Question about Freezers
ICE BUILDS UP IN LIEBHERR FREEZER
AFTER 6 WEEKS ICE BUILDS UP AND FREEZEER STOPS WORKING
    Sergeant:
  • 230 Answers
Needs a new defrost timer. If ice builds up then you are not defrosting. If you are not defrosting then the t-stat will read the ice and think it is down to temp and shut off.
Posted on Apr 13, 2014
  • 13 Answers
SOURCE: auto defrost is not working on my zanussi ice free fridge /freezer
You have a defrost problem. It means you have 3 parts that can be involve ( timer, defrost thermostat, element) most of the time it's the timer. Hope it was helpful. :)
Francois
Posted on Jan 21, 2009
SOURCE: kenmore freezer upright frost build up on door
first just take it out and clean that one carefully .And then set correctly and observe it,s working condition.then also it's not working means show it to ur near by worker those who repairs it
Posted on Jun 20, 2009
  • 358 Answers
SOURCE: freezer builds up frost and ice too quickly.
Either the door gasket is not sealing well or the unit is low in refrigerant.
Posted on Sep 25, 2009
  • 454 Answers
SOURCE: Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Posted on Mar 13, 2010
  • 389 Answers
SOURCE: I have a liebherr freezer with ice maker. ice maker broken
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
Replace ice tray
the complete ice maker will need to be removed from freezer because the thermistor comes on the new tray that you will replace.
Aug 30, 2014 | Liebherr Freezers
Maytag MFI2269VEM2 Freezer issue. In the past two weeks, twice ice has built up in the freezer so much it is causing the fan to stop working and has been running really loud. Twice now we have taken the...
it is not defrosting. timer ,element , limit switch maybe issue. find defrost timer advance it see if compressor and fan quit running. when you advance this it should start defrost mode, which turns on the heater, which stays on till limit switch opens or timer advances, most are on 12 hour cycles
Oct 02, 2013 | Freezers
I HAVE ICE BUILDING UP UNDER LOWER DRAW OUR FREEZER IS A LIEBHERR 2966
I know this unit very well, this means the thermistor on the back panel has failed, the factory has an updated kit to fix this issue, let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Liebherr Freezers
Apr 17, 2010 | Freezers
Freezer builds up frost and ice too quickly.
Sep 24, 2009 | Freezers
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
Water drains into fruit bin. not drain hole.There is no blockage in drain hole that I can see.F/F Liebherr premium model
If water drains out, then there is always a blockage somewhere on drain line.
Defrost the unit completely to get rid of ice building inside drain lines.
If that does not work , then the drain line must be unlocked using a flexible shaft.
May 21, 2009 | GE Freezer  14.8 Cu. Ft. Manual...
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezers Logo
173 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
