Question about Lenovo ThinkPad T61 7665 Laptop AC Adapter 20V-4.5A 90W (AC04VPNATNQNN)
Fan error loose connection
Fan error
    Top Expert:
  • Lenovo Master
  • 14,161 Answers
Have it serviced at a local computer repair shop.
Posted on Feb 19, 2015
Rinnai R85 starts to warm then stops and blinks 61??
I went to the Rinnai website and this is what I found for error code 61.
Error Code 61 Problem: Fan failure
Solution: Measure the resistance on the fan motor, check the damaged or loose wiring and connections. Make sure that the fan spins freely.
Sounds like either your fan is broken or something is keeping it from spinning freely.
Hope this helps.
Gary
Feb 24, 2015 | Rinnai R85ePLUS Tankless Water Heater
I have replaced the evaporator fan and the main board and am still getting the ef error code
Hi, your unit has a loose harness behind the fan motor at the wall. Manually push in every wire to assure a good connection, the error you have is that the control can't sense the fan speed. Unplug the unit when you do this to assure the computer can see and sense the fan. Failure to unplug first will not work. Good Luck.... PS once fixed use a sealant to keep these connection tight and clean.
Aug 17, 2014 | Frigidaire Refrigerators
My home dvd/cd receiver has pt fan error
you must repair it.
please inspect if fans comes up with power on.
sometimes feedback wire loose connected.
or circuit inside the fan malfunctioning.
better thing is replace.
Jun 28, 2014 | Pioneer HTD-510 System
My Ricoh SPC811 DN shows always an error code SC491
hi
this error code is about "Cooling fan motor lock", we have 2 Reason for this code,1: Cooling fan motor defective or a loose
object is interfering with the fan and 2: Poor fan motor connector connection
please check them
Oct 06, 2013 | Ricoh Brand Aficio Spc811dn WASTE DISPOSAL...
I have an HP m9050 MFP which gives an error 30.01.06-Scanner Failure whenever i touch the copy button and it all started after blowing and servicing
Based on the service manual a 30.01.06 Scanner failure:
1. With the MFP powered on,
verify that the fan is not
functioning.
2. Check for loose connections
and broken, frayed, or pinched
wires. Reseat the fan connector at
scanner control PCB location
J110, and connector J163 on the
flatbed fan.
3. Replace the fan. See "Flatbed
fan assembly" on page 154.
However print of a configuration page or event log and look at the past 30.X.X error codes make sure it's not jumping between a 30.01.06 - 30.01.10 as it could be something more than just the fan.
Oct 19, 2010 | Office Equipment & Supplies
Trouble with model LFC25760ST inside display refrig registering Err and freezer FF and things are not cold
That is a freezer fan motor error, the freezer fan is no longer running. Check the freezer fan for a loose connection, if everything checks out ok there you probably need to replace freezer fan.
Oct 07, 2010 | LG Refrigerators
How do I reset the error log in the bios? At boot up is reads that the CPU fan is not running but it is.
The bios is not picking the fans information,ie speed and temperature, therefore given an alert that the fan is not working.
The fan has three wires, black which is the negative, red which is the positive and the yellow which feeds the bios with the information, even though the fan is working the bios thinks it is not, to solve this check the connector for the fan is attached properly, unplug from the board and give it a blow, and the same with the connecter on the board and plug it back in. Boot up the computer.
If you still have the same problem then you might have check the connection to the fan to see if it is loose at all, if not to solve the error mesage you will have to buy a new fan.
Feb 09, 2010 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
There is a message which says that an error has ocurred with the ventilation
HI. This will occur if the motherboard has detected an error within the cooling fans structure. The fan may have failed, mechanically, or there may be a loose connection at the fan circuit, as well. Kindly open the desktop compartment access panel, and observe the cooling assembly. This will most likely be a set of cooling fans, mounted on the rear of the desktop compartment. If the fans are not rotating, this will be the cause of the error. check the fan connections at the fan motor, and motherboard connection port,as well. If the connections are sound, replace the cooling fan(s).
To determine if the motherboard is the issue, simply jump the fan with a 9 volt battery. If it is operational when jumped, this will indicate a more serious issue that concerns the motherboard, or heat sinks.
Nov 23, 2009 | Computers & Internet
57.70 error for hp colorlaserjet 9500n
this is the fuser fan error replace them ur problem will be resolved
Nov 25, 2008 | HP LaserJet 9500n Printer
Fan making noise help
Start by taking the machine apart, cleaning the fan, and checking the connection. The failure may be due to debris buildup or a loose connection, and I've also seen fans stop working because a hair has gotten wound in them. If it still doesn't work properly after cleaning, then it will need to be replaced. Here's a link that has breakdown diagrams and instructions, this should help.
http://repair4laptop.org/notebook.html
Jun 26, 2008 | IBM ThinkPad T40 2373 Notebook
Lenovo ThinkPad T61 7665 Laptop AC Adapter 20V-4.5A 90W (AC04VPNATNQNN) Logo
75 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
