2012 | Televison & Video
Temp light flashes and then shuts down
hi,
possiblely it is the problem of fan, try to check the radiator fan port.
later use the machine, shut off it, until the lamp fully cool.
regards
Jack
WHOLESALER AND RETAILER FOR BELOW PRODUCTS:
projector color wheel, lens and bulb, remote, lamp power, mother board. all brand and most of model.
computer mother board, memory, harddisk,
HP server, switch, and router.
Nov 21, 2011 | Optoma MovieTime DV10 Multimedia Projector
I have a Optoma HD80 and the bulb has about 450 hours on it. I cleaned the projector, unpluged it for several mins and still turns off after starting. If the bulb has only 450 hours on it, why should I...
hi,
You have to check the bulb first. Its not the matter of how many hours you have used it. just check the lamp. may be it burned out. Its only a bulb it can burnout at any time. also check the lamp colling fan is working or not. if it is not working the same problem can occur.
ok
Feb 06, 2011 | Optoma HD80 Projector
I have a Samsung HLN617w that has an awful buzzing noise that seems to be continuous and maybe from the lamp fan. Any suggestions on a fix?
This tv have a colors wheel is dying and worn out.The sound u hear buzzing,squiling or lound motor noises.The colors wheel require changing,because it dying and spinning off of it motor axis.Hire a tv Tech. to change the colors wheel,because it sit way inside near the Light Projection Engine it self,require take out many machanical parts even can come to the colors wheel itself to change it.
Nov 28, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Optoma HD80 Projector Logo
336 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
